Old Jun 21, 2009, 11:11 AM
luv2fly is offline
Find More Posts by luv2fly
luv2fly's Avatar
Joined Apr 2001
What does plug n play mean.......
Not up to speed on the electrics yet.
luv2fly is offline Find More Posts by luv2fly
Old Jun 21, 2009, 11:50 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
As the title says: Plug and play
Basically, PnP models normally come with a motor, ESC, and servos, and all you have to do is supply the radio, reciever and battery. Plug them in, and go play
Xpress.. is offline Find More Posts by Xpress..
Old Jun 21, 2009, 12:12 PM
gavoss is online now
Find More Posts by gavoss
gavoss's Avatar
USA, OK, Oklahoma City
Joined Mar 2001
More specifically, there is no programming the ESC to allow the motor to turn the correct direction, whether to apply allow the battery to completley shut down to "0"
volts or shut off at a specific minimum voltage. This is all covered by ESC programming.
Xpress is correct of course as far as the motor goes, but you might have to use servo reversing and end point adjustment on the flying surfaces. gv
gavoss is online now Find More Posts by gavoss
Old Jun 21, 2009, 01:09 PM
SabreHawk is offline
Find More Posts by SabreHawk
Off we go.............
SabreHawk's Avatar
Seattle, WA. USA
Joined Jan 2006
It simply means it's equipped with everything except your own reciever.
You just plug the plane's servos into your reciever, plug in the battery and its ready to play.
Plug, and play.
SabreHawk is offline Find More Posts by SabreHawk
Old Jun 21, 2009, 01:37 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Plug, and play.
Like I said, a lot of PnP's, such as Eflite PnP's do not include a battery or charger
Old Jun 21, 2009, 06:04 PM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
Since Horizon has a registered trademark on Plug-N-Play, here's how we define it:
Motor, ESC, Servos are included, customer supplies his own receiver, battery, charger and transmitter.
RTF or Ready to Fly means everything required for flight is included, including the receiver, battery, charger and transmitter.
BNF or Bind-N-Fly means everything but the transmitter is included. Bind-N-Fly aircraft include a Spektrum DSM2 receiver, so a DSM2 transmitter is required.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Old Jun 21, 2009, 07:55 PM
Griffin is offline
Find More Posts by Griffin
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
Basically plug and play means you get absolutely no pleasure of customizing the installation of gear for an ARF, no pleasure assembling a plane, no pleasure choosing a covering scheme, no pleasure of building the plane, no pleasure of solving problems, no pleasure of working off plans, no pleasure making your own plans, no pleasure of selecting and cutting balsa.
Basically, all you get for your money is the pleasure of flying almost as fast as you can charge a battery. For many, that's all that matters anyway, so plug and play is a perfect option.
But many of us are way to lazy and hedonistic to spend money on something with such a tiny payback of pleasure.
-Steve
(Just having some fun with the thread...it's all good!)
Griffin is offline Find More Posts by Griffin
Old Jun 22, 2009, 12:11 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
^OR PnP means hassle free components selection, such as for a modeler who needs to get a plane flying wuickly, or needs to take a break from building, or for an inexperienced modeler not ready, or comfortable yet with building a plane, or selecting components
What Does PCM and PPM mean? putt_13 Beginner Training Area (Aircraft-Electric) 6 Jun 22, 2015 06:04 PM
What does PAL and NTSC mean???? raythomas Aerial Photography 3 Mar 07, 2003 11:42 PM
What does this motor code mean Foxy Power Systems 1 May 28, 2002 05:39 PM
What does the CE symbol mean Ben Lanterman Electric Plane Talk 2 Feb 28, 2002 05:34 PM
what does the black dot mean breadboy Electric Plane Talk 3 Sep 13, 2001 09:28 PM
