Old Jun 19, 2009, 04:01 PM
hurleybt is offline
Find More Posts by hurleybt
United States, GA, Woodstock
Joined Mar 2007
DIY Patch Antenna - 900mHz - how to?
So I have done a bunch of reading on patch antennas, and they don't seem like very complex beasts. Right now I'm starring at a wikipedia article, and I'm considering going home and cutting some double sided circuit board and plugging it into my rx.
Referencing this article: http://en.wikipedia.org/wiki/Patch_antenna
Is it this simple: Cut the PCB to the dimensions (1/2 wavelength length and width), then solder the front plate to the feed wire and the ground wire to the back side?
In the article it mentioned that the ground plate may need to be slightly larger than the radiator plate (front side). If that is the case I can cut the whole PCB 1/2 inch or an inch too big (length and width), then etch off the copper on the radiator side so that the radiator plate has the 1/2 wavelength dimensions.
If I need to do anything else, please advise...
hurleybt is offline Find More Posts by hurleybt
Old Jun 19, 2009, 04:11 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
This link will show you how to build the GP Patch and if you read far enough, how to scale it for 900mhz.
http://www.rc-cam.com/gp_patch.htm
galaxiex is offline Find More Posts by galaxiex
Old Jun 19, 2009, 04:12 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Look up the build instructions for the Goof Proof Patch.
It lists the frequency it's optimized for. Scale every dimension
for the new frequency. (if half the frequency then double the size and so forth).
ian
[edit]he beat me to it.
Daemon is offline Find More Posts by Daemon
Old Jun 19, 2009, 05:21 PM
hurleybt is offline
Joined Mar 2007
thanks guys!
Discussion Goof Proof Patch Antenna for 900mhz EyeFlyPlanes FPV Talk 21 Apr 19, 2009 01:31 PM
For Sale 900MHz 500mW a/v transmitter and Reciever w patch antenna rajesh5024 Aircraft - General - Radio Equipment (FS/W) 1 Mar 04, 2009 08:47 PM
Question RV 900Mhz channel selection & patch antenna jimbril FPV Talk 2 Jan 09, 2009 07:12 AM
Discussion 900mhz patch antenna JustinONE FPV Talk 2 Aug 25, 2008 10:41 AM
Rx Antenna and how to run daveWCO Beginner Training Area (Aircraft-Electric) 5 Nov 16, 2002 01:59 PM
