This thread is privately moderated by customrcparts, who may elect to delete unwanted replies.
Old Jun 09, 2009, 12:29 AM
customrcparts is offline
Find More Posts by customrcparts
Trader Rating: 0
customrcparts's Avatar
Renton, WA
Joined May 2009
Trader Rating: 0
For Sale
Hobbyzone Super Cub Motor upgrade
This is a custom cnc machined motor mount that lets you install an EFlight 450, 480 or Turnigy 3536 on your Hobbyzone Super Cub.
Very simple to install.
Very lightweight (.6 oz).
All fasteners included.
To maintain the thrust line, the compound angle that matches the stock motor is machined into the mount.
There is no need for shims or spacers.
Buy it here: CustomRCParts on EBay
on EBay ($20.00 + $2.00 shipping)
or
RCGroups discount $20.00 including shipping (PM me and we'll make arrangements with or without EBay).
Check out CustomRCParts for information about this motor mount and other custom products I offer.
customrcparts is offline Find More Posts by customrcparts
Old Jun 09, 2009, 03:40 AM
gotboostedvr6 is offline
Find More Posts by gotboostedvr6
Trader Rating: 34
zoom zoom
gotboostedvr6's Avatar
USA, NJ, Mt Laurel
Joined Oct 2007
Trader Rating: 34
Are you accepting vendor inquiry's?
gotboostedvr6 is offline Find More Posts by gotboostedvr6
Old Jun 09, 2009, 07:40 AM
Olias is offline
Find More Posts by Olias
Trader Rating: 31
Pushin' the Limits
Olias's Avatar
Bellingham,WA.
Trader Rating: 31
Hello from up North! I'm thinking of ordering a couple of these but I want to make sure of something first. The info. here states that it fits the Turnigy 3536 as well as the E-Flite Park 480, but the info. on Ebay makes no mention of the 3536, on the 2 different E-Flite motors. I have both those motors on 2 different SC's and want to be sure before I order any that it will indeed fit both motors.
Bryan
Olias is offline Find More Posts by Olias
Old Jun 09, 2009, 10:28 AM
Trader Rating: 0
Renton, WA
Joined May 2009
Trader Rating: 0
Bryan,
Yes the Turnigy 3536 does fit this motor mount. I hadn't advertised that on EBay because I haven't test flown with that setup. I did have an inquiry about this setup so I installed one on my Super Cub and made a tutorial about how to do it. You can see it at www.customrcparts.com under the airplane section then click Super Cub.
The person that inquired about using a 3536 said he'd been using one on a competitors mount and worked fine. My concern was that only 2 screws attach the motor to the mount. He said that he's never had a problem with that. He purchased one of my mounts and plans on using it with the 3536.
Regards,
Gary
Bryan
Old Jun 09, 2009, 10:29 AM
Trader Rating: 0
Renton, WA
Joined May 2009
Trader Rating: 0
Absolutely! I got your PM and responded.
Regards,
Gary
Old Jun 09, 2009, 10:42 AM
Olias is offline
Trader Rating: 31
Pushin' the Limits
Olias's Avatar
Bellingham,WA.
Trader Rating: 31
Gary, thanks for your fast reply. Ok, if I understand this all correctly you're saying that the Turnigy 35-36 will work but by using ONLY 2 screws. Correct? If so, I'm wondering if there's enough room next to the existing holes to drill 2 more so the Turnigy can use all 4 holes/bolts. Hey...what about ordering one witrhout any holes from you!? Is that possible? Thanks
Bryan
P.S.
Sorry, I should probably be P.M.'ng these questions, ya?
Old Jun 09, 2009, 11:11 AM
Trader Rating: 0
Renton, WA
Joined May 2009
Trader Rating: 0
Bryan,
Unfortunately, there is no place to add the two extra holes. The "legs" are right where the holes need to be. As for ordering one with no holes, I could do that on my next run.
PM-ing isn't necessary. These are good questions!
Gary
Old Jun 09, 2009, 12:53 PM
Olias is offline
Trader Rating: 31
Pushin' the Limits
Olias's Avatar
Bellingham,WA.
Trader Rating: 31
Gary, again thanks for the info. I see what you are saying. That graphic helped a LOT! Ok, I think what I'll do is wait until you make some more and get one with no holes as I am also going to modify one of these to hold a ParkZone 480 Brushless (out of my Corsair). With a blank one without holes I can compare the 2 (Turnigy and ParkZone) to see how close they are. I'm good right now for my E-Flite with the home made mount that I've made.
So, I guess the next step would be to just PM if you would please when you are going to have a blank one available. Sound good? I'm in no hurry so don't worry about it.
Bryan
Old Jun 09, 2009, 02:38 PM
Trader Rating: 0
Renton, WA
Joined May 2009
Trader Rating: 0
Sounds good. Maybe you could ping me in a couple of weeks to check in.
Take care and happy flying!
Gary
Old Jun 10, 2009, 12:10 AM
race58 is offline
Find More Posts by race58
Trader Rating: 41
race58's Avatar
USA, IL, Huntley
Joined Feb 2006
Trader Rating: 41
Like Olias I would be interested in one with no holes.
Would your mount line up with this? http://www.headsuprc.com/servlet/the...unt-for/Detail
Or this? http://www.bphobbies.com/view.asp?id...7&pid=B2632605
Using the X-Mount.
race58 is offline Find More Posts by race58
Old Jun 10, 2009, 12:38 AM
Trader Rating: 0
Renton, WA
Joined May 2009
Trader Rating: 0
If I am reading the mounting information on the links that you provided, the hole pattern on the motors are 16mm X 19mm. These would fit my mount without using the X-Mount. The only issue may be the length of the motor. My mount is designed for a motor that is 1.62" (42mm) from the base of the motor to the face on the prop adapter. Also, my mount is designed for 3mm screws. The 2.6mm shouldn't be a problem though.
Gary
Old Jun 11, 2009, 12:20 AM
Mixednutz1 is offline
Find More Posts by Mixednutz1
Trader Rating: 0
!!BEWARE!! NOOB PILOT AM I
CANADA "EH"
Joined Jan 2009
Trader Rating: 0
Would this product work on other ParkZone models? I have the FW-190 whose motor mounts look very similar.
Mixednutz1 is offline Find More Posts by Mixednutz1
Old Jun 11, 2009, 01:55 AM
Trader Rating: 0
Renton, WA
Joined May 2009
Trader Rating: 0
I looked up the FW-190 and the Hobbyzone site says that the motor mount is the same for the FW-190 and the Spitfire. I have installed this on my spitfire and it works. I haven't found a spinner that will maintain the stock look though... As far as I know, the Super Cub and the Spitfire use the same motor/mount so it would stand to reason that it will work on the FW-190.
