Old Jun 08, 2009, 08:34 AM
Maylord is offline
Find More Posts by Maylord
Joined Sep 2008
which battery for ducati silverlit 1:12?
hi guys, sorry but the autonomy of the original battery is only 5/6 min, it's possible change the battery? where it's possible buy? thanks!
Maylord is offline Find More Posts by Maylord
Old Jun 08, 2009, 10:48 AM
cip060 is offline
Find More Posts by cip060
Joined Apr 2006
ma dai non trovi le batterie da sostituire??
http://www.rcgroups.com/forums/showthread.php?t=935648
cip060 is offline Find More Posts by cip060
Old Jul 21, 2009, 10:51 AM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
As I've just written this note to myself, I may as well post it here, even though the question is six weeks old:
Battery
"Shida NiMH 4 x 1/2 AAA 4.8V 220mAh" arranged 2x2 inline
The JST plug is reverse wired!
The charger charges in around 20-45 mins (apparently - didn't time it). It blinks while charging then stops. No idea if it keeps trickling.
To charge other 4 cell batteries, I'd need a reversing lead. No idea if it survives having a none-reversed pack plugged into the charger.
I'd also need a reversing lead to charge with my Apache charger. It should be safe to get it wrong with that one though.
Overall pack dimensions
48mm long (inc end caps) x 10.5mm thick in the middle (cell diamter + shrink wrap)
21.9mm wide and 11.5mm thick including end caps
Exposed wire of JST lead is 25mm long, so about 30mm of wire.
The closest match to the cells in the UK is www.component-shop.co.uk 210mAh 1/2 AAA (under Batteries->Radio control->Single cells):
1.2V 210mAh NiMH 1/2AAA Single Cell
22mm long x 10.3mm diameter with solder tags.
0.80 each.
0.74 discounted price for 10+
0.68 discounted price for 50+
- price is around $1 per cell.
Add some cardboard and tape for end caps and maybe some heat shrink.
Andy2No is offline Find More Posts by Andy2No
Old Aug 05, 2009, 11:06 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I bought some of those 210mAh 1/2 AAA NiMH cells made up as 4 cell packs, arranged 2x2, then rearranged them to fit. Not quite as good as the original but still pretty good:
http://www.rcgroups.com/forums/showt...4#post12731084
Discussion silverlit ducati desmosedici 1:12 jack-69 Motorcycles 26 Aug 08, 2008 05:19 PM
What battery for my XR-1. jmatteson Micro Helis 3 Jul 21, 2004 10:03 AM
Question What battery for 480 liteflyer Batteries and Chargers 2 Oct 29, 2002 09:42 AM
What batteries for the omega 1.8? Giovanni Day Electric Sailplanes 1 Jun 02, 2002 11:17 PM
What battery for a 480 motor... tnsfrk Electric Plane Talk 9 May 28, 2001 12:41 AM
