Old Jun 15, 2009, 02:30 PM
srt5321 is offline
Find More Posts by srt5321
Joined Apr 2007
OS10LA Spitting Fuel out of carb
Help, please...
PROBLEM, please advise...
Brand new OS 10 LA... 7x4 prop w/ spinner... 1/2" Muffler extension...
Excessive oil from exhaust pipe (literally soaking garage floor and plane), and raw fuel splattering out of carbuerator, like where to air goes IN??? opposite of how it should flow it seems... if i throttle back a bit, it will not blow
fuel, only at wide open throttle... No or litte smoke...
I try to lean the engine to prevent both symptoms, but it seems to be runnnig too lean; like if i quick-pinch the fuel line it does not climb in RPMS, just starts to die...
im afraid to go too lean? how do I know? Possible spinner too large? i think its a 1.5"... Seems to run OK other than that, if not a bit sluggish...
never had an engine this small, i dont know what to expect...
OS HELP DESK REPLIES:
The best way to tune the engine is by sight and sound. If it sounds good
and has a thick bluish smoke coming out of the exhaust it is fine. That
being said, it should not be leaking out of the carb like that. I would
check to make sure that the carb is not cracked.
Its new. No cracks. No smoke. I know it should not be splattering fuel, thats why i wrote them. They said to send it in, but theyr gonna charge me $15 + s/h if they dont find anything wrong...
srt5321 is offline Find More Posts by srt5321
Old Jun 15, 2009, 02:41 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
What kind of fuel are you using?
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jun 15, 2009, 03:05 PM
srt5321 is offline
Joined Apr 2007
fuel?
Fuel? I dunno... I got it at the LHS...
I think its 15%nitro w/ 18% oil...
It's called 2stroke-4stroke i think...
Im at work, fuel is in the garage..
Old Jun 15, 2009, 04:35 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Have you broken the engine in already? If you are still breaking it in , say at least the first several tanks like the manual states, the engine might not want to lean out much yet. Only more run time will improve it's operating characteristics.
This might sound like a dumb question, but is the engine running the correct direction? Some engines will start and run backwards.
Greg
Old Jun 15, 2009, 05:34 PM
Boomerang1 is offline
Find More Posts by Boomerang1
You made that out of trees?
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
It may be so rich you cannot see the smoke for all the spray coming out of the exhaust.
With the engine running wind the main needle in slowly until it runs lean & stops through fuel starvation, then open it 1/2 turn & try again.
Lean runs will damage an engine if allowed to continue for a long period, leaning it out until it stops while trying to tune it will do no harm at all. This is exactly what happens when it simply runs out of fuel. - John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Jun 15, 2009, 06:00 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
Most 2-stroke model engines *will* spit a lot of oil out the muffler when running fuel with 18% oil.
I suspect that some of the problem you're seeing is due to your muffler extension. When you push the fine mist of exhaust oil through a pipe like that extension, it tends to condense into larger droplets which, instead of blowing away in the prop-wash, fall closer to the engine creating an oily mess.
I *HATE* those extensions with a vengence. They rob most engines of power and are must a nuisance.
It's also not uncommon for 2-stroke model engines to spit some fuel out of the carby, although this is generally more common at lower RPMs when the effect of the intake port remaining open after TDC is likely to produce reverse-flow in the carby.
Since the LA series are plain-bearing motors, you *must* use a fuel that contains a good percentage of castor oil (Omega for instance). The castor provides a much thicker oil-film on the crankshaft journal and that not only reduces wear but also provides a better seal to stop crankcase pressure and fuel escaping through the front of the engine. If you run on fuel containing only synthetic oil then you will significantly reduce the life of your engine and possibly compromise its performance.
XJet is offline Find More Posts by XJet
Old Jun 15, 2009, 08:57 PM
my c210 is offline
Find More Posts by my c210
Resident giant scale guru
my c210's Avatar
Picayune, MS
Joined Oct 2007
my brodak 049 is doing the same thing. I am running a 20% nitro 7% castor blend in it, and it is fully broken in, however when I get it to a slow idle, i feel a mist of fuel from the carb. spraying on my hand. whats upp?
my c210 is offline Find More Posts by my c210
Old Jun 15, 2009, 10:06 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Flow reversion is rather normal at part throttle for many engines. It's not so common at full throttle unless the engine is below design operating RPM. It's just part of a single cylinder engine's characteristics. A "velocity stack" can help improve the situation.
What kind of RPM are you getting?
Greg
Old Jun 16, 2009, 08:48 AM
my c210 is offline
my c210's Avatar
Picayune, MS
Joined Oct 2007
Brodak 049 RC (2 min 48 sec)
My video
Old Jul 20, 2009, 08:10 AM
srt5321 is offline
Joined Apr 2007
Update:
Plane flies great and Ive gotten used to the fuel spitting... I keep a jug of windex handy to towel off the wings after a few flights... thank you all.
Old Jul 20, 2009, 09:59 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yeah with our normal 18% to 20% oil mix fuels, you can expect a lot of residue coming out the exhaust pipe. They are messy little buggers. Spitting a little fuel out the carb is normal too. Plus the front bushing on the crankshaft tends to ooze out some oil as well. The muffler to engine attach point tends to ooze some oil as well.
it is all normal. Adjust the engine until it is running happily. You are OK.
it is why all the model airplane kits always say to use coatings that are "hot fuel proof".
Do not use the low oil content fuels with less than 18% oil in them. After you have more experience running and using engines you might consider the lower oil content fuels, but the fuels are a lot more risky.
earlwb is offline Find More Posts by earlwb
Old Jul 20, 2009, 03:42 PM
supernovam2 is offline
Find More Posts by supernovam2
Joined Jul 2009
I have a Super Tigere .40 has been runnubg great, I have flown my Sky Raider Mach II enough taht I am almost ready to Solo.
I flew it Saturday and then Sunday it went crazy. Spittig fuel out the Carb. and a lot out exhaust. I do have an extension, i.e. exhaust deflect tube, should I remove it?
Why would it all of a sudden do this?
Everyone said,Get a new one, need new bearings and seals. I always hate that. They changed my Glow Plug and it was new.
Help me guys,why does this engine not like to start after it gets Hot?
I run 15% glow fuel
supernovam2 is offline Find More Posts by supernovam2
Question fuel tubing between carb and remote needle rodneygt Engines 1 May 05, 2008 01:38 PM
Discussion Fill the tank, it's pouring out from carb and muffler. Axel40 Engines 15 Apr 17, 2008 09:10 AM
Discussion New ASP 52 dripping fuel out of front bearing avf Engines 13 Jan 12, 2008 10:43 AM
Discussion 4stokers are spitting fuel from carburator Bako Engines 17 Nov 16, 2007 09:15 PM
How to Get Glow Fuel Out of Balsa? Jasonb3391 Beginner Training Area (Fuel) 7 Oct 04, 2005 07:35 PM
