Old Sep 11, 2001, 08:53 AM
bhagat_dhillon is offline
Find More Posts by bhagat_dhillon
Oshkosh, WI
Joined Sep 2001
Slow Flight Airfoils
I am a free-flight modeller, currently building a P-40 Warhawk at 18" wingspan. I'd like to make this an indoor flier, with a slower speed than my other WWII models have. To do this I'm considering an undercambered wing.
Any advice?
Thoughts?
Ideas?
Bhagat Dhillon
bhagat_dhillon is offline Find More Posts by bhagat_dhillon
Old Sep 11, 2001, 09:41 AM
Arizona Chuck is offline
Find More Posts by Arizona Chuck
Old Desert Rat
Arizona Chuck's Avatar
Rimrock AZ. USA
Joined Mar 2000
On some plane you can slow it down by not covering the bottom of the wing. It make it act like a under camber. The biggest thing for slow flight in light weight. Nothing will fly slow with a high wing load.
..AZ Chuck
Arizona Chuck is offline Find More Posts by Arizona Chuck
Old Sep 11, 2001, 03:45 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Dave Robelen tested 2 airfoils in the Aug RCMicroflight. Bottom line is that the Benedeck 7457 undercambered airfoil provided 50% more lift than a flat bottomed airfoil with a minor increase in drag.
Turbulating helped both airfoils.
rpage53 is offline Find More Posts by rpage53
Old Sep 11, 2001, 03:57 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Hi,
I second that. Light weight comes first, then a high lift airfoil follows. The airfoil should be thin to avoid laminar separation bubbles and should have reasonable undercamber to give high lift. Some of the older free flight airfoils (Benedek) or perhaps the MA409 (HLG airfoil) should work. I also used NACA 6410, hotwired from styrofoam, which worked good. But for really small airplanes a simple cambered plate might be the best. Do not make it too smooth or use a turbulator at these low Reynolds numbers to avoid laminar separation bubbles!
jberg is offline Find More Posts by jberg
Flight trimming and odd slow flight behavior Jeff Goldman Sport Planes 6 May 09, 2002 02:45 AM
Video on Corona in slow flight... Tom Viper Electric Heli Talk 9 Apr 12, 2002 12:18 PM
Zagi 400X in slow flight Ex-Slimedriver Foamies (Kits) 4 Jan 26, 2002 10:47 AM
Iron on covering for slow flight RCFlybry Parkflyers 3 Dec 07, 2001 01:25 PM
Location of slow flight forum Bleriot Site Chat 18 Jun 12, 2001 07:58 PM
