Old Jun 14, 2009, 12:17 AM
New Zealand, Auckland
Joined Dec 2008
ESR meter to test Nicad/NiMH ??
Hi there. Has anyone used a ESR meter to test Nicad/NiMH ??
Basicly compare the internal resistance of batts to pick out bad batts.
I wonder if I'd get any useful measurements/results.
1101 is offline Find More Posts by 1101
Old Jun 14, 2009, 07:37 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, 1101
I have two models here :
- a µMetros from Mr Cam ( DIY )
- a RIM 1000 from Conrad / ELV ( Germany )
Both work pretty well ... and give same results.
But which results !!! a bit far from the 1Khz tests ( significative ??? ) of cell constructors ... but true.
One thing is sure : it is a very good instrument to detect cell differences ... It can also show the charging state , as internal resistance is a function of charge ( and rest ...)
Don't be sad when you will discover batts are " not so perfect " ...
Alain
Acetronics is offline Find More Posts by Acetronics
Old Jun 15, 2009, 01:20 AM
Joined Dec 2008
Hi Alain
I'll give it a try them. My ESR is DIY as well.
Ive a pretty good idea what cells are 'off' on my old nicads, not sure with my NiMh
Do the batts need to be discharged first ??
Would a bad cell give a higher voltage across that cell in the pack when discharging (due to higher than normal internal resistance)??
Cheers
Steve
Old Jun 15, 2009, 04:08 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
Hi, Steve
The best to do is charge the cells and let them aside for two or three days ...
Then you measure.
A bad cell will give LOWER voltage than others during discharging ... even invert its polarities ...
And remember NiMh internal resistance can vary a lot with discharge state or rest ( moreover the AA and AAA " High capacity " cells !!! )
C Size do not show a huge variation ... THEM.
Alain
Nicad/NiMh peak charger - brand new - $28.00 delivered Danny Troy Aircraft - Electric - Airplanes (FS/W) 13 May 18, 2002 01:05 AM
Nicad/nimh charger, 1-12 cells foss1997 Aircraft - Electric - Airplanes (FS/W) 2 Apr 07, 2002 10:38 AM
Dymond Nicad/NIMH Peak charger FS foss1997 Aircraft - Electric - Airplanes (FS/W) 0 Mar 27, 2002 04:14 PM
Best AC/DC Charger for NiCad & NiMh? CheeseWing Electric Plane Talk 1 Jul 21, 2001 08:30 AM
Best AC/DC Charger for NiCad & NiMh? CheeseWing Electric Plane Talk 6 Jul 21, 2001 07:45 AM
