Go Back   RC Groups > Aircraft - Electric - Helis > Electric Heli Talk
Old Jun 19, 2009, 06:08 PM   #1
Site Sponsor
Send a message via Yahoo to pwkpete
Sniper II construction and discussion thread
So, the first batch of Sniper II's arrived today.
Before I get to processing the incoming inventory, I just had to crack open my kit
Packaging is extremely well done. Canopy is yellow FG, that will eventually get some paint!
Here is the initial batch. Lee and I are trying to keep the kits available at a very competitive price compared to the competition, which really there doesn't seem to be much in this class, but in the 425 sized machines...
Ok, now back to work... Not building...
-P
  • Name: IMG_0209.JPG
pwkpete is offline Find More Posts by pwkpete   Reply With Quote
Old Jun 19, 2009, 07:25 PM   #2
Psurvival = 1/ThArrival
Silver Member
osterizer's Avatar
Well, aren't you off work yet? Get on with it, man!
osterizer is offline Find More Posts by osterizer   Reply With Quote
Old Jun 19, 2009, 07:34 PM   #3
Site Sponsor
Right now work = processing inventory, getting Gothelirc his order and handling a small flood in the basement due to big rain storm and loss of power... (Not quite in that order )
Old Jun 19, 2009, 08:36 PM   #4
Site Sponsor
Ok a few more teaser shots.
Did I mention that the packaging is first rate?!
Includes FG blades, spongy blade holder and velcro battery straps!
  • Name: IMG_0210.JPG
  • Name: IMG_0212.JPG
  • Name: IMG_0213.JPG
Old Jun 19, 2009, 08:55 PM   #5
Silver Member
osterizer's Avatar
There you go. Who cares if the basement furniture washes away? Couple of us are pretty curious about this one. Thanks for starting the thread.
Old Jun 20, 2009, 10:21 AM   #6
Site Sponsor
Excellent!
Don't think I'll get to too much over the weekend... I may be coming down with something though, I don't think it will really hit me until Monday morning
Manual for the flybarless head - this should work on other 425mm bladed machines....
Old Jun 21, 2009, 09:34 PM   #7
Site Sponsor
I did get a little chance to get farther....
Build is smooth as silk....
  • Name: IMG_0213.jpg
Description: Parts from Body component bag Parts from Body component bag 92.2 KB · Views: 93
  • Name: IMG_0214.jpg
Description: Gears assembled and shaft blocks with bearings installed Gears assembled and shaft blocks with bearings installed 61.0 KB · Views: 80
  • Name: IMG_0215.jpg
  • Name: IMG_0216.jpg
Description: Blocks installed on one side frame... Blocks installed on one side frame... 83.0 KB · Views: 190
  • Name: IMG_0217.jpg
Old Jun 21, 2009, 09:35 PM   #8
Site Sponsor
FYI: Kit is currently available in blue anodization and soon in black...
Old Jun 21, 2009, 09:41 PM   #9
Too slow for 3D
K.Lund's Avatar
Looking Good! Are you going to take a 1000 pictures like Kai did on the first Sniper build?
Keith
K.Lund is offline Find More Posts by K.Lund   Reply With Quote
Old Jun 21, 2009, 10:14 PM   #10
Site Sponsor
LOL
Probably not. This is a pretty simple build, everything fits great. I'll point out all the unusual stuff, but hopefully you guys can comment on things I missed!
This is starting to look really good!
(One is still available at the shop and more are on the way!)
Old Jun 21, 2009, 11:02 PM   #11
Crazy Heli Technogeek
Kai_Shiden's Avatar
Keith
Hey, I think I only "took" like 998 pictures, don't make up a number (just kidding of course).
Looks great Pete, can't wait to see more of it (hopefully I'll get some pics of my V1's and Matt's V2 when he gets his built).
-Kai
Kai_Shiden is offline Find More Posts by Kai_Shiden   Reply With Quote
Old Jun 22, 2009, 12:30 PM   #12
Site Sponsor
Excellent Kai!
Here are some more of the head with some comments... Take note of the interesting inner swash ball arrangement...
  • Name: IMG_0224.jpg
Description: Flybarless head parts Flybarless head parts 58.5 KB · Views: 83
  • Name: IMG_0225.jpg
  • Name: IMG_0226.jpg
Description: Bearings were a little tight in the grips (from the anodization I think). A little sandpaper on the end of a dowel took care of that... Bearings were a little tight in the grips (from the anodization I think). A little sandpaper on the end of a dowel took care of that... 61.8 KB · Views: 93
  • Name: IMG_0227.jpg
Description: Assembled! Other notes, I had to put the balls into the a/r arms and then screw them into the inner swash, they didn't want to fit over the bolt head. Also the brass sleeve that fits into the bearings in the hub was a little tight, needed a little sa Assembled! Other notes, I had to put the balls into the a/r arms and then screw them into the inner swash, they didn't want to fit over the bolt head. Also the brass sleeve that fits into the bearings in the hub was a little tight, needed a little sa 68.6 KB · Views: 181
Old Jun 22, 2009, 01:15 PM   #13
Site Sponsor
JustPlaneChris's Avatar
Send a message via MSN to JustPlaneChris
Wow, Pete. This looks fantastic, even in blue!
-Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris   Reply With Quote
Old Jun 22, 2009, 02:16 PM   #14
Site Sponsor
RotorCycle's Avatar
That offset inner swash-ball arrangement is the same setup as on the Sniper 1 head. It was the easiest way to keep the links in close to the main shaft so they don't strike the flybar bridge. It's an eligant design.
I did notice that when breaking in the Sniper head, it's tight just like a new MaxiR / Ricco. You'll have that hysteresis until things loosen up unless you take time to work all those links.
RotorCycle is offline Find More Posts by RotorCycle   Reply With Quote
Old Jun 22, 2009, 07:19 PM   #15
Site Sponsor
The ball location change on the swash is a great idea. The washout has been a little stiff so far, didn't surprise me. Like you said, just like the little guys. Keeps things tight.
More pics. Tail went together perfectly.
  • Name: IMG_0233.jpg
Description: Partially completed tail bits, Partially completed tail bits, 60.9 KB · Views: 72
  • Name: IMG_0235.jpg
  • Name: IMG_0236.jpg
  • Name: IMG_0237.jpg
  • Name: IMG_0238.jpg
Description: Completed assembly.
When putting the drive shaft through the boom, lube the O rings with lithium grease or something similar. It will help get them started and they will go in smoothly. Completed assembly. When putting the drive shaft through the boom, lube the O rings with lithium grease or something similar. It will help get them started and they will go in smoothly. 55.3 KB · Views: 106
Discussion LAheli Sniper Discussion Thread (470mm blades) Kai_Shiden Electric Heli Talk 753 Aug 15, 2009 03:28 PM
Product Survey discussion thread. Chris Nicastro Motorcycles 15 Apr 27, 2004 05:27 PM
RC Power discussion thread jbourke Fuel Plane Talk 8 Jan 08, 2004 05:58 AM
Midi F-4 Phantom II construction jet_jer Electric Ducted Fan Jet Talk 34 May 05, 2003 04:58 PM
Aventura II construction questions Scott Elmore Electric Plane Talk 14 Mar 09, 2002 10:22 AM
Bored? Want to fight?
Join the RCGroups clan!
