Espritmodel.com Heli Air
Old Jun 13, 2009, 07:11 AM
Ukraine, Lviv
Joined Jun 2009
EDF Ducted Fan Unit 7 Blade 3.5inch
Hello. Im new to this forum and for EDF systems. i have this EDF and 80A HiModel Pro ESC
Im looking for help with: With motor i need for this EDF for best performance? Actualy need a 2000g of static thrust.
And what is better for this EDF high KV on 3S Li-po or eqivalent RPM on 4-5 S Lipo ?
What is the best RPM range for this EDF ? im read some reviews about it and a lot of ppl getting 2100 g thust on 29000 rpm
Thanks.
NowoN is offline Find More Posts by NowoN
Old Jun 13, 2009, 09:08 AM
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Welcome to the RCGroups!
This fan you are asking about is called Hayole 3.5", if you do search you will find plenty of data about it in this forum.
Make sure that you will balance it before running!
I am planning of using this fan with Scorpion 3026 1400kV - this $75 motor seems to me as a most economical solution.
I bet that others, more experienced with DFs guys will chip in with help...
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Jun 13, 2009, 02:45 PM
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
What battries and how many do you plan on using??
RWCLOUD is offline Find More Posts by RWCLOUD
Old Jun 13, 2009, 04:59 PM
Ukraine, Lviv
Joined Jun 2009
RWCLOUD
even i dont know 4s Li-po 4000 mAh
i can buy motor only from Hobbycity The KD or Turnigy inrunners marked with numbers like 36-50-08. So what size of motor i need?
Or another way. What is the best config for this EDF, to get high ans stable thrust like 1800-2000 g.
Its my first try in EDF. Thats why my questions is so stupid
Tnx
Old Jun 13, 2009, 05:48 PM
marell01's Avatar
Sweden
Joined May 2006
Hi NowoN, welcome to this fantastic commiunity.
I´ve been done some testing for this fan. Please check this tread : Test of Haoye 3.5 " FAN
Also this post for finding a good motor from hobbycity Hobbycity motor for 90mm fan
marell01 is online now Find More Posts by marell01
Old Jun 14, 2009, 05:44 AM
Ukraine, Lviv
Joined Jun 2009
marell01 tnx .
Very usefull data.
Old Jun 15, 2009, 04:22 AM
Ukraine, Lviv
Joined Jun 2009
May be some kind of outrunner can be installed in this EDF ???
Old Jun 15, 2009, 06:52 AM
Joined Jan 2009
yeah i bought the 89mm+outrunner combo from HC. The outrunner it comes with is ~1670kV and it's a bit of a no mans land as i dont want to run 5S (4S too low 6S too high).
i'm running this combo on an 1.6m F20 and i've pegged the max throttle in the tx to max it out at 1100W only as the batteries are two 3S 2200mAh 20C's and i don't want to fry them. once i have more flights on them i have plenty of battery room and i'm planning on 6S 2P'ing them and putting about 1.9kW into this combo on 6S. Not sure it'll work but i'll give it a go when the time comes.
I think for 4S i'd go for about a 2000-2200kV motor for about 1.0-1.3kW out of two 4S2200 for a total of 4S 4400mAh. You'd have high current and voltage losses though.
on 4S 4400:1.3kW 90A (safe option, should handle power, these motors get hot though)
http://www.hobbycity.com/hobbycity/s...idProduct=6676
on 4S 5000:1.5kW 100A (dunno, maybe too much power)
http://www.hobbycity.com/hobbycity/s...idProduct=6529
on 4S 4400:1.4kW 95A (but will probably melt)
http://www.hobbycity.com/hobbycity/s...idProduct=6531
When I melt the motor that came with this combo I'm going to buy one of these:
http://www.hobbycity.com/hobbycity/s...idProduct=8485
and run it 6S2200 1.25kW 20C or 7S4400 (lots more batteries) for 2kW
i have a lot of 3S2200's and 4S2200's so all the setups i have are multiples of these...
PulseFusion is offline Find More Posts by PulseFusion
Old Jun 15, 2009, 06:45 PM
Ukraine, Lviv
Joined Jun 2009
http://www.hobbycity.com/hobbycity/...?idProduct=8485
I got this outrunner and 2x of ZIPPY_Flightmax_4400mAh_3S1P_15C
i got in total 4400 6s1p. How do u think is my HiModel 80A Pro Series good for it? I hope it is.
Actualy i need i bit more than 1400g thrust but at this time nozzle thrust looking verticaly down.
Old Jun 16, 2009, 03:41 AM
Joined Jan 2009
Yeah that should draw about 60A... 2x 3S4400's may be a bit heavy... 2200's are about as small as you can possibly go, 3000's may be the best size for this setup, 4400's will fly for ages but may be pretty darn heavy and difficult to balance... what's it going in?
Old Jun 16, 2009, 09:18 AM
Ukraine, Lviv
Joined Jun 2009
oh its for X-35 STOVL
Old Jun 17, 2009, 03:19 AM
Joined Jan 2009
gosh, and by stovl, you mean you're making an F35 that looks and smells right but not actually going to try to do one of the hardest things with ducted fans known to man (STOVL/VTOL)... good luck if so, pics and vid... ;-)
Old Jun 17, 2009, 05:35 AM
Pasadena, CA
Joined Mar 2007
Is there a link to an article explaining fan blades and kv?
Havnt found much on google.
Mostly threads about what specific setups people are using.
But i need ti understand WHY certain motors are better for specific edf blades.
I am currently running a 5 blade EDF, 64mm diameter, 3500kv outrunner, 4S 2200mah batt, 60A esc.
Not enough speed.
After a 3 minute flight, battery, motor, and ESC still relatively cool.
No indications of overamping.
What should i do to increase top speed.
The jet is a Freewing L39 Albatross.
What effect will the 7 blades fan have if i drop it into this power system?
Brutikus is offline Find More Posts by Brutikus
Old Jun 17, 2009, 03:53 PM
Ukraine, Lviv
Joined Jun 2009
for EDF 64 5 blades u need 4300-4600 Kv
Old Jul 08, 2009, 03:13 AM
Ukraine, Lviv
Joined Jun 2009
Work in progress. Another question. Anyone runEDF89_with_D3468kv on 6S config and what is motor Kv?? 3468Kv ? OMG on 6S its near 75000 rpm !! EDF calculator talks 238km/h
So anyone have rigth data on this combo?
Help! EDF Ducted Fan Unit 7 Blade 3.5inch NowoN Power Systems 2 Jun 13, 2009 07:07 AM
Discussion United Hobbies EDF Ducted Fan Unit 7 Blade 5 inch 127mm bryadelm Electric Ducted Fan Jet Talk 10 Nov 06, 2008 11:47 AM
Sold Hurricane 8 blade custom ducted fan unit! airmcn_3 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 27, 2005 11:53 AM
Factory Sealed WeMoTec MF 001-3 480 Mini Ducted Fan Unit $48.00 shipped. gbagley Aircraft - Electric - Airplanes (FS/W) 0 May 19, 2002 12:29 PM
