Old Jun 07, 2009, 08:19 PM
41North is offline
Find More Posts by 41North
Dumb lipo charger question - 1s, 2s, 3s battery chg rates
My DN Power balance charger fills 1-4 cell lipos at .2A to 2A rates in .2A increments.
Now, I get that lipo's like to see rates of 1c or less. I have some 1s, 2s and 3s batteries. I've been selecting charge rates of 1/100 of the mAH rating or less on all of them. But pondering what's going on... Isn't the mAh rating of a muli cell series wired battery the sum of all the cells?
The charger display seems to indicate the charge rate per cell. If I'm dumping .8A per cell into an 800 mAh 2s battery, isn't that 2c?
Or have I forgotten basic electronics?
41North is offline Find More Posts by 41North
Old Jun 07, 2009, 11:40 PM
sparkie624 is offline
Find More Posts by sparkie624
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
In regards to the MAH rating to multi cell. I think you see it wrong if I am interpeting you correctly... For an 800 mah 3 cell, each cell is 800 mah being in series, at 3.7 volts each makes it 11.1 volts. In series Voltage adds up, in parallel current adds up and volts remain the same.
sparkie624 is offline Find More Posts by sparkie624
Old Jun 08, 2009, 04:27 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
I hope you mean 1/1000th of the mAh e.g. 2A for a 2000mAh battery, because 1/100th is 10C and could be deadly .
Anyway in a SERIES connection the VOLTAGE is the sum of the individual cells and the capacity (mAh) stays the same. E.g. 3 x 1000mAh 3.7V cells in series gives 11.1V @ 1000mAh
In a PARALLEL connection the CAPACITY (mAh) is the sum of the individual cells but voltage stays the same e.g. 3 x 1000mAh 3.7V in parallel gives 3.7V @ 3000mAh.
Steve
slipstick is offline Find More Posts by slipstick
Old Jun 08, 2009, 09:40 AM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
41 - Also keep in mind that your DN charger charges cells seperately so what you see, regardless of the # of cells in a pack, is what you get. Your display even shows you the amps going into each cell during a charge.
Also, the DN's (and CellPro 4S's) chargers can safely charge at 2C and 3C without any issues as each cell is charged seperately so all cells are balanced when the charge is complete.
Rick
rampman is offline Find More Posts by rampman
Old Jun 08, 2009, 05:28 PM
41North is offline
Thanks, all. It makes sense now.
For Sale Eflite Celectra 1S/2S/3S Lipo charger CuStOm Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 13, 2009 10:55 PM
FS: Kokam Lipo charger and Etec 1200 3S dw1122 Aircraft - Electric - Airplanes (FS/W) 11 May 28, 2004 02:28 PM
Lipo/charger question Charger Batteries and Chargers 2 May 28, 2004 08:37 AM
FS- NIB Apache 1215 Lipo charger and New 2S Kokam 1500HD pack Etonic Aircraft - Electric - Airplanes (FS/W) 4 Mar 06, 2004 08:58 PM
Scott Henion's DIY LIPO charger question rcnutt Batteries and Chargers 5 Dec 16, 2003 06:35 AM
