Old Jun 07, 2009, 09:15 AM
ggofish is offline
Find More Posts by ggofish
Ggofish
Anderson, Texas
Joined Jun 2009
Need info on a bait deployment boat for the surf.
I'm new to the board of RC. I'm a shark fisherman that surf fishes for large sharks on the Texas coast. We generally use kayaks to take out shark baits from the beach to 500+ yards out in the surf. The problem is that on some days are too rough to use the kayak for bait deployment. My past experiences kayaking heavy surf has landed me in the ER, So ...no more heavy surf for me. My idea is to build my own boat that will be at least 6' in length with 2' wide for heavy surf applications. I need info on what kind of radios and servos to use that will range out to 800 yards in the surf. NOBODY in the US has developed a boat like this for surf fishermen. I plan on using salt water trolling motor in front with a rudder in the back to keep line tanglement from happening. A small car battery should be enough to propel baits out that will be about 5 lbs of payload and 5-8 lbs of line drag. If somebody can and will help me with this project, It would be appreciated. This is not a joke....serious problem solving required from you.
Ggofish
ggofish is offline Find More Posts by ggofish
Old Jun 07, 2009, 10:13 AM
lightthings is offline
Find More Posts by lightthings
Joined Oct 2008
I won't be much help but I will do what I can.
First, Some states have made it illegal to use R/C to aid in fishing. I am very unclear about this and it most likely will depend on your state regulations, statutes and laws. Check with your game and fish department for more info involving the use of R/C in this matter.
Having lived on the Gulf Coast and done some surf fishing myself, I understand the problems you face and this may be quite a project indeed.
I have considered using R/C for calm freshwater fising to get the bait or lure to places under brush that one cannot cast towards for fear of losing the bait/lure and the time to repair. I was told I cannot use R/C for this.
Surf conditions on the other hand are very different. I would never consider those conditions to be safe for model boating.
Still, It probably can be done if one were to put their mind to it.
As for radio, most brand name radios for R/C cars will be able to maintain good contact with the craft for as long as you can see it.
Things to consider are:
Water proofing. Salt water can be a beast on the equipment used.
Rip tides and undertow besides the surface conditions.
Vision: Lights could be helpful except on sunny days. Also one must be able to see the craft to be able to make decision on what action to take and when to take that action. At a hundred yards, an object that is 6'X2' will not appear very large at all and trying to decide which is front and which is back in bobbing surf will not be easy. As you multiply this distance the problem grows.
In the troughs between swells, you may not be able to see the craft.
Something like a bicycle flag (do they still make those?) would help with visibility.
That is what I can come up with from the top of my head.
As for the mechanics and hardware, I hope someone else can be helpful to you.
P.S. I have enjoyed shark fishing myself. We used bonita for bait. You?
LT
lightthings is offline Find More Posts by lightthings
Old Jun 07, 2009, 10:36 AM
ggofish is offline
Ggofish
Anderson, Texas
Joined Jun 2009
LT,
Thanks for the response. I shark fish at Follites Island near San luis pass between Galveston and Surfside Beach Texas. Far as building a fiberglass boat will not be a problem. Electronics will be water proofed to the max. I will not launch the boat in heavy surf...but medium surf with breakers breaking to the forth bar at max. We both know sharks run about 100 yards past the 5th bar in about 20' of water. I have a 20 ' car hauler that has been converted as an RV with a roof to stand on which is about 12' high....do the math. I will not be a problem seeing the boat in the surf. I don't know anything about RC electronics period, but I do know electronics far as 12 volt systems go. My plan is to build a boat 6-8' boat with a bait holding chamber in the back that will be spring loaded for line pulling out the bait and weights to fly out the bait box when required. There is no law against bait deploying with RC boats in Texas waters that I know of, just that you can not fish with them. If I have to, I will put TX # on the boat to be legal because it will be a motorized boat. We use 9/0 penns with 130# braid and 80 mono. Sting ray and mullet are a favorite bait for us down here.
