Old Jun 21, 2009, 05:55 PM
Majortomski is online now
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
Help!
Green RC Super Tiger Moth ARF ????!!!!
I got one of these 78 inch kits for father's day. The structures and the fittings are worth what I paid for it.
The instructions are practically worthless. My kit pacakaged in 2006 even has an addendum to the instrucions, which doesn't make any sence WRT the original set.
Biggest disappointment where does the engine go wrt the rest of the fuselage? How far out should the thrust washer be from the fire wall.
"Attach the cowling with 3 self tapping screws"... Wher?
Has anyone figgured out these details? Or is there a better translated set of instructions?
TIA
Tom
Majortomski is online now Find More Posts by Majortomski
Old Jun 21, 2009, 07:02 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Sometimes.... you just have to act like you know what you are doing and make it work.
I've run into this type of poor instruction issue with a few ARFs...
Slide the cowl in place so it looks right. (eyeball comparison to a good picture will be pretty accurate...) Tape in place. Poke a ruler in through the hole the prop shaft is supposed to come out of and measure from the front of the cowl to the firewall. Add 1/4 inch. Thats how far out the back of the spinner should be.
This makes some allowance for thrustline offest tilting the spinner in relation to the front of the cowl. If the front of the cowl is angled you don't need to add quite as much.
finding where to bolt the engine... make a disc and tape it to the front of the cowl (still taped in place...) Poke a hole centered in the disk (centered in the prop opening)and align a brass tueb n the desired thrust line. Shove a sharpened music wire in through the tube and make a "ding" in the firewall.
Follow your engine/motor mount instructions for aligning the mount to center the prop shaft on that mark. Shim as needed to get the thrust line.
Result SHOULD be that the engine/motor shaft comes out centered in the cowl. (if you did it right)
Hunting for the hardpoints where the cowl mounting screws belong means assuming the hardpoints are even there... often a bad assumption.
Pick 4 points (2 each side) and install your own hardpoints. There are many different techniques you could use... one that works well is angle brackets bolted to the firewall and tapping the metal bracket for the screws that will go through the cowl. use rubber grommets in the cowl and blue or green locktite on the screws that go into the threaded bracket.
These are generic "How to deal with China Model Products ARF" (and similar) tips...
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jun 21, 2009, 08:40 PM
Joined Aug 2000
Well part of the problem is just how far back past the firewall is the rear edge of the cowling supposed to go?
It says attch with three screws, if I push it as far aft as it will go then the upper radius and an edge on the bottm make contact with the fuselage. The flat sides of the cowl are a good 1/8 inch away from the fuse sides. Not really a good place to make a secure attachment.
This is more like scratch building an arf the instructions are so poor.
Old Jun 21, 2009, 09:26 PM
Joined Mar 2005
Tiger Moths are very forgiving of things that would normally make a biplane unflyable. So don't get too worried. The most important things is that the wings are properly aligned to each other.
I doubt you want the cowl as far back as you can push it... but to get better info you'll have to find someone who actually put one of the same ARF together.
Old Jun 22, 2009, 07:03 AM
Joined Aug 2000
Exactly why I'm posting here
Old Jun 22, 2009, 11:28 AM
Joined Aug 2000
Airliners.net was a bit of a help. the cowling, at least in the 1:1 scale bird bumps up against the cabanes and the landing gear forward support struts. Now I have an idea of where to mount things.
Old Jul 11, 2009, 12:25 AM
Teals1 is offline
Find More Posts by Teals1
Teals1's Avatar
New Zealand, Auckland, Papakura
Joined Nov 2006
Hi Guys, Thought you may like to see a picture of my Tiger Moth which is close to being finished. It's a quarter scale Flair kit, power is a Laser 150 four stroke. It is covered with Coverall and colour scheme is based on a full size here in New Zealand. Have some detailing to do and fitting of plumbing and radio gear. The Flair kit instructions are good but there is no mention of side or down thrust. Have heard that this is Ok for the TM as it is a slow flier. You may be interested to know that in this kit, the large cowl only has three small screws to hold it in place. They screw into wooden blocks glued to the firewall. The metal 'L' brackets would work well too.
Teals1 is offline Find More Posts by Teals1
Old Jul 11, 2009, 12:30 AM
Teals1 is offline
Teals1's Avatar
Joined Nov 2006
Forgot mention, the wind screens are just sitting in place here. Not happy with the quality of these plastic molds and may make new ones from lithoplate. The front doors open, the rear doors were removed on the original as they were using it at the time for photography work. Allen
Old Jul 11, 2009, 10:01 AM
Joined Aug 2000
Nice build my arf is finally in just about the same state of completion.
Old Jul 16, 2009, 06:05 PM
spudandcat is offline
Find More Posts by spudandcat
Australia, NSW, Lavington
Joined Jul 2005
G'day, mine is a 150 mm from the firewall, the instructions are a bit vague aren't they!
seeya spud
spudandcat is offline Find More Posts by spudandcat
Old Jul 28, 2009, 04:08 PM
Joined Aug 2000
seeya spud
Mine came out at 143 mm so Mk I eyeball was working pretty well.
Wanted Kyosho Devland DH Tiger moth ARF yukondog Aircraft - Fuel - Airplanes (FS/W) 2 Sep 07, 2005 09:53 AM
het-rc super tucano electric arf help voyagerxp Electric Plane Talk 1 Sep 01, 2005 07:57 PM
Question Super Tiger Moth Colours Buyerlot Scale Fuel Planes 3 Nov 17, 2004 06:05 PM
Looking for a 30 size Tiger Moth Arf? new2heli Scale Kit/Scratch Built 66 Nov 28, 2003 08:30 PM
72" Dymond Tiger Moth ARF Kit dbarrym Aircraft - Electric - Airplanes (FS/W) 1 Mar 08, 2002 08:39 AM
