Old Jun 06, 2009, 08:15 PM
CALIBER30DRIVER is offline
Find More Posts by CALIBER30DRIVER
LINCOLN, NEBRASKA
Joined Sep 2003
Help! set up for Blade 400 with Spektrum DX6i
Ok, every thing is set up according to the manual, I think. I even went to E-flite website and set the transmitter using these updates below:
AILE 1 80% 30%
ELEV 1 80% 30%
RUDD 0/1 100% 30%
RUDD <- 80% -> 80%
RATE SW- GYRO
0: 66.5%
1: 64.0%
NORMAL POS L POS 2 POS 3 POS 4 POS H
0.0% 42.5% 60.0% 80.0% 100.0%
STUNT POS L POS 2 POS 3 POS 4 POS H
100.0% 92.5% 85.0% 92.5% 100.0%
HOLD POS H
- 0.0%
NORM POS L POS 2 POS 3 POS 4 POS H
35.0% 42.5% 50.0% 75.0% 100.0%
HOLD POS L POS 2 POS 3 POS 4 POS H
AILE - 75%
ELEV - 75%
PITC + 70%
CCPM 120*
RUDD - R
SWASH TYPE
TIMER
DOWN TIMER - 04:30
MODEL 1
BLADE400
REVERSE
AILE - R
PITC CUR
SWASH MIX
SETUP LIST
MODEL NAME
D\R&EXPO
TRAVEL ADJ
GYRO
THRO CUR
DX6i Program Settings/Values for Blade 400 3D RTF*
*NOTE - All DX6i settings are the same as "default" unless specified
ADJUST LIST
Here are the changes which I had to make in order for the control surfaces to move in the right direction: AILE + 75%
ELEV + 75%
PITC + 70%. Now, here is my real problem when I increase the throttle, the swashplate would move up, giving me negative pitch instead of positive. I just can't figure this out. Please help.
CALIBER30DRIVER is offline Find More Posts by CALIBER30DRIVER
Old Jun 06, 2009, 08:17 PM
Billh178 is offline
Find More Posts by Billh178
Billh178's Avatar
United States, NV, Las Vegas
Joined Jul 2007
AILE 1 80% 30%
ELEV 1 80% 30%
RUDD 0/1 100% 30%
RUDD <- 80% -> 80%
RATE SW- GYRO
0: 66.5%
1: 64.0%
HOLD POS H
- 0.0%
AILE - 75%
ELEV - 75%
PITC + 70%
CCPM 120*
RUDD - R
SWASH TYPE
TIMER
DOWN TIMER - 04:30
MODEL 1
BLADE400
REVERSE
AILE - R
PITC CUR
SWASH MIX
SETUP LIST
MODEL NAME
D\R&EXPO
TRAVEL ADJ
GYRO
THRO CUR
ADJUST LIST
ELEV + 75%
reverse the Pitch from + to - on the swash mix
Billh178 is offline Find More Posts by Billh178
Old Jun 06, 2009, 08:19 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Try swapping the two "aileron" servo connectors and put the percentages back to negative.
(I don't have a Dx6i or a blade 400, but this is usually the fix when you can't get the CCPM mixing to work)
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Jun 06, 2009, 08:20 PM
pmackenzie's Avatar
Joined Dec 2002
Or try going into the swash mix menu and set the pitch mixing to negative.
Pat MacKenzie
Old Jun 06, 2009, 09:20 PM
LINCOLN, NEBRASKA
Joined Sep 2003
Help with Blade 400
I just veried the servo connections at the receiver and everything seems to be in the right spot. I changed pitch in the swash mix to neg and this gave me way too much neg pitch with the throttle off. And with the throttle wide open, there is just not enough pos pitch to get off the ground. I have only one aileron servo connector, so I can't do the swapping. I tried changing the pitch from normal to reverse and this messed up the CCPM set up completely.
Old Jun 06, 2009, 09:35 PM
pmackenzie's Avatar
Joined Dec 2002
By "aileron servo" connectors I meant ch 1 and ch 6.
Get everything moving the right way first, then worry about the actual pitch.
Pat MacKenzie
Discussion Help Needed with Set Up for Blade 400 and Futaba radio Blue Jacket Mini Helis 6 Nov 10, 2008 10:02 PM
Help! Has Anyone Got Spectrum Set Up For Mx 400? SEAT OF MY PANTS Mini Helis 2 Apr 05, 2006 12:28 PM
Discussion Right set up for a Vasa65 with a Mega 16152 Jack G Diaz Electric Ducted Fan Jet Talk 2 Jan 27, 2006 05:30 PM
Question How Do I Set Up My Zoom 400 with Phoenix 25? BimmerM3 Mini Helis 7 May 11, 2004 08:46 PM
Best brushless set-up for ZOOM 400 ?? andre seb Mini Helis 0 Feb 28, 2004 08:16 AM