Old Jun 07, 2009, 10:47 AM
Joined Oct 2008
Seems there have been a lot of guys doing R/C fishing since last I checked!
You might want to get in touch with these guys:
http://www.rcfishingworld.com/
They are doing what you want to do on a smaller scale in fresh water. Perhaps They could advise you.
Also there are a lot of videos on youtube regarding fishing and R/C. Pretty entertaining. Perhaps you could get some ideas there as well.
Here are a few to get you started.
Remote Control FISHING PHENOMENON (1 min 15 sec)
redneck rc boat fishing (0 min 52 sec)
Lazy Man's Fishing (3 min 14 sec)
Fishing with R/C Boats! (The R/C Fishing Pole" (1 min 19 sec)
Old Jun 07, 2009, 11:03 AM
ggofish is offline
Ggofish
Anderson, Texas
Joined Jun 2009
Good ideas, but a little under scale. Can you imagen a 8' bull shark taking them boats down....LOL. I need info on servos and trans mitters for a 12 volt system. Ideas wanted.
Old Jun 07, 2009, 11:52 AM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
Tricky, but it could be done... I already built 2 bait boats, different principles, and it works like a charm. For your needs, you need to go for a design similar to the one in the picture: unsinkable rescue boat. Very low CG, bottom heavy. You can use a standard prop in the back, as long as it is a Kort nozzle: easy to protect, all the thrust you need. For the bait, get some ideas from the pics. It is a new unfinished version (have no idea when I will finish it) with a bait delivery system based on a dual swing door. Blow this up and it could do what you are after...
CornelP is offline Find More Posts by CornelP
Old Jun 07, 2009, 01:32 PM
ggofish is offline
Ggofish
Anderson, Texas
Joined Jun 2009
Here is my design for the boat....
Old Jun 07, 2009, 03:03 PM
CornelP is offline
CornelP's Avatar
Bucharest, RO
Joined May 2009
The only problem I see is the interface with the motor. You want to be able to control speed and stop. Maybe going for a mechanical link between speed controls and a hi torque servo will do the trick. Same for the steering: you are looking at some serious servo... As for design, it is going to self level, so it is ok, but do not make it too wide. Just make it a little more round around the corners, for strenght purposes.
Old Jun 07, 2009, 04:45 PM
cos918 is offline
Find More Posts by cos918
cos918's Avatar
abingdon england
Joined Feb 2008
Hi there this has been talk about before see link. The short of it is the boat is going to have to be so over engineered to surf the surf it going to cost a lot . That idea having a prop hanging down is a non starter it will get smashed props need to be in tunnel like the have on the RNLI life boat , they can take one hell of a pounding.
John
http://www.rcgroups.com/forums/showthread.php?t=865029
cos918 is offline Find More Posts by cos918
Old Jun 07, 2009, 06:05 PM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
I think your basic idea may be sound, a few thoughts.
I would use the smallest trolling motor available due to current draw and you are not pushing a man/full sized boat around.
Lose the rudder, control the direction by rotating the motor, servo city has high torque servos that will rotate the motor.
http://www.servocity.com/html/bottom...wer_gearb.html
as an example.
To control the speed you may have to hack the throttle mechanism to allow a servo to operate it.
Either a 3rd servo on separate channel or full rudder plus trim input can be used to release the bait hatch(only needs 2 channel radio)
Cage the prop aka surf rescue rubber ducky's to protect it and help from getting the line tangled.
Make the top higher like the lifeboat pictures but keep all the weight down low, the trolling motor will act like a sail boat keel helping even more to keep the vessel upright in the surf.
As long as the hull is watertight, a small hatch to access is better than splitting the whole hull, use hockey tape to seal the hatch before a mission. Keep the watertight internal box as well.
Don't use a car battery, choose a sealed lead acid/gel/AGM battery for safety, the boat will roll and you don't want spilled battery acid sloshing through the boat. They are available in large sizes as well.
