Old Jun 09, 2009, 02:48 PM
ukeyboy12 is offline
Find More Posts by ukeyboy12
ukeyboy12's Avatar
Strongsville, Ohio
Joined Jun 2007
Help!
CMPro U.S. Navy T-34 Mentor 40 - 58" Nitro Gas Fiberglass Radio Controlled Airplane w
Please Help. I just got for my BD a Nitro plane that i am going to make electric. here is the website for the plane. http://www.nitroplanes.com/new20cmunatm.html
I want to purchase the motor and batteries for hobbyking. the motor i was thinking is either this one a friend suggested http://www.hobbycity.com/hobbycity/s...idproduct=4914
or
http://www.hobbycity.com/hobbycity/s..._(Eq:_4030_AXi)
my friend also suggested two of these batteries in series
http://www.hobbycity.com/hobbycity/s...dProduct=9183#
i would also use a 80amp esc and i would also get a bec.
if anyone can help, please do..im so frustrated i dont know what too do. thanks ahead of time. victor. ps if you know what kind of servos i should use would also help..for the plane and the retracts.. vic
ukeyboy12 is offline Find More Posts by ukeyboy12
Old Jun 10, 2009, 11:02 AM
savas_78 is offline
Find More Posts by savas_78
Athens
Joined Sep 2008
hello i ve recently purchaced the t34 and i will use a 580 kv 50-55 Turnigy motor and 80A esc. As for the batteries i want to use my 4s 4000 packs and then try A123 set up.
savas_78 is offline Find More Posts by savas_78
Old Jun 10, 2009, 01:16 PM
GOK is offline
GOK
Find More Posts by GOK
GOK
Turkey, Izmir
Joined Aug 2005
That looks like a relatively light model at 2600-2800g.
I am no expert at conversions, but if you try and keep her light say at or under 6lb AUW, you might even be able to get away with an axi 2826 10 or 2826 12 equivalent from hobbycity. This would be the sk 3548 900kv motor, I am working on a .46 size p51 conversion currently with this motor but havent tested it yet. In order to keep her light you would need to stick with this lighter motor.
OR!
you can use the 580kv motor but in that case you would most likely want a 5s pack. which will bring the weight up still higher.
I hope I haven't confused you even more
Good luck, and let us know how it goes
GOK
GOK is offline Find More Posts by GOK
Old Jun 21, 2009, 06:36 AM
savas_78 is offline
Athens
Joined Sep 2008
Hello i ve maidened my T34 today, the weather was good and i decided to give it a try. I had a preflight check and taxi to the end of the runway, i applied some throttle to start rolling and thats it, airborne. It is very stable, predictable and enjoyable to fly. I had set my stop watch at 6:00 minutes since it was the first time, i haven't cycled the retracts in the air because i wanted to learn the plane. It was time to land, i made a low pass to see how it settles at low speed and then in the second pass i land it in one piece. The set up worked very well, i have A123 6s2p 4600mah totaly, a lipo 3s 2200 for the receiver and the servos, 580 kv turnigy motor, 80A esc and 13x7 APC prop. The AUW is 3,500gr, 750 watt and about 40A. I charged the packs later on and they took 800mah each at about 20 minutes, totaly 1600mah. I think that i can stay to the air at about 10 minutes. Thanks.
Old Jun 26, 2009, 12:22 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
very cool! ive been thinking about getting one of these!
corsair nut is offline Find More Posts by corsair nut
Old Oct 04, 2012, 08:55 AM
rkopka is offline
Find More Posts by rkopka
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
Some time since then but a question: where did you put the batteries ?
RK
rkopka is offline Find More Posts by rkopka
Article Hangar 9 T-34 Mentor 40 ARF w/ Optional Retracts Review rc2xs Fuel Warbirds 83 Jul 31, 2011 12:31 AM
Discussion CMPro T-34 Mentor FRIDAY_2008 Electric Plane Talk 1 Jan 27, 2009 11:21 AM
For Sale F/S Sapac T-34 Mentor Tail wing set CGReload Aircraft - Electric - Airplanes (FS/W) 0 Jun 29, 2008 11:40 PM
S400 T-34 Mentor mrittinger Scale Kit/Scratch Built 17 Jun 07, 2005 12:13 PM
For Sale;WM T-34 Mentor 40 ARF NIB Warby Aircraft - Fuel - Airplanes (FS/W) 3 May 14, 2004 10:00 PM
