Go Back   RC Groups > Aircraft - Electric - Helis > Multi Rotor Helis
Old Jun 16, 2009, 11:35 PM   #1
Quaduino-Part2 (Arduino QuadCopters)
This is a continuation of the Quaduino thread. (This thread is dedicated to quad copters that use an Arduino micro controller.)
Working Quaduinos-
1) AeroQuad by Mikro (*Download contains complete code. Well documented)
Highlights-
1)RX channel order independent.
2)Configurator for easy PID adjustments and other features.
3)Optional shield available.
2)Quaduino-ng by Paulrene (*Available in an "as is" download. Download contains partial code. You still need to find a compatible ServoDecode and SoftwareServo library I think?)
Highlights-
1)Stable, RX channel order dependent using single PPM pulse train from hacked receiver.
2)Uses mainly, quick int calculations.
3)Caspiquad by dcaspi (*Working version)
Highlights-
1)Stabilization is based on roll/pitch estimation using accelerometer and gyro inputs.
Posts in this thread-
Technical Quaduino-
*1) brij-Interrupt based ADC sampling -> Roy-CodeSuggestion -> brij-ADC sampling/ISR triggered -> brij-Fix/ADC Trigger -> Roy- Interrupt/Timing? -> brij-ISR timing
*2) sat-analogWrite resolution -> Mikro-256 incriments -> sat-duty cycle? -> dcaspi-Reduce PWM frequency? -> sat- Bad intermediary PWM -> sat-1KHz hitching? -> sat-hitching122Hz, No hitching 488Hz -> sat-488Hz in 0-2ms -> sat- Timers PWM setting?
*3) NegativeShift vs PositiveShift -> rich-2.4g=No shift.
*4) Roy- Correct Terminology
*5) Roy- Aerobatics Complimentary filter
*6) brij- Constant loop rate - Roy- Busy wait loops, not good - dcaspi- Poll the Arduino millis() function
*7) kal- Accelerometers not usefull -> Roy- Z axis usefull. -> sat- ACC resets gyros to zero -> kal- Force vectors cancel each other. -> otl- Earth Frame of reference. -> jes- Document refering to 0-4g -> otl- Math explaination too simplistic -> Roy- Inflight v.s Stationary readings -> Roy- Forces illustration -> Cor- Accel literature -> jes- Accel Spike info good enough -> Roy- Thrust always in Z axis -> Mikro- Data collected
*8) Roy- What D does in PID -> don- What PID is -> RoyLB- More mass needs more P
*9) bblack- LQR controller and Kalman
Sensor Suggestions-
1) Fred- Invensense 3axis accel
2) sat- Wii Motion Plus - uphiearl-Wii 6DOF -> uphiearl-12c/Arduino code -> JimnAz- Device ID's conflict -> uphiearl- Devices in Parallel -> kaldak- Enabeling takes time -> RCvertt- Earls 9 steps -> RCvertt- Quadrotor Using Wii MotionPlus
3) felik- New 5 DOF IMU -> voice- auto zero pin use
Arduino IDE Compatible Boards-
1) Roy- xduino not pin compatible
2) Pso- Maple prototype
General Quaduino-
1) QuadroController II code
2) brij-CustomPCB -> PCB
3) sat-saturnine quad code -> sat-View channels/Arm motors/Channel order -> sat-Raw channel values
4) ber- NonArduino quad - ber- Motor mounts - ber- Flight video - ber- PWM at 250hz - ber- Quad Code
5) brij- Pushpak Quad, Custom PCB using Arduino IDE
6) Parallax propeller QuadCopter-
7) Multipilot Board:Education board for gyro acc app. (Runs AeroQuad and Mikrokopter code)
8) Quad using ArduIMU
9) Spanish Quaduino inspired quad
10) Low cost DIY XBee/GPS plane locator (Maybe usefull to this project?)
11) My tricopter design (autonomous indoor hover etc.) - Atmega32 (Very stable tricopter using Arduino hardware but not software)
AeroQuad Info-
AeroQuad Tutorials
1) Basic AeroQuad Tutorials (Need to update configurator tutorial) -> RCv- Ignore Red items in configurator
AeroQuad General
1) Mikro-Sensor Orientation
2) Mikro-AnalogWrite vs ServoTimer2 -> dcaspi-Hardware not interrupts -> rich-carrier shifts -> rich- 2.4ghz=No shift
3) Mikro-Aref resistor -> dcaspi-1.2K=3.25v AREF -> bob-2.2k=3.14v AREF -> rich- Resistor degrades accuracy
4) felik- 2000 keeps quad in stable mode
PID Info
1) Mikro-Configurator settings
2) feli- PID Frame weight
3) don- Quad Settings
Video
1) Mikro-Shield/Flight video -> Mikro- Camera stabilization test -> Mikro- X config
2) RCv- First flight - RCv- Spectrum Futaba configurator
3) kar-Spectrum flight - kar- Video and pictures
Experimental Designs
1) RCv- QTD (Quad Tilt Duino) -> RCv- Props under wing more efficient -> RoyLB- Rate limit code
Last updated to thread page- (46)
RCvertt is offline Find More Posts by RCvertt   Reply With Quote
Old Jun 17, 2009, 01:06 AM   #2
Ok, old thread is all closed down. Hope this one goes just as long!
kaldak is offline Find More Posts by kaldak   Reply With Quote
Old Jun 17, 2009, 04:15 AM   #3
Quad Crash Test Pilot
Mikro's Avatar
BTW Kaldak, thanks for starting the first one... it gave us a place where a bunch of us had similar ideas and really start hashing it out!
