Old Jun 14, 2009, 08:39 AM
Jaketownsend36 is offline
Find More Posts by Jaketownsend36
We all love Cox wont-starts
Jaketownsend36's Avatar
Caister on sea, Norfolk, UK
Joined May 2009
White spirit in fuel?
Can you put white spirit into fuel, or will this not work?
Jaketownsend36 is offline Find More Posts by Jaketownsend36
Old Jun 14, 2009, 11:59 AM
Bothersome is offline
Find More Posts by Bothersome
That whirly guy
Bothersome's Avatar
Vivian, LA
Joined Jan 2007
That's a good question.
I have a couple of gallons but I'd never try it without some of the experts chiming in and explaining things in more detail.
I suspect, no. It probably won't mix well with the oils we use.
However you said fuel but did not list the type of fuel you refer to. I reply on the assumption of methanol fuel.
If you mean gasoline, then yes you probably could mix 10% into it, but I'm no expert.
Bothersome is offline Find More Posts by Bothersome
Old Jun 14, 2009, 12:31 PM
Joined May 2009
I meant methanol-based fuel.
Just wait and find out i guess
Old Jun 14, 2009, 12:44 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
People are running 50/50 methanol and gasoline in engines. You could do the same with white spirits. It will considerably lower the octane rating of the fuel and this may or may not be a problem for the engine you are using. The glow plug is also not as effective, so you may find it needs to be powered all the time to run the engine.
It's not a common practice so you'd be on your own. If you want to save money on fuel, the easiest way is to run methanol oil with no nitro. No modifications required.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jun 14, 2009, 04:33 PM
XJet is offline
Find More Posts by XJet
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
I've never been able to get methanol to mix well with gasoline.
XJet is offline Find More Posts by XJet
Old Jun 14, 2009, 04:57 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Hi,
What do some of you call "white spirit" .
White spirit here is sold at the liquor store at over $30.00 a litre.
It is also called vodka.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Jun 14, 2009, 06:50 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Bruce, you must have seen the gas-glow thread over at RCU
Old Jun 14, 2009, 07:12 PM
XJet is offline
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
No, I don't bother with Nazi-land any more :-/
Edit: someone complained about this post. It looks as if RCU moderators also use RCG :-)
No, I'm *not* going to change it just because it puts someone's nose out of joint.
Old Jun 14, 2009, 07:42 PM
Wayne V is offline
Find More Posts by Wayne V
Wayne V's Avatar
London, Ontario, Canada
Joined Jan 2006
GAS/GLOW works great and yes it's 1 part glow fuel mixed with 2 parts premium gasoline and as long as you get good gasoline the two stay mixed just fine, we use the mix in a converted weedeater engine on an OS 4 stroke glow plug.
Wayne V is offline Find More Posts by Wayne V
Old Jun 15, 2009, 11:26 AM
Joined May 2009
Cools
Old Jun 15, 2009, 02:28 PM
unattainium is offline
Find More Posts by unattainium
Chicago
Joined Jan 2009
Originally Posted by Zor
Hi,
Zor
Try White Lightning. You don't buy it at liquor stores and you don't pay tax on it.
I would say that the white spirit referred to here is low octane gasoline used for gasoline lamps and stoves and sometimes also called mineral turpentine when used with paint.
Correct me if my memory is playing tricks, but I remember from somewhere that acetone acts as an aid to mixing methanol and oils or alkanes such as gasoline.
unattainium is offline Find More Posts by unattainium
Old Jun 15, 2009, 03:21 PM
Joined May 2009
I dont know if countries have regional names, but it is naptha, a fraction from the fractional distillation of crude oil. The substance is used for cleaning brushes, and yes, it is used for parrafin lamps, but i am wondering if you can mix hydrocarbons with methanol-based fues.
Discussion Glo Fuel Dissolves White Glue in ARF bryadelm Fuel Plane Talk 10 Jun 27, 2007 01:51 PM
:)Anyone made a B2 spirit in Depron? broddarn Foamies (Kits) 10 Jun 22, 2001 11:21 AM
Red circle with white X in place of graphic? Balin Site Chat 2 Apr 22, 2001 11:11 PM
