Old Jun 16, 2009, 11:28 AM
clayb62 is offline
Find More Posts by clayb62
Isaiah 40:31
Atlanta, GA
Joined Dec 2008
Question
Motor wont hold full throttle
I just finished building a mini telemaster and I'm pretty new to the hobby and when I put the throttle on full it only holds it for a few seconds before stopping. It doesn't do this on slower speeds. Is this something with the speed controller? Any suggestions?
clayb62 is offline Find More Posts by clayb62
Old Jun 16, 2009, 11:40 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Ensure the battery is fully charged and try again.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jun 16, 2009, 11:51 AM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Possibly too much current demand and the resistance ofthe battery causing the voltage at the ESC to "sag" enough to trigger the low voltage cutoff.
Possibly your setup has enough servo load to cause the ESC to trip off the motor due to a thermal protection system. High power will cause higher servo power demand (even durring "static" tests)
If unplugging one servo cures it... you need to disable the ESC's BEC and use a different power supply to the RX.
You can also test for this by just moving the sticks rapidly and checking for the ESC getting hot.
Occasionally you can get a thermal ESC shutdown by demanding too much current for the motor.
If the ESC is hot when it shuts down you should consider using a lower pitch and/or smaller diameter prop.
You either have an undercharged battery or you are overloading something.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jun 16, 2009, 12:18 PM
clayb62 is offline
Isaiah 40:31
Atlanta, GA
Joined Dec 2008
I just charged the battery last night so I'll see what happens with the essc later.
Old Jun 16, 2009, 04:19 PM
clayb62 is offline
Isaiah 40:31
Atlanta, GA
Joined Dec 2008
like I said earlier, I'm a beginner and I get the general idea, but how would I use a different power supply for the Rx and how do I disable the BEC?
Old Jun 16, 2009, 04:36 PM
Joined Mar 2005
to disable BEC you simply clip the center (+) wire of the 3 wire lead between ESC and RX. I clip the center lead of an extension thus making it very simple to go back.
Then you either get an appropriate RX battery (typically 4 cell AA NiCd or 5 cell AA NiCd.... or NiMh)or you get a stand alone BEC/voltage regulator (often called a "UBEC"... but thats a brand name.. Kind of like commonly calling facial tissues "Kleenex")
The new RX power source is plugged into any unused RX channel (servo slot) or you can use a Y harness to plug it in AND plug a servo or other device (ESC) in the same channel.
Old Jun 16, 2009, 04:53 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Mini Telemaster is small enough to where you can use the ECS's BEC without problems. I wouldn't disable it, and save yourself some weight (adding a seperate RX pack adds on weight and increases the flight speed, making it come in faster for landing- also make it less stable).
Xpress.. is offline Find More Posts by Xpress..
Old Jun 16, 2009, 05:19 PM
Joined Mar 2005
But... temporarilly using a separate RX pack is a valid troubleshooting technique. (making that modified "servo" extension a useful thing to have.)
If that cures it... something is probably making a servo draw too much power... find which one.
If that doesn't cure it then you have isolated it to something to do with the ESC/motor/battery/prop system.
Old Jun 16, 2009, 06:49 PM
R/C_Addict is offline
Find More Posts by R/C_Addict
That's me.
R/C_Addict's Avatar
San Francisco Area, CA
Whats your power setup?
R/C_Addict is offline Find More Posts by R/C_Addict
Old Jun 16, 2009, 08:57 PM
clayb62 is offline
Isaiah 40:31
Atlanta, GA
Joined Dec 2008
an atlas 12 amp esc, a X-cell 7 cell 1100 mah sport Nimh battery and an 8*6 prop.
Old Jun 16, 2009, 10:38 PM
Joined Mar 2005
Which motor?
Old Jun 17, 2009, 08:04 AM
clayb62 is offline
Isaiah 40:31
Atlanta, GA
Joined Dec 2008
An axi silver 2208/34 brushless outrunner.
would an extra cooling duct help, or would it make to small of a difference to be worth while?
Old Jun 17, 2009, 08:18 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
An 8x6 prop is "borderline" for your drive setup. Recommend to use an APC-E 8x4" and try again.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 17, 2009, 09:59 AM
Joined Mar 2005
Jürgen
We have a winner...
Yep
Drawing too much power with the motor due to excess prop load
Old Jun 17, 2009, 01:54 PM
clayb62 is offline
Isaiah 40:31
Atlanta, GA
Joined Dec 2008
thanks you guys rock, well I'll head to my LHS, get the new prop, and hopefully get this bird in the air soon thanks!
cd-rom still wont go full throttle?? Opie818 Power Systems 0 Oct 05, 2004 03:32 PM
Question Motor Pulsating at Full Throttle RMEFlyer Power Systems 2 Aug 25, 2004 10:05 AM
feda dragonfly main motor wont go full power fatboywings Micro Helis 0 Sep 27, 2003 01:35 AM
Motor went to full throttle when landing Parkflyer Castle Creations 1 Aug 11, 2003 04:47 PM
Kontronic 1000 will not hold full throttle YEAP CHIN POH Power Systems 7 Sep 16, 2002 08:35 PM