Something around 20 to 30 Ah capacity will give you around an hours use at full throttle on a small trolling motor. Use straps or other method to secure the battery so it cant move regardless of the boats attitude.
Regards
Nick
nick_75au is offline Find More Posts by nick_75au
Old Jun 07, 2009, 06:14 PM
ggofish is offline
Ggofish
Anderson, Texas
Joined Jun 2009
Is there a gas powered chopper that can lift 15-20 lbs or so out there? That would work!!!
Old Jun 08, 2009, 12:02 AM
toesup is offline
Find More Posts by toesup
USA'd ex Brit
toesup's Avatar
Back.. In California
Joined Aug 2006
Radio's (FM and 2.4) should be able to operate at that range, they (in theory) should be able to operate as long as you can see the boat....
Question is, can you tell (see?) the orientation of a 6ft long by 2ft wide object, in rolling surf at nearly half a mile away?
toesup is offline Find More Posts by toesup
Old Jun 08, 2009, 03:13 AM
capntroy is offline
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
You'll need to install a surfboard type skeg in front of the trolling motor to take the brunt of the impact when you surf it back into the shore.
You can even get fancy and have a grounding plate that sits under the trolling motor and is supported by three legs back to the hull.
This will also give you something to sit the boat on at the beach without damaging the trolling motor.
capntroy is offline Find More Posts by capntroy
Old Jun 08, 2009, 09:20 PM
tigerbay is offline
Find More Posts by tigerbay
Joined Sep 2006
Some thoughts. Immediate and off the wall
I really have no idea what I am talking about.
As suggested a high superstructure for visbility.
Paint it four colors. So from above it is divided along Centre line and amid ships across the beam.
Learn your colours and you will always know your orientation.
Power. (I think your biggest problem)
Will a trolling motor have enough power to push through the surge at the beach?
Probably not on 12v, perhaps on 24v.
Also how long will it take to go out 800m and return?
Then work out how many trips your boat needs to make.
Heavy boat may not be a problem, it will have more inertia, which may help with the surge.
A skeg was mentioned. Perpaps a full length keel would help her keep going straight. The motor could then be mounted between tow sections of keel to keep it off the bottom.
You mentioned a gasser. See if you can buy a salvaged jet ski. Rip the guts out of it. That will give you a jet drive. And should be powerful enough to punch through the surge.
A few big cheap servos (from 1/4 scale aircraft) should be able to operate the throttle and steering.
OPTION 2
A darned big sailboat.
The storm winds will give you a lot of drive, and battery life will not be an issue. It will also be more visible
tigerbay is offline Find More Posts by tigerbay
Old Jun 09, 2009, 05:30 AM
gobigkahuna is offline
Find More Posts by gobigkahuna
United States, CA, San Diego
Joined Nov 2008
How about a tethered, rc controlled, helium or hot air blimp? Or if you've got an offshore breeze, you can use a kite. I know they use this method in Asia.
A buddy of mine in Hawaii uses a "sit on top" kayak to drag his lures outside the reef (a couple hundred yards from shore). He's caught 100+ lb Ulua using this method.
BTW, there's an 8 foot bull shark up here I wouldn't mind someone catching. He chased me out of the water a couple weeks ago.
gobigkahuna is offline Find More Posts by gobigkahuna
Question GWS brushless outrunners - need info on props for them! A.Kovala Power Systems 7 Apr 08, 2007 09:26 AM
Question Need info on mini crystal for Bluearrow submicro Guidoco GWS (Grand Wing Servo) 2 Nov 15, 2006 12:09 PM
Need info...on/off control for circuit from RX ChuckD DIY Electronics 6 Jul 11, 2005 08:01 AM
Need info on upgrades for T-33 nbj6879 Electric Ducted Fan Jet Talk 6 Sep 23, 2002 08:36 AM
