That is a nice, and original, project
Latest blog entry: BAe Hawk 90mm EDF
Denmark
Joined Nov 2004
More progress.
The wing has now been glassed using the vacuum bagging technique. From the leading edge to the main spar I used 200 gr. UD carbon and from the main spar to the trailing edge I used 80 gr. glass. The trailing edge is reinforced with a carbon roving. Just to make it tougher. The wing weighs 170 gr. against 150 gr. expected. I could have used a lighter UD-carbon, but I just took what I had on the shelf. And the 20 gr. ekstra is not fatal. It's not a DLG. The wing is extremely stiff and much stronger than you could build with traditional balsa/spruce at the same weight. Now the wing needs two servos. I will use 2 pc. of Dymond D60. And some holes for the wing mounting bolts and the mounting bolts for the engine nacelles. Furthermore the ailerons must be cut loose. As hinge i bagged in som nylon (peelply ?). And finally paint all over with RLM 76 as base colour for the whole plane. I will use an acryllic paint, havent decided yet about using paint brush. After that the camo.. The mold for the engine nacelles is half done now, in fact more than half done. I wonder if I can pull the finished mold and the plug apart ? Thats exciting.
Denmark
Joined Nov 2004
The molds for the engine nacelle is now ready to use. I am happy with the result. It is my first epoxy mold
The first layup consisted of 1x49 gr. FG, 1x160 gr. Kevlar and 1x80 gr. FG. Although the results is very nice it is much to heavy. 27 grams (almost 1 oz). I want it lighter, preferably 10 grams but realistically around 15-20 grams. In the latter case i will save 15-20 gr. total for two nacelles compared to the Kevlar layup. Of course it is not necessary to be so focused on the weight here, but it is very easy just to mold a new nacelle and I want to try some different layups. It is cheaper to make test on a small nacelle than on a large fuselage, where the weight matters more. The next nacelle will probably consist of 1x49 gr. FG, 1x0,8mm balsa and 1x49 gr. FG. Or maybe 1x25 gr FG, 1x200 gr. FG ? Thin Kevlar could also be the way, but I don't have anything on stock. FG can be layed up much more dry than the thick Kevlar, which is difficult to wet properly out. The fabrics of the Kevlar necelle only weighed 6 grams, the filling of the corners (epoxy+tix+microballoons) weighed around 6 grams, so 15 grams is pure epoxy !! But on the other hand the Kevlar nacelle is almost bulletproof !
| Thread Tools | |
| Build Log Avro Arrow Twin 50 Mm Edf Foam To Composite Conversion | larry baraniuk | Electric Ducted Fan Jet Talk | 9 | Feb 10, 2011 12:04 AM |
| GWS EDF 50 mm for sale | bruff | Aircraft - Electric - Airplanes (FS/W) | 2 | Dec 18, 2003 04:41 PM |
| $1.50 micro EDF? | hardlock | Indoor and Micro Models | 9 | Jan 08, 2002 05:07 PM |
| MiG-15 for EDF 50: micro EDF action! | Thomas B | Parkflyers | 2 | Dec 27, 2001 08:27 AM |
| Another Little hornet maiden flight | poobs | Parkflyers | 3 | Sep 09, 2001 02:10 PM |
