| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#121 | |
Southern Pride
I agree that TP should have marketed them a lot more selectively. I have posted many times that the extreme series should have never been sold to the average modeler however consider this.
Recently (this year) Thunder Power only sold their Pro Power 40s to a limited market,mostly RC surface vehicles and through Bob Violet Models for us in his ducted Fan models. What happened ,many got mad because they could not purchase them . Go figure. Note I am not stating that the Pro Power series has the same problems as the Extreme series dis. My PP 40 has over 160 flights on it and is still as strong as day one with no measurable capacity loss. Interesting reading for some perhaps. http://www.rcgroups.com/forums/showp...7&postcount=35 Snip: Quote:
#122 | |
More is better, always!
Jack |
#123 |
Glitch Master
Hey TreeDiver!
Yes, X-pro's are all I have, and yes! I agree wholeheartedly, a timer and good knowledge of your power train's electron consumption is the best way to manage your batteries for best health. Hitting LVC is simply a last ditch effort by the system to save your components from definite damage. |
#124 |
@Jack
For the record. I have one TP pack left. After that I do not use them anymore. Please tell you "weak and idiot" story to TP users. Again 99% of the ESC cutoff at 3volt per cell and the only batteries that can not handle it are TP eXtreme. Or does the autolipo selection of CastleCreation does something else???? It is 6volt...9volt....12volt... The older Jeti and Hacker even Cutoff lower (see link to manual) All the controllers sold do have 3volt per cell!!!!!!!!!!! You make a fool of yourself Jack, facts are "firm" against you. ![]() And bye the way, if this is so tricky at these eXtreme packs. Why does TP does not mention this??? User please set Cutoff to 3.3volt per cell....or something like that. ????? Last edited by TreeDiver; Nov 07, 2009 at 06:25 AM. |
#125 | |
So wise to set it manual with USB controller to 3volt per cell or higher if needed. It works fine these USB controllers and as said, most ESC do have this 3volt per cell setting. Only at RCgroups a few "users/TP related" people tell other stories. Unlucky for them the facts are different. Still, if a pack can handle the amps, a higher cutoff is wise to use. Also, because then you have also time to land to land on the flying field instead elsewhere. So if a pack does allow it (has good voltage load) it is wise to use 3.2 or so per cessl. I did try 3.3volt with 4s cells, but with Extreme Pack that drops to voltage with 15c load to 13volt...you can understand that it is no fun. Maybe the new packs, which are 30C will do the trick. I try first 3.2volt and will report. First I have to breakin the packs (5 times at 5c) and then I will use them in flight pulling 15C. Next year you guys will hear if the Turnigy 25c did its job and my Rhino 30c did their job btw flying on time is also an option. Packs duration is often longer then the flights a RC pilot makes. In my case. I mostely land after 7 minutes. Rob Last edited by TreeDiver; Nov 07, 2009 at 07:05 AM. |
#126 |
Hi guys,
I did say my work about it and will report in the future about the Turnigy pack and Rhino packs I have. This to stick to this thread. I had bad expierences with other expensive packs and the competition seems to be much better then expected. If a 20c cheap pack does outperform a 25c expensive pack...that does say enough to me. So Jack and Charles. Please do stop with telling weak stories that hold "no ground" at all and are only subject to one brand in the market. So guys...stay tuned for the reports of Turnigy and Rhino Rob ps. And I was right. All Controllers do Cutoff at 3volt per cell and not higher. |
#127 |
Jack is actually right,
3.0 WAS for the OLD packs, 15C etc, today higher is needed, new ESC's are getting there, CC you can program yourself. If you discharge newer packs (25+C) regulary to 3.0, THEY WILL FAIL, period! How they fail is a different story, some loose capacity, some get raise in IR, some puff. That all depends on the chemistry used for that pack. Only way to truely use LVC is to add a Schulze LipoDimatic or simular device, monitor each cell, AND program it to correct LVC (3.2 or so) That is, since voltage drop is so fast when its little capacity left, some cell (if out of balance) will dip more, and just a few mah difference, makes a huge voltage difference when there is no capacity left. Timer or Lipodimatic, last resort only use LVC in the esc (if max 3.0 is possible) as failsafe, if your forgot to charge your pack. |
#128 |
By the way, the fact that even new esc's are set for 3.0 isnt because its "right" but how many ESC's would go in return because it cutoff 30 seconds into the flight, for all users having old crappy packs?
