Old Sep 27, 2009, 05:28 PM
viggen65 is offline
Find More Posts by viggen65
Sweden, Gothenburg
Joined Aug 2005
Hello
Heres a few pics from our latest clubscalemeeting here in Gothenburgh, as seen in the pics theres a great varity of helis in our club, mine two are the
Eurocopter Panther and arrospatiale White Lama, both electroconverted and from Hirobo, unfortunaly there wasnt much flying due windy conditions that
day.
Cheers
Jack
viggen65 is offline Find More Posts by viggen65
Old Sep 29, 2009, 05:12 PM
Rodan is offline
Find More Posts by Rodan
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
My Sea Ranger at the Albuquerque Fun Fly last weekend:
Sea Ranger AlbQ 09 unedited (5 min 34 sec)
Rodan is offline Find More Posts by Rodan
Old Sep 29, 2009, 05:37 PM
Paul-RC is offline
Find More Posts by Paul-RC
Let me Fly please :^)
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Wow! once its off the ground you cant tell if its a model or the real thing.
Paul-RC is offline Find More Posts by Paul-RC
Old Sep 29, 2009, 09:26 PM
hrbeta is offline
Find More Posts by hrbeta
Happy bluesman
hrbeta's Avatar
Boca Raton, FL
Joined Jul 2006
Hey Rodan, beautiful heli and excellent scale flying Can we please have the info on the SeaRanger?
Cheers.
hrbeta is offline Find More Posts by hrbeta
Old Sep 29, 2009, 11:08 PM
Rodan is offline
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
Thanks guys!
It's a Century/Funkey 60 size Jet Ranger on modified TRex 600E mechs.
Build thread here: http://www.scalerchelis.com/phpBB2/v...hp?f=17&t=8727
Old Sep 30, 2009, 07:19 AM
Spidious is offline
Find More Posts by Spidious
Bush Pilots Bounce Higher
Spidious's Avatar
USA, IL, Champaign
Joined Dec 2006
Looks great...Ever thought of putting a diffuser over the back windows so you don't see the gears and frame work ? I used a plastic screen like you would use in a door. And it makes a big difference...
Spidious is offline Find More Posts by Spidious
Old Sep 30, 2009, 11:08 AM
Rodan is offline
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
I have, but that's where all the airflow goes, and I like the fact that it runs nice and cool. Also I don't think the screen works as well for windows as it does on the bottom, where you can paint it.
Old Sep 30, 2009, 11:19 AM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Rodan, very nice flying ! And great looking heli.
Here is a video I made of my mini titan with A109 K2 fuselage with in onboard flycam.
Carguy
Mini Titan A109 K2 (3 min 53 sec)
carguy1994ca is offline Find More Posts by carguy1994ca
Old Sep 30, 2009, 06:19 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
That 109 looks real good like that.
What club was that video taken at, it looks great.
Paul
Old Oct 01, 2009, 02:35 PM
Quebec, Canada
Joined Sep 2006
Hi Paul !
It is the Club d'aéromodélisme les Phoenix in Saint-Georges Beauce.
Here is the web site: www.clubphoenixbeauce.com
You can see many videos taht I made there on Youtube. Just type ''club phoenix beauce'' or look under my user name carguy1994ca.
Carguy
Old Oct 01, 2009, 02:39 PM
C Andrew Green is offline
Find More Posts by C Andrew Green
แอนครู กรีน (เขียว)
C Andrew Green's Avatar
Oxford, UK
Joined Mar 2002
Align 450 size EC135, Rush flapping head with Rush narrow chord blades. Flew fine in pod and boom as a 4 blader doing ~2150 RRPM on a 3850Kv motor with a 10T pinion, real stable even looped it a couple of times. Seems to have come over all suicidal now it's back in the EC135 fuz???? C/G may be to far aft now, was quite nose heavy in pod & boom.
Andrew
C Andrew Green is offline Find More Posts by C Andrew Green
Old Oct 01, 2009, 02:52 PM
Paul-RC is offline
Paul-RC's Avatar
Montreal,Canada
Joined Mar 2003
Originally Posted by carguy1994ca
Hi Paul !
Carguy
Thanks Carguy, I have to go visite you guys next summer, I will check for the funfly
Old Oct 01, 2009, 04:47 PM
gimbal is offline
Find More Posts by gimbal
walkera (ab)user
Joined Jul 2007
Andrew
you may have to revisit the pitch curve; did you try adding an equivalent weight of the fuselage to the heli to simulate extra load (less weight of l.g./fins as necessary) and retrimming before outfitting?
putting the fuselage on has not just moved the cog (that's a lump of fibreglass on that tail); the expo may need adjusting due to decreased efficiency of blade area close to fuselage affecting total available thrust. the impulse from the outer 2/3 of the rotor disc is now significantly higher than it was is p'n'b configuration.
a lot of turbulance around the body won't help the gyro, on top of reduced tail rotor thrust from that tail, running a lower h/s means less tail authority. upping the gyro gain may help. gearing the tail speed is better.try hanging the whole heli by it's rotorhead on a string to set the cog (with battery installed) first.....then if it flies level but turns/spins then you're already beginning to sort it.
gimbal is offline Find More Posts by gimbal
Old Oct 02, 2009, 08:38 AM
Quebec, Canada
Joined Sep 2006
C Andrew Green
How is your heli flying with the scale head vs the 2 blade with flybar ? Is it much harder to fly ?
Maybe I would like to try a scale head on my A109 mini titan but since it flies real nice with stock head, I wonder how the scale head may affects performnace and stability ?
Carguy
Old Oct 02, 2009, 09:54 AM
wangzx is offline
Find More Posts by wangzx
Singapore
Joined Sep 2009
Here my semi scale heli
wangzx is offline Find More Posts by wangzx
Discussion Post a picture of your SCALE sailplane s2000 Scale Sailplanes 609 Aug 27, 2016 01:41 PM
Cool post any videos of your 1/2A. rctoyflyer 1/2A Planes 9 Jan 31, 2008 08:25 PM
Discussion For those of you that want to get good videos of your scale planes. randall1959 Scale Kit/Scratch Built 4 Apr 21, 2007 09:02 PM
Will Someone Please Post Pictures of the Inner Workings of a Brushed Motor? CAFB 04-12 Power Systems 25 Jun 21, 2005 09:01 PM
Please post pictures of your GWS warbird Razor setup... flipnidaho Parkflyers 1 Jul 12, 2003 04:54 PM
