Google is your friend:
http://radiocontrol.wikia.com/wiki/E..._speed_control If you want very detailed info RCG is your friend: http://www.rcgroups.com/forums/showthread.php?t=200567 In any case search is your friend. |
Thanks Herk! Frank Promoting the Hobby - One Pilot at a Time www.WAA-08.org |
First of all , esc's refer to two different things, so that might be confuisng (similar to "BEC" which may refer to switching or non-switching bec):
Brushed motor esc: Simple brushed motors will spin by themselves when you place voltage accross the two leads. Battery + motor = spin. A simple switch can turn them on or off. An electronic speed control simply gives you the function of a throttle. Some controller are more efficient than others at partial throttle (surprise- Steve Nue back in the early 2000's showed that many brushed motors/escs are actually more efficient at partial throttle than brushless). Brushless motor esc: A brushless motor has three wires sticking out of it, and they will NOT spin if you simply hook a battery up to two of the wires. The motor will simply get hotter and hotter. In a brushless motor, a microprocessor inside the "electronic speed control" is actually sending positive and negative current to the various wires in a specific, timed progression that makes your motor spin. As an aside, the brushless ESC's can also give you a throttle function. The ealry, 1990's vintage controllers needed extra wires hooked up to small sensors inside the motor in order to work. By 2000, most controllers developed the ability to sense the magnet position by back emf, and only need the three power wires (these are called sensored and sensorless esc's, respectively, today everything is sensorless). |
This might provide some insight:
http://ww1.microchip.com/downloads/e...tes/00885a.pdf http://ww1.microchip.com/downloads/e...tes/00857a.pdf http://www.microchip.com/stellent/id...GE&nodeId=1523 The controller chip and its software makes electronic commutation possible. There is a lot of detail here, but it is interesting to see how many dynamic problems must be solved to achieve practical control of a BLDC motor. |
| Thread Tools | |
| Discussion help me convert my Superstar EP to brushless. what motor, batteries ESC do I need? | pbjones81 | Electric Plane Talk | 1 | Dec 01, 2006 06:21 PM |
| Discussion What is an ESC brake? | mooseomighty | Electric Plane Talk | 6 | Nov 27, 2006 11:17 PM |
| Discussion what is an ESC anyway ? | X3n0 | Micro Helis | 7 | Aug 11, 2006 04:52 PM |
| Discussion what reciever and ESC do you use? | darklyte24 | Foamy EDFs | 3 | May 16, 2006 08:12 PM |
| What tail motor esc do you use? | brianb10 | Micro Helis | 0 | Sep 19, 2005 10:06 PM |
