Old Jun 15, 2009, 06:30 AM
stemasoft is offline
Find More Posts by stemasoft
Hinwil, Switzerland
Joined Oct 2005
Readout RPM and Temperature out of Lambert Kolibri Turbine
Another customer want's to know if it's possible to read out the RPM's (about 250'000/min) and as well the temperature via the ECU-FADEC (JetECU Interface Cable) out of his Lambert Kolibri Turbine ( here's the link to http://www.lambert-modellturbinen.de )
Could anyone help? That's the only question that's left!
Regards
Stemasoft
stemasoft is offline Find More Posts by stemasoft
Old Jun 16, 2009, 01:04 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Stemasoft,
Yes, that should work fine, as long as the ECU used with the Kolibri is the FADEC. I looked at the photo on the website, and it sort of looks like the FADEC, but I did not see it explicitly mentioned on the website.
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Sold Eagle Tree V3 150A with RPM and temperature sensor! sircrashesallot Aircraft - General - Miscellaneous (FS/W) 2 May 15, 2008 07:59 PM
Discussion RPM and Temperature Sensor wadiprawita UAV - Unmanned Aerial Vehicles 7 Aug 02, 2007 07:35 PM
Discussion Lambert Kolibri nickhawk Fuel Jet Talk 3 Dec 19, 2006 11:37 AM
Discussion Lambert Kolibri nickhawk Fuel Jet Talk 0 Nov 05, 2006 10:23 AM
Discussion RPM, Throttle, Temperature, Voltage Data From ESC-View MDrive Power Systems 0 May 26, 2006 09:16 PM
