Old Jun 07, 2009, 09:01 PM
h_bondok is offline
Find More Posts by h_bondok
h_bondok's Avatar
Canada, AB, Calgary
Joined Dec 2008
how to connect an ESC with BEC to a receiver.
Hi guys,
I have problem with my new transmitter. the receiver is designed for ESC without BEC and it was working well.
unfortunatly my ESC without BEC had been broken down (not because of crash ) and i do have ESC but with BEC. some folks tould me to dis connect the red wire coming from the ESC to receiver to disable the BEC but it doens't work with me.
Experts, could you please help me out .
below is the transmitter picture.
h_bondok is offline Find More Posts by h_bondok
Old Jun 07, 2009, 10:02 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
BEC just supplies RX power... generally regulated 5.0 v, up to the current limit of the BEC.
The RX pictured should have no issues with that.
The first/easiest problem you could be having is signal/- reverse plugging the ESC into the RX.
The RX can even be powered up by the BEC and operate servos with the ESC plugged this way but the motor would not respond.
If you plug the ESC backward... then following the color code of the ESC you would plug all the servos backward and the RX's LEDs will work, but it won't move any servo.
No damage to this point... just unplug the ESC and servos... ONE AT A TIME, reversing the black vs white (Futaba color code) wire order and replugging.
(brown vs lightest orange if JR color code... Black vs yellow if Hitech color code)
See if that gets you functioning...
Whatever is supposed to normally supply power to the RX... (since your old ESC reportedly had no BEC) can be plugged in, along with one servo.
Make that servo work. If you can't make a servo work off of the other power supply, then you can't make the ESC work with the red (center) wire disabled.
Basicly... I doubt its the new ESC's fault that things are not working. And your old ESC may also be fine.
You might have some other issue that made you THINK the ESC was bad...
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jun 12, 2009, 12:37 PM
h_bondok is offline
h_bondok's Avatar
Canada, AB, Calgary
Joined Dec 2008
Hi fhhuber506771,
i had replaced the ESC and considered your advice, finally it works now.
thank you buddy.
Discussion How to Connect an ESC & Separate BEC Model Aero Power Systems 16 Sep 25, 2009 12:57 AM
Discussion how do you hook an ESC with built in BEC up to the reviever? (youtube video included) at3buell Scale Kit/Scratch Built 10 May 08, 2008 09:43 PM
Discussion how do you hook an ESC with built in BEC up to the reviever? (youtube video included) at3buell Electric Plane Talk 6 May 08, 2008 09:42 PM
Discussion How to use an ESC without BEC mnahmia Power Systems 3 Apr 08, 2007 03:07 AM
Discussion How many servos my ESC with BEC can support? VRflyer FPV Talk 8 Jan 06, 2007 10:58 PM
