Old Sep 29, 2009, 03:09 PM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Looks awesome. At 1/9 scale you should have a nice size plane. What will your power be? This will be sticks and tissue?
warhead_71 is offline Find More Posts by warhead_71
Old Sep 29, 2009, 09:00 PM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
This project reminds me of the FW56 Stosser I recently built. Similar type of parasol plane of mixed construction, with a large, solid cowl. If I could have done one thing differently, I would have built at around your 40" span than the closer to 30" span that I built at. As far as the build goes, it was done on the fly, using a 3-view as a guide. Are you planning to fully CAD design the plane first, or just get started with a basic outline/formers, and work out the details as you go?
WTFLYR is offline Find More Posts by WTFLYR
Old Oct 01, 2009, 12:29 AM
Longhorne is offline
Find More Posts by Longhorne
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Warhead,
It will be along the lines of the original: skinned cowling and stick/tissue over the rest. The motor I've set aside is a RCHotdeals special that runs 150-180W on 3S. I'm running the same outfit in a similarly-sized sport plane that I've really liked.
WTFLYR--your Stosser is a nice little build. For the Curtiss I'll reduce the solid model to the final framework and the result will become the cut file. I've got a ways to go that just got longer now that the little woman wants me to design a patio in CAD.
Paul
Longhorne is offline Find More Posts by Longhorne
Old Oct 01, 2009, 09:51 AM
Led Zepplin is offline
Find More Posts by Led Zepplin
Fly, dangit!!!
Led Zepplin's Avatar
Little Rock, AR USA
Joined Jan 2007
Paul - Great CAD work on a great subject. This one has a really beautiful form. I'll definitely be watching with interest. Best of luck!
Led Zepplin is offline Find More Posts by Led Zepplin
Old Oct 03, 2009, 08:08 PM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Thanks, Led. Maybe a micro-version is in the future? Those little baby bipes of yours are really sweet!
Dad's home with a barfing 7 year old today. Bummer for both of us but at least I've got an excuse to spend a day doing CAD. Well, now that I'm done cleaning the carpet--ew.
Got quite a bit of the deconstruction done today. Just the ailerons and fuse are left. With a little luck I might be laying down the cut files by Monday.
The ailerons are a bit longer than stock but they're narrower than I'd like do to the enormous outer wingstrut faring. Should be ok for scale performance, but she definitely won't be a sport plane.
Paul
Old Oct 03, 2009, 11:00 PM
WTFLYR is offline
WTFLYR's Avatar
West Central PA
Joined Dec 2008
Originally Posted by Longhorne
Warhead,
Paul
That's probably the only way that would interest me in using CAD, being an ex-Pro-e guy. You can pretty much get anything out of the 3-D model. It's easier for me to work from 3D to 2D, than vice versa. I would probably export DXFs to ACAD, after putting enough thought into what sections I needed.
The Stosser is typical of my scratch builds, in that the 1 evening spent enlarging and taping together sheets of an enlarged 3-view with sections, is about all the patience I have in the planning stage. I like to get to the balsa as soon as possible. It's amazing how quickly you can frame up a plane with a 3-view, using the Guillows design method.
Your Curtiss has definitely caught my interest, after building a similar era parasol plane. It's a pretty plane.
Old Oct 18, 2009, 01:36 PM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Man the time flies by! It took a bit longer to get a battery hatch and wing attachment layout that I was happy with. The hatch result will be a vac formed cowling with light internal framework. The parting lines are the same as the original cowl housing the Conqueror V12. Plenty of access to the motor and battery from here.
The wing attachment will involve a removable hatch permantly fixed to the wing by the cabanes. It will be fixed in place by pins in the back and a single 10-32 in the front. Once removed the rudder and elevator servos will be accessible.
Now for the cut files!
Paul
Old Oct 31, 2009, 02:38 PM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Entering the Building Phase
The cut files went out last week so this project has effectively moved from a CAD exercise to construction.
The first step was to build a little tank to soak the strips of 1/32" balsa that make up the wing tip and tail laminations. As Jr had recently worked with me on some irrigation repairs, he was given that assignment. He made a 26" long tank from 3/4" PVC. This easily fits 20 strips or so--perfect.
After an overnight soak in water with a little ammonia the strips were very submissive. We painted the mating surfaces with a mixture of carpenter's glue and ~30% water, pinned the lamination tightly to the styrofoam form, and left the result to cure overnight.
There's a few odds and ends to arrange on the plan drawings to keep me busy until the parts show up. This is the point where the size of the project becomes a reality. While this project isn't really that big (WS = 42") it's bigger than most of mine. That's becoming very clear to me now that I need two D size sheets for the plan.
Have fun,
Paul
Old Oct 31, 2009, 04:00 PM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Very nice subject Paul !
jofrost is offline Find More Posts by jofrost
Old Oct 31, 2009, 06:33 PM
Fly, dangit!!!
Little Rock, AR USA
Joined Jan 2007
Paul - Excellent idea on the soaking tank... I usually just use my wife's bathroom sink which usually gets me in trouble.... I guess the ammonia helps it to saturate better?
Anyway, I'm so excited to see this one come together! Those drawings are just beautiful. It might make a great micro model, I wonder how small you could make this one and still keep it nice and stable with the flat wing...
J. B.
Old Oct 31, 2009, 06:36 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
The ammonia softens the lignin (I think that's what it softens!) in the wood more effectively than simply soaking the wood in water.
James
Deuce is offline Find More Posts by Deuce
Old Nov 16, 2009, 10:40 PM
woodsy is offline
Find More Posts by woodsy
Woodsy
Drouin, Australia
Joined Sep 2003
Check out this link, down the bottom, page 157
http://books.google.com.au/books?id=...6c%206&f=false
woodsy is offline Find More Posts by woodsy
Old Nov 19, 2009, 02:02 AM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Back at it!
Woodsy--thanks for the link. That book is chock full of ideas for future projects.
After a bit of a hiatus the Curtiss is under full swing again. Zeke sent out the short kit and luckily this time the postal gods smiled upon the project--no boot prints.
To get started the tail group was framed up and filled in. The parts fit was very good, but the doofus that designed this thing left out a couple of notches here and there--oops! Anyways, we're off and running now.
Paul
Old Nov 19, 2009, 09:16 AM
roscoedude is offline
Find More Posts by roscoedude
roscoedude's Avatar
United States, OH, Cuyahoga Falls
Joined Oct 2006
Looking good Paul... wait till you you have her all framed up, your gonna sit there and say, damn, that's alot bigger than I thought it was.
Funny how CAD makes everything seem smaller, until you actually build it.
Good luck,
Dean
roscoedude is offline Find More Posts by roscoedude
Old Nov 19, 2009, 02:42 PM
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Yeah, I've been thinking that alot. I think the solution is to work on a 42" screen instead of a laptop.
Paul
60" AT-6 Pylon Racer Tawg Slope 63 Feb 14, 2005 12:38 PM
Curtiss R-6 part 2 kinda wespe Scale Kit/Scratch Built 14 Jan 09, 2005 05:36 PM
Wing construction advice Curtiss R-6 wespe Scale Kit/Scratch Built 45 Nov 17, 2004 09:24 AM
