Old Jun 18, 2009, 11:45 AM
tevz is offline
Find More Posts by tevz
Joined Jun 2009
twin pack charge lead (2 x 3S)6S + Turnigy Accucel-6 50W 5A Balancer/Charger
Heya, im new to this hobby, just got my honey bee king 3 and i'm really satisfied with it. The only problem is the charger, it charges about 3+ hours so i orderd Turnigy Accucel-6 50W 5A Balancer/Charger + twin pack charge lead (2 x 3S)6S. I just need to know how can i plug it in ? When i get the package should i just plug and charge? Or, i need any other cables etc... As i saw on the twin pack charge it has 2 connectors. I know that the white one should go into the charger but what about the other one ? I read that i should go into the charger aswell but i cant see any connector on the picture that could fit into it ...
Charger
Twin pack charge lead
Thanks for Your help
Best regards,
Tevz
tevz is offline Find More Posts by tevz
Old Jun 18, 2009, 04:02 PM
EricJ320 is offline
Find More Posts by EricJ320
EricJ320's Avatar
Knoxville, TN
Joined Dec 2005
The charger should come with a charge cable with a deans connector for the batteries on one side, and banana plugs on the other end for the charger. When charging a single 3S pack you will plug the balance connector into the charger port, and the charge lead into the main leads on the battery. The charger will charge through the main leads, and balance through the balance plug.
When using the twin lead, you will plug the balance connectors from both packs into the twin lead adapter, and the twin lead adapter will plug into the 6S slot on the charger. You will plug the charge lead from the charger into the charge lead on the twin adapter. The charger will now charge and balance both the packs through the balance plugs on each battery. The main leads on the batteries will not be used at all when using the twin adapter. Select 6S on the charger program, and charge rate of 1C for the packs being charged. In other words, for 2 3S 2000mah packs, select 6S and 2.0 amps.
Remember, make sure the packs have identical cell count and capacity when using the twin lead adapter. Also, make sure the starting voltages are nearly the same or else it will take forever to charge both packs, and could potentially stop before one of the packs is completely full.
Another option, that is safer and easier, is get a parallel lead and charge multiple packs at once in parallel. The packs just have to be the same cell count and have a remotely close starting voltage. They can be any capacity, and don't have to be the same, just add up the capacity for the charge rate. For example, 2 3S packs, one is 1300mah, the other is 3S 2200mah. Select 3S and 3.5 amps on the charger program. This is a basic way to do it, and won't balance the cells in the pack. But so long as you balance charge them every so often they will do just fine like that. It is possible to balance charge in parallel, just do a search for how to do it, there are plenty of threads showing how to set it up.
Hope that helps,
Eric
EricJ320 is offline Find More Posts by EricJ320
Old Jun 18, 2009, 05:34 PM
tevz is offline
Joined Jun 2009
Thanks for the reply, it's much clearer now
Old Jun 19, 2009, 10:48 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
What are you going to be useing as your power supply for the charger?
livonia bob is offline Find More Posts by livonia bob
Old Jun 20, 2009, 03:33 AM
tevz is offline
Joined Jun 2009
I will be using 12V 5A Power Supply
Old Jun 20, 2009, 09:35 AM
Heli collector
Joined Apr 2009
OK I was just checking to make sure you knew that you needed one,,,good choice...
Discussion Twin pack charge lead? boopidoo Batteries and Chargers 3 Dec 02, 2008 02:22 PM
Discussion 2 x 3s pack ballancing ? HELP PLEASE SOMEONE Paul DF jet man Electric Ducted Fan Jet Talk 3 Jul 13, 2008 05:02 PM
Discussion Charging 6s lipo as 6s instead of 2 X 3s dubhouse Batteries and Chargers 6 Jul 13, 2008 05:01 PM
Help! 2 x 3s packs want to charge them in series HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Paul DF jet man Batteries and Chargers 6 Jul 10, 2008 01:47 PM
Discussion Best charger to balance charge 2 x 3S simultaneously MikeHRC Batteries and Chargers 29 Jan 02, 2008 07:50 AM
