Old Jun 15, 2009, 02:30 AM
Mr. UD is offline
Find More Posts by Mr. UD
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Build Log
EPP SU-22 Fitter
Hy everybody,
just wanted to share some pics of my recently finished SU-22. OK, shes no pusher but I think she fits in here best.
She is made of 20mm(fuselage) and 10mm(aerodynamic surfaces) EPP RG20 (20kg/m) with 1,5mm carbon rod reinforcements. Armament is mounted with 2 pieces of 10x5x1mm magnets each and removable for flight.
Some tech data:
span: 930mm
length: 970mm (1090mm including Elevator and Spinner)
area: 19,6dm
fuselage diameter: 97mm
weight: 570g
Tailerons: 2xHXT-900
Rudder: 1xHXT-500
Motor: Turnigy 3530B 1400kV
Akku: 3s2200mAh Flightpower
RX: GWS 6Ch
First flight will be together with my YAK-130 when it stops raining in Germany together with my YAK-130.
Hope she flies as she looks
Mr. UD is offline Find More Posts by Mr. UD
Old Jun 15, 2009, 08:49 PM
beanie is online now
Find More Posts by beanie
Ann Arbor, Michigan, United States
Joined Sep 2003
mr ud- that looks great!! are the Su-22 and the Su-17 sister ships? i was working on an Su-17 that has stalled out a bit. but the lines look extremely similar to the Su-22 that you have here. excited to hear about how she performs and where your CG ends up. is yours swing wing? good luck with the maiden!
-beanie
beanie is online now Find More Posts by beanie
Old Jun 16, 2009, 12:10 AM
Mr. UD is offline
Mr. UD's Avatar
Deutschland, BY
Joined Oct 2007
Hello beanie,
as far as I know is the main structure of the SU-17, SU-20 and SU-22 almost the same. The SU-20 and SU-22 are export- versions of the Su-17. Changes were primary made on engine, armament and avionics and small changes on Canopy and back. All drawings of the three birds that I have found were almost the same - but I cant guarantee
I was testing the CG before installing armament and electronics (~250g) and had to move the CG about 20mm back from the calculated position for a nice glidepath. Lets see wether the CG still fits with more than twice the weight and a powerfull engine in the nose.
PS.: still raining in Germany
Old Jun 16, 2009, 08:17 PM
adamdb is offline
Find More Posts by adamdb
United States, CO, Denver
That is going to look GREAT in the air! Even better than if it were a pusher with a motor hanging off of the back.
I hope it flies as good as it looks!
adamdb is offline Find More Posts by adamdb
EPP SU-27 Flanker Pusher jet (Video) Philip Thulin Pusher Prop Jet Models 38 Mar 19, 2009 10:36 AM
Rcm-pelikan Epp Su 27 Andy McCowan Foamies (Kits) 141 May 03, 2005 08:44 PM
Su-22 Fitter drawings? Huckebein Electric Ducted Fan Jet Talk 6 Mar 21, 2005 02:09 PM
FS: EPP Su-31 JRW21 Aircraft - Electric - Airplanes (FS/W) 3 Dec 06, 2004 12:10 AM
Epp Su-27 swingkat420 Electric Ducted Fan Jet Talk 1 Mar 25, 2004 02:45 PM
