This thread is privately moderated by FLOEY, who may elect to delete unwanted replies.
Old Jun 13, 2009, 01:12 PM
FLOEY is offline
Find More Posts by FLOEY
Norway
Joined Dec 2007
Build Log
Crash built with scratches
Some pix of my 'designs' protoypes as usual.
Need some bad weather to get the designs
finished.
FLOEY is offline Find More Posts by FLOEY
Old Jun 14, 2009, 08:30 PM
sky56 is offline
Find More Posts by sky56
Saint John NB
Joined May 2007
Good idea / magister end flaps
On your magister i noticed the straight on feed to control horn .
I have stayed away from "wing" far end mount ailerons with single
servo control now I see I should be able to feed the control horns with a wide
sweeping turn plastic tubing . As in the past I`ll use .035 mig wire with soldered
brass eyelets on the ends and small bolt /nut .
If you can hide the tubing this might work for foamies to larger scale
home builts . .....Wayne
sky56 is offline Find More Posts by sky56
F/S FP Piccolo built with extras Aobid Aircraft - Electric - Airplanes (FS/W) 4 Feb 12, 2003 08:15 AM
What have YOU built with 5mm Depron? Matthew Allen Foamies (Kits) 31 Jul 17, 2002 10:24 AM
F/S Hornet built with CP head and servos logo10 Aircraft - Electric - Airplanes (FS/W) 0 May 21, 2002 12:40 AM
F/S New hornet built with CP head logo10 Aircraft - Electric - Airplanes (FS/W) 0 May 20, 2002 01:07 AM
Has anyone built with the Lil Hornet's foam wing left overs? poobs Parkflyers 32 Sep 29, 2001 02:47 PM
