Old Aug 14, 2009, 09:42 AM
glenbees is offline
Find More Posts by glenbees
Leeds/Bradford Leeds, Great Britain (UK)
Joined Jun 2003
x30pilot, thinking of buying the hunter and will be belly landing on grass. been told you can cover the bottom with lightweight glass cloth and use a substance called poly-c. really great stuff as there is no smells and you can wash your brushes with water. allso foam friendly.
glenbees is offline Find More Posts by glenbees
Old Aug 14, 2009, 10:16 AM
paulhunter is offline
Find More Posts by paulhunter
United Kingdom, England, Chester
Joined Jun 2009
i think i may have to change mine into a belly lander as the field i fly from is quite rough grass so will be glassing it aswell i think! had the plane built for a month but been working away since i finished it and not going to get a chance to fly it till november :-(
paulhunter is offline Find More Posts by paulhunter
Old Aug 14, 2009, 09:31 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Originally Posted by Prof100
Great maiden video. Landing was very smooooooth.
Thanks Prof100!!!
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Aug 15, 2009, 05:55 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
@ Eric,
Here is how I did my Elevator setup. Works great, no slop and does not protrude into the outlet duct. Good luck!
Regards, Chris
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Aug 15, 2009, 04:10 PM
giddyuperic is offline
Find More Posts by giddyuperic
giddyuperic's Avatar
USA, CA, Riverside
They came out great I like what you have done. My first one had the long rods on it and the did not move the elavator very good at all. It was really bad had to run them on high rates all the time. I am going with your set up this time. Did you just hot glue them in and have you maidened your plane yet?
giddyuperic is offline Find More Posts by giddyuperic
Old Aug 15, 2009, 04:16 PM
NY, Rochester
Joined Oct 2003
Yes, just glued them. Maiden: yes! (see page 9)
Old Aug 15, 2009, 04:30 PM
X30PILOT is offline
Find More Posts by X30PILOT
X30PILOT's Avatar
Joined Aug 2007
glenbees
Glassing the belly of the hunter is not an easy task. Unlike the smooth belly of my Phase 3 F-16, the Hunter has lot of detail on the bottom and all this would need to be sanded off to get a smooth surface to glass.
Thanks for the kind words.
Is the servo over throwing or is the mechanism just rough and not working smooth? If it is a bad mechanism, get to me in email and we will work on a replacement for you. Also have you looked at the Suspension Struts for the Hunter? Really sweet!
Also I use these Du-Bro servo savers for situations like this where the servo might over throw or on the steering servo.
Take a look here: Du-Bro Servo Saver
Hope that helps
Max
Max,
I certainly appreciate the offer for the replacement nose gear, I lubed the current unit with some Tri Flow and it works smoothly now.
Dave
X30PILOT is offline Find More Posts by X30PILOT
Old Aug 15, 2009, 08:58 PM
Hawk Fanatic
Joined Jul 2008
I've got a somewhat extensive build log on another thread. Go check it out as it gets built. Well, its already built, but my procrastination has finally caught up to me and I'm now finally getting around to starting my posts. Let me know what you think.
Old Aug 15, 2009, 09:00 PM
Hawk Fanatic
Joined Jul 2008
Originally Posted by Downwind3Zero
@ Eric,
Regards, Chris
Awesome idea Chris. Looks great too.
Old Aug 15, 2009, 09:39 PM
USA, CA, Riverside
Yes I will do that as soon as my new fuselage gets here. My other one flew like a dream and was pretty fast on the six cell set up. I have the F9 too on the four cell set up and she is down due to a blade wobble and bang that was the end of that. Any way I am going to do that first thing for the elevators. Did you cut the hole at a angle? You must have the body is round that was a dumb question. I love this plane it flies so good I cant wait to start on it and I already know what to do and not do but I am sure I will have more questions. So thanks guys. Eric in so cal
Old Aug 16, 2009, 01:48 AM
NY, Rochester
Joined Oct 2003
Thank you!