Just because your old ESC was set to 3.0 it didnt cutoff. So from a business standpoint, 3.0 is usually the default for new ESC (not CAR ESC's they are a bit a head already having higher cutoff already) That doesnt mean its right for you or your packs though. |
#129 |
MrMel,
Well, time will tell. If the Rhino 30C I did order will have the same problem, I will post it for sure. The Rhino 20C anyhow are solid in my hangar untill now. If the new ordered Rhino 30C have a good voltage under load. Then an ESC setting of 3.2volt should be no problem and is wise to do. In my case it did not work out with the 2008 eXtreme packs because they do not hold voltage with 15C draw. (see other thread about this). So Jack can tell "allot" but it did not work out. Basic design of these packs where "crap". I agree that it is wise to pick a higher voltage ....but only BECAUSE: If a pack hits 3volt per cell with the ESC, there is not much juce left...and it can cause trouble in reaching the landing field! Fact: most RC pilots lands before it his the ESC Cutoff, since with LiPoly you have enough duration already. Next year for sure more 25c and 30c pack will appear on RC club. Most likely HC packs. But if they have the same problems as the TP packs, it will pop-up for sure. Do not worry about that. All RC pilots at our club have 3volt per cell as Cutoff for their packs and I did not notice anyone having troubles with it. Also these are facts. So if you and Jack are right, we are going to see "allot" of defect HC packs next year. As said, time will tell. :-D Rob Last edited by TreeDiver; Nov 07, 2009 at 08:20 AM. |
#130 |
Hi,
Anyhow I hope somebody will post now about his Turnigy 25C pack!!!! My friend has one and I will ask him if he will post. So Turnigy users.... please tell us your expierences!! This thread is initial about Turnigy. I did my word and told that I am surpriced about the quality of these HC packs and told also that I bad expierence with very expensive packs. Everybody must value that to his own and make his own conclusion. Cheers, Rob Last edited by TreeDiver; Nov 07, 2009 at 08:30 AM. |
#131 | |
A man with too many helicopter
Turnigy
I charge them at 2C and it takes about 25 minutes or less depending on how far I run them down. When charging I really notice that the last phase (CV) goes much faster than on my other batteries. I only have about 50 flights on each and so far the capacity and IR are the same as when new. They replaced some EVO 25 5000 packs that I had been flying for a while and the performance boost with the Turnigy packs is very noticeable. The EVO packs also took a lot longer to charge even at 2C.
#132 |
My friend's flightmax started to loose punch now after only 30 cycles (about 6 months calender time), correctly stored inbetween, used in low avg draw application (7+ min flighttimes), hard to say why some lasts and some dont really.
That said, they might survive longer though, just not as powerful (they trigger 3.2v cutoff too early now). |
#133 |
@ RC Man
Cool. That is good news. The Turnigy packs mention that they are selected on IR.Kind of omega symbol at it in upper right corner. I eager to test my 30C Rhino Packs. Must say that the Turnigy packs look very cool with this sticker they use. The 30C Turnigy 2200 seems to be a bit more heavier then the 2150 Rhino 30C, so I did select the Rhino. But if you remove this "thick" plug from Turnigy, they are "allot lighter". So it could be that the Rhino 2150 and Turnigy 2200 are very close in weight. I use 3.5plugs and the Rhino will be arround 184gram (3s). Cheers, Rob |
#134 | |
Seems to be the same problem I had. They loose power. It also goes slow. I noticed the defect of my 4s packs the moment my RC friend did fly with the same setup and had far more power. So it can also be sneaky. Best is to check regular with a "Wattsup" device and check how the voltage does drop during load. I had only 13volt...pulling 26amps with 4S pack. 30cycles is not much if he did not push the pack to its limit. Bad luck I am afraid...just like me. Rob |
#135 | |
Here's my video of a 3D Yak using Turingy power system. I get about 3:30 flights using 80% rule for big lipo batterys. http://www.fliqz.com/aspx/permalink....44909dfad3b56f This is a 12S1P 5000mah setup with turnigy 100A ESC. No problems drawing 100+ amps in burst over 4000 watts. Plus my blog which has more actual in-flight data logged data. These are accurate facts of actual preformance of a new pack! http://www.rcgroups.com/forums/member.php?u=11740 Enjoy! Frank |
| Thread Tools | |
| Discussion balance plug on the new turnigy batteries.. | 57sailplane | Batteries and Chargers | 5 | Oct 28, 2009 06:27 AM |
