Old Jan 25, 2010, 09:46 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
gobigkahuna, we recently added firmware to our "Flight Data Recorder" to monitor a 3 axis digital compass and display a heading. The performance of this compass (HMC6343) is not too satisfying, though. Acceleration, tilt/roll, vibration, etc., seems to cause quite a bit of variation in the compass reading. The plan was to port the firmware over to our eLogger and OSD Pro, but more investigation is needed to determine if another compass would work better.
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jan 26, 2010, 12:19 AM
gobigkahuna is offline
Find More Posts by gobigkahuna
United States, CA, San Diego
Joined Nov 2008
Thanks for the update Bill. Would the compass performance be any better at slower vehicle speeds? My application would be to use this in an underwater robot (max speeds around 2-3 knots). The only other 3 axis digital compass I know of with reportedly good performance are the ones by Ocean Server ( http://www.sparkfun.com/commerce/pro...oducts_id=8960 ) which cost $100 more than the HMC6343 and output NMEA sentences instead of I2C.
gobigkahuna is offline Find More Posts by gobigkahuna
Old Jan 29, 2010, 06:03 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
gobigkahuna, the compass performance issues were due to the wild and crazy forces encountered in an aircraft, I believe. I suspect the HMC6343 would work well in your slow moving robot.
It's quite easy to wire up the HMC6343 board from sparkfun.com to our car data recorder. The support for that is in an alpha version of the software.
Regards,
Site Sponsor
Old Jan 30, 2010, 03:12 AM
Joined Nov 2008
Thanks Bill. I'm actually more interested in an OSD Pro. Any idea if / when the code will be ported?
Old Feb 05, 2010, 07:50 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
gobigkahuna, it should be working now with the OSD Pro. I think we are in email contact also?
Regards,
Site Sponsor
Old Feb 06, 2010, 02:51 AM
Joined Nov 2008
Yes, I got your email. Thanks very much.
Old Jul 25, 2010, 12:48 PM
xenonfire is offline
Find More Posts by xenonfire
Joined Feb 2009
Eagle Tree magnetic compass??
I have OSD pro and I need magnetic compass.
In an old thread i saw that i could use HMC6343 to get a compass in my submarine.
Does this work?
Where could I buy this HMC6343 and is there any schematic of this?
Thanks in advice!
xenonfire is offline Find More Posts by xenonfire
Old Jul 26, 2010, 04:43 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi xenon, we have some support for the HMC6343 board which is available from sparkfun.com. You'll need to solder on a diode to the board to make it work, however.
Site Sponsor
Old Feb 05, 2013, 07:42 PM
cwleveck is offline
Find More Posts by cwleveck
cwleveck's Avatar
United States, OR, Salem
Joined Aug 2010
Um, so just out of curiosity...... what other "hidden" sensors may have support within the current alpha software? The reason I ask is because I am working on some fairly complicated systems and would love to be using eagletree for my "production" product instead of just for testing. I mean if there is more support for sensors or a way for us to gain access to the data stream for use with microcontrollers or even just to be able to display the data on an additional device without having use the picture, or being able to tx the data without having to use my video stream would be awesome.
cwleveck is offline Find More Posts by cwleveck
Old Feb 07, 2013, 03:35 PM
billpa is offline
billpa's Avatar
Joined Nov 2003
Hi, the HMC6343 did not work well. We're working on a more integrated compass solution now.
Re other sensors, could you let me know what you might be needing? Feel free to email me if that's better.
Site Sponsor
Discussion How do I transfer Data from Fut 9chp - Fut 9chp with cam- pac ? djdaveq Radios 4 Aug 21, 2008 12:18 PM
Monokote Glue,How to remove glue from top covering? speedo Electric Plane Talk 4 Apr 11, 2002 08:27 AM
Have Whatt Meter, how to interpret data? ErnieR Power Systems 11 Mar 14, 2002 06:08 AM
how to remove econocote from my twinstar flyer10 Foamies (Kits) 1 Apr 21, 2001 12:54 AM
