Old Aug 11, 2009, 11:37 PM
giddyuperic is offline
Find More Posts by giddyuperic
giddyuperic's Avatar
USA, CA, Riverside
I use Hitec 82 MG if you can't get them. Parkzone servo for the rudder and streering in a metal geared servo and works great. The hitec in 21 bucks and the parkzone is about 12 dollars. Make sure it is the one for the rudder/streering.
giddyuperic is offline Find More Posts by giddyuperic
Old Aug 12, 2009, 12:58 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by skyline_g35
Did you guys take a look at my vid?
Tell me what you think of the landing...
Great maiden video. Landing was very smooooooth.
Prof100 is offline Find More Posts by Prof100
Old Aug 12, 2009, 09:55 AM
X30PILOT is online now
Find More Posts by X30PILOT
X30PILOT's Avatar
Joined Aug 2007
Just some quick observations before I start building this thing. The kit looks great, and that CNC metal fan is very impressive.
I purchased my kit from Max at http://parkrcmodels.com . Considering the current issues with some of the online venders, I have to say that dealing with Max was an extremely positive experience!
The main gear retracts in the wing work nice and smooth, however the nose gear retract is binding. If I cannot resolve the binding issue I am concerned that a stalled servo could brown out my AR 7000. I fly mostly off of grass fields so forgoing the gear altogether would skip 4 servos. This would not only reduce weight, but the amp draw of those servos on the bec. The video that Extreme RC posted flying off of the grass was very impressive.
Any thoughts?
X-30
X30PILOT is online now Find More Posts by X30PILOT
Old Aug 12, 2009, 11:20 AM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
If you are going full house on this plane (8+ servos), I HIGHLY recommend using a separate NiMH or A123 pack for the RX power. I don't trust an internal BEC with any more than 3 servos, or an external BEC at all (I've had CC BECs melt on me).
If you want to keep the LG in, then work with the nose gear until you resolve the binding issue. BTW, what part of it is binding? I've had to rework the pre-bent wires some on my Panther and F-16 to get things to work just right.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Aug 12, 2009, 12:11 PM
X30PILOT's Avatar
Joined Aug 2007
Pat,
Thatís probably some good advice on the BEC, although I am running my Trex 500 with 4 medium sized digital servos and a gyro on the Align 60 amp ESC with a built in BEC.
If I go the full house route Iíll be running 10 servos. 3 retract 1 nose wheel steering
2 aileron, 2 flap 1 elevator and 1 rudder. The linkage on the nose wheel looks fine but I may have to disassemble the unit and lube the moving parts.
Dave
Old Aug 12, 2009, 01:16 PM
Jimmy_H is offline
Find More Posts by Jimmy_H
Jimbo and the Jet Set
Jimmy_H's Avatar
York
Joined Jul 2005
I replaced the bent wire with straight, used a 12g mg 2kg towerpro servo and added a balsa block to stop the stall when the two forces meet.
the attached should help
Jimmy_H is offline Find More Posts by Jimmy_H
Old Aug 12, 2009, 10:46 PM
X30PILOT's Avatar
Joined Aug 2007
Jimmy_H
Thank you for posting that picture of your nose wheel installation.
Have you test flown your Hunter?
Dave
Old Aug 13, 2009, 12:34 AM
Patrik J is offline
Find More Posts by Patrik J
Sweden
Joined Oct 2008
Is it possible to fit air retracts on this bird?
Considering a mini metal air set and get rid of a couple of servos.
I have not yet received my Hawk, so I don't know if there's any space to put the air tank.
Patrik
Patrik J is offline Find More Posts by Patrik J
Old Aug 13, 2009, 01:29 AM
Parkflying is offline
Find More Posts by Parkflying
United States, MI, Auburn Hills
Joined Dec 2008
Any thoughts?
X-30
Thanks for the kind words.
Is the servo over throwing or is the mechanism just rough and not working smooth? If it is a bad mechanism, get to me in email and we will work on a replacement for you. Also have you looked at the Suspension Struts for the Hunter? Really sweet!
Also I use these Du-Bro servo savers for situations like this where the servo might over throw or on the steering servo.
Take a look here: Du-Bro Servo Saver
Hope that helps
Max
Parkflying is offline Find More Posts by Parkflying
Site Sponsor
Old Aug 13, 2009, 08:20 PM
muckie is offline
Find More Posts by muckie
Situationally Unaware
muckie's Avatar
Rhode Island, USA
Joined Dec 2007
This mat be one of the dumbest questions ever asked but:
How is easy is it for everyone to release the cockpit/battery hatch?
I haven't assembled the fuse yet but at the moment the only way I can get the hatch off is to push it from below. I can't see how I'll get it off when the lower front fuse is attached. Maybe I should swap the plastic latches for a couple of magnets...
Cheers!
muckie is offline Find More Posts by muckie
Old Aug 13, 2009, 08:23 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The catch is good, once you have stuck the canopy down with decent quality double sided tape you will be able to pull the hatch up at the front edge by holding the canopy, same for all the Lander models. I have not had an issue yet with any of mine, broke the Panther one eventually but the canopy had been removed MANY times
Extreme_RC is offline Find More Posts by Extreme_RC
Old Aug 13, 2009, 08:29 PM
muckie is offline
muckie's Avatar
Rhode Island, USA
Joined Dec 2007
Thanks, Extreme.
That's good to know.
Nice video earlier!
Cheers
Old Aug 14, 2009, 02:09 AM
USA, CA, Riverside
What I did was took two pieces of plastic you know like something would come in from the store like a servo package and cut a L shape out of it and glued it to the front of the hatch to make a handle to pull up on the hatch. They work so good I have them on all of my RC Lander air planes and the clear plastic you can not see so it works great. If you need photos just ask. Okay Eric
Old Aug 14, 2009, 07:19 AM
muckie is offline
muckie's Avatar
Rhode Island, USA
Joined Dec 2007
Eric - that's a great idea - thanks!
Old Aug 14, 2009, 09:14 AM
X30PILOT's Avatar
Joined Aug 2007
Extreme_RC
How is your Hunter holding up after repeated belly landings on the grass?
Did you put anything on the bottom to protect it?
Dave
Cool New Mini FuntanaX from e-flite (official build thread/ flying thread!!) p51flyer 3D Flying 1735 May 19, 2015 06:02 PM
Yippee! RWDRC Hawker Sea Fury Build Thread iflyprops Scale Kit/Scratch Built 414 Sep 09, 2008 11:09 AM
DC-9 Airliner for EDF-50BH - Official Build Thread Hawker Electric Ducted Fan Jet Talk 77 May 29, 2007 09:54 PM
Aerodrome RC Fokker D.VII - Pictorial build thread Admiral Piett14 Scale Kit/Scratch Built 11 Oct 17, 2005 12:59 PM
Hawker Hunter official list starting U812 Electric Ducted Fan Jet Talk 47 Aug 01, 2003 07:07 PM