Mikro is offline Find More Posts by Mikro   Reply With Quote
Old Jun 17, 2009, 06:48 AM   #4
how to alienate your wife ;)
bob.titus's Avatar
Originally Posted by Mikro
To slow down the code, just put a delay() statement inside the main loop. Maybe try delay(10); first?
where exactly do you put the code?
bob.titus is offline Find More Posts by bob.titus   Reply With Quote
Old Jun 17, 2009, 06:57 AM   #5
Tinkerer
don_cocinero's Avatar
Thanks for all the fish!!
Just a quick note to say that I appreciate immensely the dedication, patience and kindness you have all shown in helping us less enlightened aficionados.
The development of this project continues to provide me (and I am sure many others) with loads of fun. If we destroy a few bits in the process...well no one ever made an omelette without breaking a few eggs . To me the journey to a working quad IS the excitement! Chances are I'll turn to something else once I have a reliable working quad. I cannot thank you guys enough for all the learning you have facilitated.
I raise my glass to the new thread.
Don
don_cocinero is offline Find More Posts by don_cocinero   Reply With Quote
Old Jun 17, 2009, 07:42 AM   #6
bob.titus's Avatar
I have tried Aeroquad v1.2 with servotimer2 and as far as I'm concerned :
- no more cracking sounds
- engine bursts are still very present as you can see on the screen captures
Next step is inputing delay as soon as I find how to
SORRY : Aeroquad v1.1
  • Name: Capture-JLF- 145.jpg
Description: Motor bursts as seen from Aeroquad Configurator Motor bursts as seen from Aeroquad Configurator 71.6 KB · Views: 611
  • Name: Capture-JLF- 146.jpg
Description: Motor bursts as seen from Aeroquad Configurator Motor bursts as seen from Aeroquad Configurator 68.6 KB · Views: 206
  • Name: Capture-JLF- 147.jpg
Description: Motor bursts as seen from Aeroquad Configurator Motor bursts as seen from Aeroquad Configurator 68.2 KB · Views: 223
Old Jun 17, 2009, 08:06 AM   #7
Omni
feliksayk's Avatar
AeroQuad 1.2? Miko, you've updated it once more?
feliksayk is offline Find More Posts by feliksayk   Reply With Quote
Old Jun 17, 2009, 08:09 AM   #8
bob.titus's Avatar
woops!!!! I meant Aeroquad v1.1
That's what happens when you take your dreams for reality
Old Jun 17, 2009, 08:10 AM   #9
Omni
feliksayk's Avatar
So Bob, you're saying it's working better now? The new AeroQuad v1.0.1 ?
I just noticed you are still using some of those experimental values, the windup guard and level limit. Maybe they are interfering with the Acrobatic mode code.
Old Jun 17, 2009, 08:16 AM   #10
bob.titus's Avatar
No, I mean : it's working better now with Aeroquad v1.1, I insist!
Can somebody explain how come v1.0.1 got upload AFTER v1.1???
  • Name: Capture-JLF- 153.jpg
Old Jun 17, 2009, 08:19 AM   #11
Omni
feliksayk's Avatar
I would say it's either a typographical error or the old v1.0 got a little tweak in it and so now is v1.0.1.
Old Jun 17, 2009, 08:25 AM   #12
bob.titus's Avatar
Originally Posted by RCvertt
I put the Quad on the road, and armed the motors... they started to spin gently, and within a second, without me touching the throttle, suddenly went full throttle!!!!
Sorry to hear about the slice and dice flight you had At least you have possibly discovered one issue with the code, since changing the values may have affected the full throttle issue.
I'm assuming you didn't write down all of the values you put into the quad for both of these flights so we can reproduce your results? If so, would you mind taking a camcorder along with you so we can at least watch what is going on? I don't want to see you get cut up but I would have liked to see it go into the power lines if it's going to happen anyways.
You assume wrong
Here it is (eventhough the only doubt I have is regarding transmitter value that might have been 0,15 in both cases):
  • Name: Capture-JLF- 154.jpg
Description: Setting used for the first flight with slight oscilations Setting used for the first flight with slight oscilations 55.4 KB · Views: 183
  • Name: Capture-JLF- 150.jpg
Description: Settings at the moment of the fatal throttle revup (I know, I corrected opposite for oscilations-It was on purpose I just needed to confirm) Settings at the moment of the fatal throttle revup (I know, I corrected opposite for oscilations-It was on purpose I just needed to confirm) 56.1 KB · Views: 178
Old Jun 17, 2009, 08:31 AM   #13
bob.titus's Avatar
well then, could somebody explain the main differences betwwen v1.1 and v1.0.1?
Old Jun 17, 2009, 08:35 AM   #14
bob.titus's Avatar
well again, could somebody then synthetize what should be and what should not be used for values?
Old Jun 17, 2009, 09:09 AM   #15
bob.titus's Avatar
I have managed to use Aeroquad Configurator with my french version of WinXP. It was so easy, I'm ashamed I did not think of it right away!
All I had to do was changing the localization of my user in windows control panel
Well it works fine now, and it's MUCH easier to setup the bird this way than constantly swapping between serial monitor and AeroConfig, having to disconnect and reconnect each of them constantly!
I have posted a (very boring) video on Youtube that shows the throttle issue viewed fom the configurator.
- I am using "X" config and "Servotimer2", and never move the sticks other than for arming/disarming purpose (only once I move the throttle a bit)
- the battery is not connected, only the USB is (and it does not change anything to the results if it is)
- you will notice that "mode" channel is toggling as well between min and max, and what is strange is that I initially had an issue with mode causing the serial to freeze...
Hope this helps:
http://www.youtube.com/watch?v=Q0sT4-pXX4w
Congratulations SimpleM!