Old Aug 24, 2009, 03:38 PM
Uno is offline
Uno
Find More Posts by Uno
Uno
Sweden
Joined Dec 2005
I fly the bellylander. Have about 15 flights. The first ones without droptanks. The cheaterhole and speedbrakes eat grass. Have made shorter droptanks (450liter) as we had on the mark 4 in the Swedish Airforce. I put thin glassfiber with epoxy on bottom of them and also glasfiber under the nose. So far no problem but I consider making sidesupport on the tanks as the real F6 had to the big tanks. With the cg set according to the manual (130 mm) nose digs down hard in the grass. Also rolls are very badly and inverted needs full down. I have a graf of the fullsize cg and when scaled to the model it should be 190mm from leading wingedge. I fly now with 180 mm and just a little down elevator inverted and rolling much better. I also put Sidewinders under wings as we had here in Sweden on the full size Hunter. No bad habits with thoose. Today at 10-12 knots wind I think it was less wingrocking with missiles on. I start with a bungee 5 m surgical rubbertube, 10m nylonline, hook between “breasts” and footpedal for release. Start as from a carrier. After seeing Phillips video t/ and landing on grass I am tempted to order one more with retacts. I do not use flaps. How does it handle with flaps? The real one was pretty nasty made nosedown at high speed and killed pilots. Flaps were very strong meant as speedbrakes but the speedbrake below fuselage had to be added later. I fly on 4S 2500 and 4000 mah and can fly 5 mimutes on the 2500. Use full throttle sparingly. Come in slow and low, hit throttle and go directly in to a big loop. Could not do that with the real one. Lander fan runs very smooth. Beatiful aircraft that fly very good /Uno
Uno is offline Find More Posts by Uno
Old Aug 24, 2009, 03:58 PM
Uno is offline
Uno
Uno
Sweden
Joined Dec 2005
Sorry Jimmy that I called You Phillips. For other pilots here is the link to Jimmys nice Hunter flying on grass. http://www.nlmfc.org/index.php?optio...d=131&Itemid=1 Best regards Uno.
Old Sep 06, 2009, 01:43 AM
USA, CA, Riverside
Better the second time around!!!!!
Sorry chris but I could not put the servos back in the fuselage. I only have a six channel radio and the flaps go on the slave. Well maybe next time but what I did is go with the gold rods from sullivin they move like butter and was able to make a new and better spot for the servo. My friend as been helping me alot she should be ready to go by tuesdayfor her maiden. Still running the 22.2 volt with 2800 mAh and I have the nice gear on her too. It worked so well last time the gear is very good.
Old Sep 06, 2009, 02:34 AM
Jimmy_H is offline
Find More Posts by Jimmy_H
Jimbo and the Jet Set
Jimmy_H's Avatar
York
Joined Jul 2005
No worries UNO, thanks for the kind messgae you left on my review, I love flying her and the retracts are holding up well to grass. Our strip is quite a bit longer as the weather is changing and temperature droping but no signs of any problems so far
Jimmy_H is offline Find More Posts by Jimmy_H
Cool New Mini FuntanaX from e-flite (official build thread/ flying thread!!) p51flyer 3D Flying 1735 May 19, 2015 06:02 PM
Yippee! RWDRC Hawker Sea Fury Build Thread iflyprops Scale Kit/Scratch Built 414 Sep 09, 2008 11:09 AM
DC-9 Airliner for EDF-50BH - Official Build Thread Hawker Electric Ducted Fan Jet Talk 77 May 29, 2007 09:54 PM
Aerodrome RC Fokker D.VII - Pictorial build thread Admiral Piett14 Scale Kit/Scratch Built 11 Oct 17, 2005 12:59 PM
Hawker Hunter official list starting U812 Electric Ducted Fan Jet Talk 47 Aug 01, 2003 07:07 PM
