Old Oct 07, 2012, 09:52 PM
mhills51 is offline
Find More Posts by mhills51
mhills51's Avatar
kansas city
Joined Feb 2007
Almost had a disaster today. I changed my swash, but forgot to put the ball link back on the ball for the elevator. Took off like I had one hell of a binding problem in the swash. Was able to get it down safe. Once the ball was back on all was good.
mhills51 is offline Find More Posts by mhills51
Old Oct 08, 2012, 01:54 AM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
You lucky, lucky bastard!
Gongrats for getting it back down safe!
Those things are a nice wake up call for preflight checking, aren't they?
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Oct 08, 2012, 02:14 AM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Brgds, Bert
Talking about a wake up call, yesterday I changed the Asymmetrical Spinblades I use on a star-ranger body for two Sabb symmetrical blades to see if they do it better in gusty winds.
I have two sets of them and numbered them for use in a four-blade setup.
When spooling up a huge blade vibration/wobble starts to occur and the body was starts to move up and down and side ways I killed the trottlehold and she stopped shaking as a wet dog.
The problem was that I used two different blades out the two sets and they are really not balanced with each other.
After fitting the correct blades it was a dream and much more steady in wind gusts.
And I was awake for sure
Jan,
Horseman is offline Find More Posts by Horseman
Old Oct 08, 2012, 03:25 AM
The Netherlands
Joined Nov 2009
Jan,
That is exactly why I don't mess around with blades and heads....Too much chance for something like this, and the risk of being too late with killing the throttle is a bit too much risk for me
I never mix-use part of a four-blade set to a 2 blade set, and never buy two 2-blade sets to make one 4 blade set....
(fortunately I don't have to: the vario blades don't mix anyway and are always balanced as a set, and the Spinblades on the 450's are just the best there are anyway, so no need for cross-testing)
Glad to hear you didn't get any additional damage!
Brgds, Bert
Old Oct 08, 2012, 10:10 AM
coptercptn is offline
Find More Posts by coptercptn
coptercptn's Avatar
United States, AZ, Mesa
Joined Dec 2008
Originally Posted by mhills51 View Post
Just looked over at RR. I'm sorry about the police 500 ouch! I have a CH-53 shell maybe I will bring to our FF. I just have never been happy with the raised tail.
I'll see you in KC
coptercptn is offline Find More Posts by coptercptn
Old Oct 08, 2012, 12:22 PM
rotoraddict is offline
Find More Posts by rotoraddict
Joined Jul 2008
Here is the latest video of my friends big, very detailed, turbine Llama with yours truly happily doing the flying.
Lama Turbine Heli - Almost Done! (4 min 57 sec)
rotoraddict is offline Find More Posts by rotoraddict
Old Oct 08, 2012, 12:54 PM
Bad Creation is offline
Find More Posts by Bad Creation
Bad Creation's Avatar
United States, FL, Orlando
Joined Dec 2009
Awesome Nice flight too
Bad Creation is offline Find More Posts by Bad Creation
Old Oct 08, 2012, 02:28 PM
ghostpipe is offline
Find More Posts by ghostpipe
Heli-Teck
Switzerland
Joined Nov 2009
Hi guys,
the last week-end I tried the new blades produced by kin, the Scale carbon rotor blades 600 /700 (650 mm).
I tried them on a Hughes MD500 scale 700 with PHT2 turbine with 5 blades, and an electric EC-120 Hirobo scale 60/90 with 3 blades.
I am very pleased with the results and the accuracy of the flight, I get the same result, using only the blades Hirobo scale, but the cost is much higher!
This is the video of the first test flight with the blades
Huges MD 500 PHT2 (3 min 16 sec)
ghostpipe is offline Find More Posts by ghostpipe
Old Oct 09, 2012, 07:07 PM
Keyrigger is offline
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Nice flight, rotoraddict. I wouldn't mind the chance to fly one of those some time. Take care.
Don
Keyrigger is offline Find More Posts by Keyrigger
Old Oct 09, 2012, 07:44 PM
Keyrigger's Avatar
Joined Sep 2009
mhills51:
I was test flying a brand new 700 that had been partially assembled by the owner when during a landing approach, the heli became unresponsive about 30 feet up. It seemed to have no power to climb but would hold altitude, which was very puzzling, to say the least. I added full up pitch and forward collective and it started to move forward from the end of the field. It made it a bit more exciting that I was above our asphalt runway while this was going on as the grass was a lot softer with the rain we had been getting. I coaxed it along until it was in the grass area and I could set it down. As it finished spooling down, I checked the cyclic and to my amazment, the elevator arm didn't move up or down. I got really weak at the knees when I grabbed the arm and moved it without the servo making a noise and all this time, the power was still to the servos, so it should have been solid. I looked and found the servo wheel had moved off of the spline but the screw was still there!!!. There was no lock washer under the screw head and it had backed off in the three test flights I put into it. I took it home, loctited the screws and all is good. When I told the owner, I made him promise not to build any more large heli's until he can assemble and fly a 450 or smaller heli from a kit. Did I mention, his soldering skills and wire joining capability are attrocious? Checking my shorts......
Don
Old Oct 09, 2012, 07:58 PM
mhills51 is offline
mhills51's Avatar
kansas city
Joined Feb 2007
So glad you got it down! Well that is two close calls, don't these things go in threes?
We had I guy come to the field with his outrage 50 after a crash. He thought everything was ready to go, but while it sat on the bench we noticed the elevator was not level. after checking it out it seems he replaced the servo, but all the teeth were gone off the servo horn.
Old Oct 09, 2012, 08:18 PM
Keyrigger's Avatar
Joined Sep 2009
Now, that's a whoops.....
Don
Old Oct 10, 2012, 02:11 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Thats a tricky one
Jan,
Old Oct 10, 2012, 12:33 PM
Joined Jul 2008
Thanks for the Kudos on the flying of the big Llama guys.
Old Oct 10, 2012, 12:37 PM
Joined Jul 2008
Originally Posted by Keyrigger View Post
mhills51:
..... I looked and found the servo wheel had moved off of the spline but the screw was still there!!!. There was no lock washer under the screw head and it had backed off in the three test flights I put into it. I took it home, loctited the screws and all is good. When I told the owner, I made him promise not to build any more large heli's until he can assemble and fly a 450 or smaller heli from a kit. Did I mention, his soldering skills and wire joining capability are attrocious? Checking my shorts......
Don
Good save there Keyrigger. I hope that fellow knows how lucky he is. As for soldering skills, that is one that many lack simply because it takes awhile to attain them.
I agree, that is why learning many of these skills should be done while building smaller helis, but I think they could also learn them by building helis as big as those that 550 blades.
Discussion Post a picture of your SCALE sailplane s2000 Scale Sailplanes 583 Apr 10, 2016 01:00 AM
Cool post any videos of your 1/2A. rctoyflyer 1/2A Planes 9 Jan 31, 2008 08:25 PM
Discussion For those of you that want to get good videos of your scale planes. randall1959 Scale Kit/Scratch Built 4 Apr 21, 2007 09:02 PM
Will Someone Please Post Pictures of the Inner Workings of a Brushed Motor? CAFB 04-12 Power Systems 25 Jun 21, 2005 09:01 PM
Please post pictures of your GWS warbird Razor setup... flipnidaho Parkflyers 1 Jul 12, 2003 04:54 PM
