Old Jun 14, 2009, 08:21 AM
bobruhter is offline
Find More Posts by bobruhter
Joined Dec 2008
Watts per pound
I am new to electrics and need know where I can find the watts per pound for electric.
bobruhter is offline Find More Posts by bobruhter
Old Jun 14, 2009, 08:35 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Bob - watts per pound are found when you use a watt meter to determine how much power you system produces.
The meter goes in between your batter and ESC on your power system and it measures the watts/amps/volts. It is used for ground testing.
If the meter shows 100watts and you have a 1 pound airplane - you have a 100w/lb.
Simple as that.
Old Jun 14, 2009, 08:44 AM
BEA flyer is offline
Find More Posts by BEA flyer
Concord, MA
Joined Jun 2002
Watts per pound was what people used to talk about when determining how powerful a motor you needed to fly a plane. Watts was sort of a measure of power, except when prople satrted flyingthier electric planes the brushed motors were pretty inefficient, so 200 watts measured going into the motor was anywhere from 20% to 70% efficient.
People generally quoted 50 watts per pound as "adequate." I think this would be at the 70% efficiency, 35 watts OUTPUT per lb, and this is flying pretty marginally, like a piper cub style plane with a light wingloading, like a powered glider.
For ROG, 70 watts per pound is better. For a 3D plane, you are talking around 150 watts per lb.
If you are building a kit, the manufacturer would likely recommend a motor size.
The manufacturer of motors will list a watt rating for the motor, but prop size and cell count and cell type will all effect the output.
I would use the 50 watts per pound as a minimum. At 100 watts per pound, you will be testing the structure of the plane, and it needs to be as robustly constructed as a power plane at 100 watts per lb. an imbalanced prop ofr bengt shaft wil make it vibrate as much as a nitro engine.
770 watts is about a horsepower. Do not compare this to nitro motors horsepower, because you might have a motor rated over 1 hp, like a .40 pylon motor, at 21,000 rpms, but it only runs at 12,000 rpm as propped, so an electric motor putting out 400 watts would fly about the same.
Go with a recommended power system, ie battery and ESC and motor, until you have some practice with different planes and power setups. And keep in mind that BRUSHED motors are not very efficient, so you might double the power in to get the same watts output. I have a wattmeter. It measures the watts going into the motor. You could get watts output using calculations based on rpm, prop size and prop speed.
I would just go with watts input, and maybe go a little higher on the watts per lb. 75 watts per lb, input for brushless motors should be enough watts per lb. unless you need to go straight up. This should give "spirited performance," like loops from level flight.
BEA flyer is offline Find More Posts by BEA flyer
Old Jun 14, 2009, 09:33 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally Posted by bobruhter
I am new to electrics and need know ...
For a rainy day.
* Presentation: de-mystifying Electric Flight
www.rcaircrafters.org/The%20Electric%20Show.pdf
* Brushless motor animations and simulations:
http://www.rcgroups.com/forums/showthread.php?t=216928
* www.wattflyer.com/forums/forumdisplay.php?f=3
-> Everything You Wanted To Know About Electric Powered Flight
* www.ampaviators.com
-> Beginner Guide
* www.ezonemag.com
-> Faq
* Choosing a power setup
www.rcgroups.com/forums/showthread.php?t=739069
http://www.wattflyer.com/forums/showthread.php?t=27019
* Current, voltage, Watt, battery-types and -C-rating explained
www.rcgroups.com/forums/showthread.php?t=417868
* Motor_internals_101, about poles, winds, delta, star
www.gobrushless.com
-> knowledge base
-> basic overview (1-5)
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jun 14, 2009, 11:00 AM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
FYI - My 5.5 lb Cub on floats has 400 watts , ROW's and flies fine , can do loops ( with a shallow dive to start ) and rolls and inverted flight , etc. once up flies easily on 1/4 throttle .
lake flyer is offline Find More Posts by lake flyer
Old Jun 14, 2009, 12:07 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Watts per pound is really determined by your prop choice too, I.E. a 3D plane with 150 watts on the nose, weighing in at 15-16oz with a 10x4.7SF prop on 3 cell will go vertically pretty quickly. But a pylon racer on the same battery, same weight but an inrunner swinging a 6x4 prop may need at least 200 watts per pound to go vertically.
Generally, for your parkflyers swinging 7-12" props, here's a good chart, if you must:
50 watts per pound = slow flight, enough power for cruising.
100 watts per pound = Good flight performance, quick takeoffs.
150+ watts per pound = Unlimited vertical power, will takeoff vertically.
Xpress.. is online now Find More Posts by Xpress..
watts per pound smittylube Power Systems 8 Oct 07, 2002 03:51 PM
Watts per pound for a sports plane Masterpiece Electric Plane Talk 10 Feb 22, 2002 08:56 AM
Watts per Pound gary majnusz Electric Ducted Fan Jet Talk 7 Feb 22, 2002 02:17 AM
Watts per pound in or out!! GUIS Electric Plane Talk 5 Feb 16, 2002 04:01 PM
Y/A F18 200 watts per pound Plane Crazy Electric Ducted Fan Jet Talk 33 Dec 23, 2001 08:01 PM
