This thread is privately moderated by gtfreeflyer, who may elect to delete unwanted replies.
Old Jun 09, 2009, 12:07 AM
gtfreeflyer is offline
Find More Posts by gtfreeflyer
Put a bigger motor on it!
gtfreeflyer's Avatar
Costa Mesa, CA
Joined Feb 2007
Build Log
Quic Fly by Phil Kraft
Here's my latest project. First of all, thanks so much to Carl for giving me this kit for free after knowing me for only 2 or 3 days. So kind of him This is the Quic Fly vintage RC plane designed by Phil Kraft many many years ago.
The first photo is of Carl's Quic Fly. It has a fully sheeted and glassed fuselage, painted to match the monokote wing. The wing is glassed where ever there is balsa sheeting underneath. Carl let me fly this plane and it flies like it's on rails. It's a real good flyer.
I'll be building my Quic Fly for electric power, and I'll add retracts. My paint/covering scheme will also be quite different.
gtfreeflyer is offline Find More Posts by gtfreeflyer
Old Jun 09, 2009, 12:21 AM
Costa Mesa, CA
Joined Feb 2007
Ailerons
The leading edge of the aileron is slanted and hinged towards the top, rather than the usual V-shaped or rounded leading edge which is hinged in the middle. This leaves a very tiny gap on the upper surface between the trailing edge of the wing and the leading edge of the aileron, but a bigger gap on the lower surface.
The leading edge of the aileron is also more than 1/2" tall which is taller than most control horns. This gave me the idea to try a completely internal aileron linkage - something I've never done before but always wanted to. If I could somehow attached the aileron pushrod to the lower surface of the aileron, I should have enough aileron travel with the hinge being at the top.
I took a plastic pushrod clevis and cut off the little pin at the tip of it. I drilled straight thru the existing hole in the clevis, creating two holes in-line on both the clevis lugs. I cut off a piece of pushrod wire and placed it inside the aileron, and this passes thru the holes in the clevis lugs creating a nice pinned joint.
It worked out great! See the pics...
Old Jun 09, 2009, 12:30 AM
Costa Mesa, CA
Joined Feb 2007
Retracts
I started toying around with the placement of the retracts. The pics show what I'm currently planning. The landing gear wire is bent aft as shown because that's how it was on my Sportster that crashed (see my Sportster blog for the great crash pics). I should be able to use these same retracts that were on the Sportster. So far it looks like they will fit nicely without having to bend the landing gear wire at all.
I also hope to attempt to make gear doors. This is something I've never done before. I usually get lazy and in a hurry to finish the plane when building, and I tend to skip details like gear doors since they aren't necessary for flight. With two other planes in my garage ready to fly, I hope to be in no hurry with this plane and hope to make the gear doors. We'll see.
Old Jun 09, 2009, 10:32 AM
pyrobus is online now
Find More Posts by pyrobus
outstanding in the left field!
pyrobus's Avatar
USA, IL, Marengo
Joined Feb 2007
Nice work
Love the planes. Carls looks very nice and yours will be excellent too!
Very fun aircraft and a timeless design.
Cheers!
Pyro
pyrobus is online now Find More Posts by pyrobus
Old Jan 03, 2010, 01:10 PM
Asger is offline
Find More Posts by Asger
Joined Jan 2010
Kraft retractable landing gear
Har hatt anlegget liggende i 20 r har nu tenkt bruke det, er der nogen som vet hvordan man fr det til virke fra futaba radio aux canal.
Asger is offline Find More Posts by Asger
Old Jan 03, 2010, 08:20 PM
Costa Mesa, CA
Joined Feb 2007
Translation?
Giant Glider Fly-by video from Lite-Stik Cam view jas_Qfix Parkflyers 8 Jun 30, 2001 07:40 AM
Fly-by-video Close-call of a PusEcat and a Cow-on-handglider jas_Qfix Electric Plane Talk 3 Jun 24, 2001 11:54 PM
Close call of PusiEcat and Cow-on HandGlider .. fly-by video jas_Qfix Parkflyers 0 Jun 24, 2001 01:59 PM
Pico Stik mod Lil-Hornet look-a-like Fly-By Video jas_Qfix Electric Plane Talk 5 Jun 22, 2001 10:16 PM
Lil_Hornet look-alike fly-by video jas_Qfix Parkflyers 8 Jun 21, 2001 08:21 PM
