| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 |
I think its just a rounded number , the 600īs has the same limit and then the 425īs
can run 2600 . Manufacturer with complaints experience in my opinion . |
#62 |
TeamTP,Minicopter,Spartan
Location: Mississippi 31 years , Now Kotzebue , Alaska 12
chichissport. Yeh! I know all about the eco8 size. I designed a 480 size a few years back but never pulled it through,
it was based around the 6S 3850. if anyone remembers the eco8 when lipos came out, a 3S4p 8000 was about the same weight as a 6S 3850. I been working on the 90 size now. T |
#63 |
Too slow for 3D
Well, I started on my Sniper II build today. Everything was going smoothly until I got to the head. My spindle has one of the bolt holes drilled in at a slight angle which puts the thrust bearing in a bind when installed into the grip. I guess my build is also on hold for the moment
How are the rest of the builds going? Keith |
#64 |
Keith,
I can get you a replacement. |
#65 |
Sniper II, Maxir, Beam E4
Build update - started slowly late Friday - softball tournament slowed progress waaay down over the weekend. I had the same problem as Pete with the anodizing in one of the grips - the sandpaper/dowel did the trick.
An observation - for my experience level with heli kit building (fairly low - 2 Maxirs) it would have been a big help for a mention in the instructions of the grub screw adjusments available for the tail drive pinion and conical to free up the spinning of that shaft during frame assembly. Fiddled and scratched my thick head for a long time getting those bearings smooth. Those little circle cut outs in the frame are there for a reason I guess. A more experienced builder may well have already known this.Matt |
#66 |
Heli Hooligan
Mine just arrived
#67 | |
If you fly this size of heli at less than 1600gr you will be amazed . |
#68 |
Cool, glad my little trick helped with the grips!
How many people would be interested in the BBT 480mm blades if I could get a bunch? (I'm communicating with them now) |
#69 |
Well , if I need them I will buy from you , but I donīt want to need them
#70 |
The balls for the swash that I have are all 4mm, yet the compensator link N0319 inside diameter is a hair over 3.5MM.
Am I missing something, or do I have to ream the N0319's out? |
#71 | |
Crazy Heli Technogeek
-Kai P.S. I couldn't help you with this over the phone, because I don't have the part numbers memorized, and you didn't mention them... (that part number is the same as the V1 Sniper). |
#72 |
OK - when I did the ball from the inside and the bolt from the outside of the link, screwed it in and pressed it on, it worked out perfectly. Backed it off added some Loctite and it's good to go.
#73 |
Heli Hooligan
The Gaui550 475mm wooden blades are like $16 and would probably be ok for beginners hovering around at low rpm.
#74 |
Good catch! (Not what I'm looking for but could help others
#75 |
Heli Hooligan
I broke the c-clip on my Scorpion motor when I replaced the bearings with ceramics. Where can I get a c-clip? Do I need it or is it safe to run without it?
| Thread Tools | |
| Discussion LAheli Sniper Discussion Thread (470mm blades) | Kai_Shiden | Electric Heli Talk | 753 | Aug 15, 2009 03:28 PM |
| Product Survey discussion thread. | Chris Nicastro | Motorcycles | 15 | Apr 27, 2004 05:27 PM |
| RC Power discussion thread | jbourke | Fuel Plane Talk | 8 | Jan 08, 2004 05:58 AM |
| Midi F-4 Phantom II construction | jet_jer | Electric Ducted Fan Jet Talk | 34 | May 05, 2003 04:58 PM |
| Aventura II construction questions | Scott Elmore | Electric Plane Talk | 14 | Mar 09, 2002 10:22 AM |
