Old Jun 20, 2009, 02:43 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Fan/Motor Testing
I got some motor/fan testing done last night. I have a Neu 1521-1.5y that I bought last Fall for my Falcon 120 that was powered by a single TJ-100 fan. But I didn`t realize that the dia on the 1521`s is slightly larger than the 1515`s so I haven`t been able to test it in the TJ.
Note: My TJ-100`s are very early production models and won`t accept anything larger than the 1515 series motors, but the new versions will, although the motor case has to be turned down a little to fix and Tam can do that at his store.
Anyway, I took a chance and bought an Easy Tiger 100mm fan (the $30 reinforced nylon version) because it said that it would accept the larger motor, and I thought that I might put the TJ rotor in the ET housing at least for some tests.
I decided to first mount the ET rotor. It needed some balancing and needed the blade length to be equalized, but after that it was running smoothly.
I made a quick thrust measuring stand with some cheap drawer guides and a digital fish scale from WalMart. This is nothing fancy and has a little drag, but it gives me a good idea. I used a homemade intake ring that I made for the TJ on the Falcon and it doesn`t fit exactly. There is quite a bump where the fan lip meets the intake ring. So it could be better.
I was very happy with the results.
44.2v
80a
3.5kw
11 lbs of thrust
45k rpm measured with an optical tach
The fans that I`m running on the twin Falcon only give about 9.5lbs for the same 3.5kw on the smaller 1515-2y motors, and I`m only running them at 3kw and about 9lbs..
This (the total 22 lbs of thrust) will be good enough to fly the Rafale for sure, and there is a little more to be had by adding 3.7 more volts for those who know my history. That should push the power up near the 4kw range for each side (8kw total! If that`s not quite enough, I can up-grade my TJ-100 fans to accept the 1524 motor that Tam is working on and get up near 10kw.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 20, 2009, 02:58 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Airframe progress
I`ve decided to make the control surfaces removable so that they can be removed and painted off the plane when I`m ready to paint it. The pin hinges are put together with a small aluminum rivet. I removed one to check the diameter of the rivet and found that it seems to be exactly 1/16th inch dia, so I`ll use a long piece of 1/16" music wire as the pin. So that`s what I`m working on.
Old Jun 20, 2009, 08:34 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Better Motor Test
The test I did last night was just a quick test. I didn`t have an efflux tube attached and I was using the 3500mah zippy packs which took an extra cell to hold voltage near 12s levels at 80 amps.
Today I charged up my new XPS 12s 5000mah pack (this is 3 x 4s) and installed a proper efflux tube. I used a 74mm exit dia. I`ve ordered a new V3 air-speed sensor from Eagle Tree. I`ve very interested in the efflux speeds. The force against my hand held in the efflux behind the fan is tremendous.
The results after about 30sec of run-time were...
4040w (just over 4kw)
44.4v (packs held 3.7 per cell at 91 amps!!)
91a
10.5 lb thrust (lower thrust expected with efflux tube)
To say the least the XPS packs performed awesome!! I only did the short test because I want to break them in carefully.
I`m plenty happy with this motor. It weighs 5.5 oz more than the 1515 motors so it can handle longer stretches at these power levels than the 1515`s can.
This is exactly the power level that I was looking for. I`m guessing that on 13s the power would increase to approx 4.7kw (47v @ 100a). May have to try that someday with a CF rotor.
Old Apr 22, 2012, 01:51 PM
shamu is offline
Find More Posts by shamu
Joined Oct 2009
Hi Knife,
whats happend to your Projekt? I am also thinking of Building a SM twin Rafale...
shamu is offline Find More Posts by shamu
Old Apr 22, 2012, 02:08 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Well I hacked it up to fit a pair of 127mm fans in it. Now that power levels are way up on the 90-100mm fans, I wish that I would have left it stock. Still haven`t finished it. I think the stock airframe with a pair of 4kw 90mm fans would be an awesome jet.
Old Apr 23, 2012, 12:18 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Nice build! I attempted a Flyeagle Rafale with a Stumax fan. I gave it up because I wasn't able to fabricate intake ducting and couldn't find anyone to make me a set. Did you find a set that would fit 90mm fans?
techspy is offline Find More Posts by techspy
Old Apr 23, 2012, 06:47 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Check with Tamjets. I think that Barry worked on a set for Tam.
Old Apr 26, 2012, 10:14 AM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
I know this plane will be ballistic...........Remember I followed your twin build on the Falcon 120 and installed two 90mm Wemos/ARC motors in my falcon..........too danged fast for me so I removed them and went back to a single fan..........
Godd luck and I am following this thread.....we want video of course.
Madmax1965 is offline Find More Posts by Madmax1965
Old Sep 16, 2012, 03:18 PM
shamu is offline
Joined Oct 2009
Hi all,
Plane arrived at my door :-)
Here are some pictures from the factory...
My plan is to build here with twin Stumax 100-45 and HET 700-83-975. This setup is good for 6,5 kg thrust each.
Retracts will be converted to electric with Lado series 666 and also gear doors i will do with Lado.
@Knife Liddle: If it is okay, i will continue my build here in your tread...
Bye
Stephan
Old Sep 16, 2012, 04:36 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
I like the color scheme. Like I said, I wish I would have left mine stock now that I have some strong 90-100mm fans that would be perfect for it. I`ll enjoy your build. It should be a nice project.
Old Sep 21, 2012, 07:36 AM
shamu is offline
Joined Oct 2009
LADO retract conversion
Hi all,
here are some pics from the retract conversion with the LADO e-cylinders.
just disassemble the retract, drill a new 6-32" thread in the "cross bolt" (dont find a better word ;-) ) and assemble the retracts. All togehter in just 30 minutes :-)
Old Sep 21, 2012, 11:31 AM
Liebrein is offline
Find More Posts by Liebrein
Weidenbach, Bavaria
Joined May 2007
Hey Stephan,
wow, looks nice, looking forward to see it in person.
BR
Reini
Liebrein is offline Find More Posts by Liebrein
Old Sep 22, 2012, 01:30 PM
shamu is offline
Joined Oct 2009
Canards
going on with Canard installation...
Old Sep 25, 2012, 02:13 PM
shamu is offline
Joined Oct 2009
Front Gear installation
When fhinished with main Gear i also will post a video of gear operation...
Old Sep 26, 2012, 09:04 AM
shamu is offline
Joined Oct 2009
Main Gear
Hi all,
just mounted the main gear and removed the turbine shelves :-)
I moved the main gear a bit forward to better rotate at start. Thanks Gregg :-))
Build Log Thermal Studios - Reiher 1/7.5 Puget Sound Flyer Sailplane Talk 16 Nov 10, 2009 10:28 PM
Help! OLD K&B 7.5, 8702 model...how to check and refurb frd1952 Racing Boats - Internal Combustion 9 Feb 26, 2009 07:40 AM
Cool Victor Stanzel Co.(or how I spent my summer vacation) CashRC Vintage & Old-Timer Designs 10 Aug 31, 2008 08:47 PM
Wanted k&b 7.5 parts or complete motor 185mitch Boats (FS/W) 11 Dec 05, 2007 07:14 PM
Source for a 5,6, or 7 to 1 Gear Box for a sp400? rsieminski Power Systems 1 Feb 07, 2002 01:17 PM
