| Thread Tools |
| This thread is privately moderated by UBILDIT, who may elect to delete unwanted replies. |
SuperCub Powers.... Activate
The transformation of the SuperCub is nearly complete. I have the clipped wing twin motor version ready to go, complete with fabricated nose cone. Now the only part of the transformation to comlete is to make an outrunner mount detachable so that I can remove the solid nosecone, put an outrunner on the stick mount that's under it, put the original cowl over the outrunner, then replace the twin engine wing with the original wing. I should be able to make the SC into two different planes within a matter of minutes. I'll add pics as I make the transformation.. Hopefullly will get some flying pics of it tommorow. Anyone have any ideas about what kind of plane it looks like with the twins and the new nose on it... I can't quite place it...
Bo
Champion Lancer?
Google Champion Lancer.
It's fuuny, I was looking at this the other day and planning to build one with a current project of an Aeronca Champion. I have not seen one modeled yet. Daniel Link http://www.8kcab.com/8KCAB-Hist6.html |
it was like the 2nd pic in the list http://www.superyachttimes.com/edito...article/id/594 |
No Problem.
Taekwondo,
No problem. I kept the cut out foam shapes that I formed the nacells with. Basically, I used a contour guage from the leading edge of the wing back and started from there. The cowls are simply strips of bluecore in a ring with lid glued on then monokote ironed on. I'll take some pics for posting the general idea. But in general, it was not nearly as easy as I thought it would be, however I learned how to do it from building Vyceroy's Sorta Grumman Goose which uses the same methods. I'll try to get them up for Monday. Bo |
Nacelles..
O.k. here it is.. pics of making the nacelles the way I made them for the Super cub. It was kind of down and dirty, but I thought it would make good practice for me to whip up another set. A lot depends on how far the motor, stick mount or whatever kind of mount you're using comes out from the leading edge and what style nacelle you're going for. I was going for one of those semi-square kind of round nacelles like on a Piper Chereokee.. I think..
Hope this helps.. Bo
