View Poll Results: Would you seriously consider purchasing this board when it is released?
100% for sure 129 29.52%
Probably 126 28.83%
Maybe 81 18.54%
Undecided 37 8.47%
Unlikely 33 7.55%
Would not 31 7.09%
Voters: 437. You may not vote on this poll
Closed Thread
Old May 01, 2010, 11:58 AM
RTF copters maker
maximus-rc's Avatar
South France
Insomnia Carbon foldable maiden flight
Rainy day, but it flies anymore !
Insomnia carbon.AVI (0 min 48 sec)
maximus-rc is offline Find More Posts by maximus-rc
Old May 01, 2010, 12:41 PM
My name is Tom
Tommygunn's Avatar
United Kingdom, England, Kenilworth
Joined Aug 2009
Nic,
The only parts of my Quad that are MK are the FRP chassis squares. All other parts i.e. the booms are 10x10mm alloy that I bought from the local DIY.
The booms themselves weigh a total of 100grams approx, that's one continuous piece and two separate @54cm and 26.5cm(x2) respectively.
The MK chassis squares are negligable and then you have such odds and sods such as roll cage, nut & bolts etc.
Max,
Very slick.
I take it that your motors are not equi-distant and your Quad is actually a rectangle?
I know it is only a short time period but how are the flying characteristics and, if you know, how do the three blade props compare to two blade props?
Tom.
Tommygunn is offline Find More Posts by Tommygunn
Old May 01, 2010, 12:56 PM
RTF copters maker
maximus-rc's Avatar
South France
Hi Tom,
Frame is rectangle but motor to motor si square
honestly, not perfect square 37x40cm...
he flies very well with my "old" quad board that I put from frame to frame...
I didn't touch the gain...but only flew 10mn in my garden.
Maximus
ps: I use 3 blades only for test, 2 blades have better efficiency
Originally Posted by Tommygunn View Post
Nic,
Max,
Very slick.
I take it that your motors are not equi-distant and you Quad is actually a rectangle?
Tom.
Old May 01, 2010, 01:15 PM
My name is Tom
Tommygunn's Avatar
Joined Aug 2009
Fair enough.
Tom.
Old May 01, 2010, 01:21 PM
My name is Tom
Tommygunn's Avatar
Joined Aug 2009
New camera mount on the go.
I have used a cut-off from a piece of pool noodle connector to make an above prop camera mount. It works very well will little perceivable vibration.
I am going to try and improve it further by mouldng some bathroom silicone into thick strip, or blocks, and sandwiching them between the rollcage and the foam/cable ties to further reduce any transmitted vibrations.
Tom.
...and some video.
Quad Onboard Video 1st May 2010 (2 min 6 sec)
Old May 01, 2010, 01:42 PM
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
Tommy
Nice flight and video.
What camera are you using?
Neal
Nobert is offline Find More Posts by Nobert
Old May 01, 2010, 01:56 PM
My name is Tom
Tommygunn's Avatar
Joined Aug 2009
Neal,
It's a Panasonic Lumix DMC-ZS3.
MP4ing the video and then putting it on Vimeo really screws up the video quality though.
Tom.
Old May 01, 2010, 04:17 PM
blindflight's Avatar
CA
Joined Dec 2003
My Quad Finished and ready for first flight :)
I'd like to thank the group for all there help and also George for his efforts in designing a very nice product. I did some filming but need to get it out of my camera. The conditions were: 10-15mph wind and it did get a little tossed a bit for my first flight. However flew rather well for first flight. Being I'm using 4 -750KV motors, a 4cell 4000 Lipo pack, plastic plates & landing gear,my weight was rather high at 4lbs.and giving me maybe a 10min test flight or less The weight seemed to drain my battery as using alot of power to get her up. I did not have any issues with the "flipping" at all. The board seem to do its job, and I did not have to do any adjustments except for flying inputs. I'm going to either make a lighter frame & plate or buy one to get some weight off. Looking forward the new board George!!
blindflight is offline Find More Posts by blindflight
Old May 01, 2010, 05:25 PM
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
Glad to hear that so many people are having success with their quads.
Blindflight. You quad is the sturdiest looking thing I've seen yet! It's a compramise I guess. Strength on a heavy frame. Or longer flight times on a weaker frame. Can't wait to see some video
CJ
Carlos230023 is offline Find More Posts by Carlos230023
Old May 02, 2010, 02:26 AM
My name is Tom
Tommygunn's Avatar
Joined Aug 2009
Blindflight,
What does she tip the scales at, if you know?
CJ,
My thinking is that a Quad on the whole does not require much beefing up unless your going for something intense i.e. twin inverted motors per boom, heavy duty gimbal and camera/video.
You could say you only have to have a beefy Quad if your prone to crashes and even then the bigger they are the harder they fall.
My Quad, which uses MK airframe squares and homemade 10x10mm alloy, is light and I crashed a good few times in the early days and it came out unscathed, except for the props.
Tom.
Old May 02, 2010, 03:42 AM
Joined Jun 2007
Fair enough tom. I'm sure I'll figure it all out when my stuff comes. I've designed three frames so far but with no carbon fiber having showed up yet I'm still just drawing. I've got a 25cm center to center mini quad, a 55cm FPV quad. And something a little more heavyweight at 120cm centers for lifting a monster camera. I'll have to post some pics when I'm next at home.
CJ
Old May 02, 2010, 03:51 AM
My name is Tom
Tommygunn's Avatar
Joined Aug 2009
Yes, we always need photos.
Tom.
Old May 02, 2010, 10:08 AM
CA
Joined Dec 2003
My Quad
TommyGun: weight is a hefty 4 lb's 6.8oz Testing flight time was under 6 mins. Need to trim some serious weight...I have some Trex 600 tail boom's comming
Here are some pictures of parts I made and views. Still trying to work on video.
Old May 02, 2010, 10:17 AM
RTF copters maker
maximus-rc's Avatar
South France
Hi,
Little problems happened this morning...I've had some difficulties to associated the 2.4ghz with the Tx, then once all ok, I've pushed the throttle, the quad took off and...no action of the sticks
Fortunately (for him) the quad plunged into the biggest thicket of brambles...recovery was more painful for me
Only on prop broken, carbon is strong !!!
I have made the arms little longer with some carbon plates and fix a little camera on the top...Here is the movie.
Maximus
Quadricopter "insomnia" carbon inboard camera (1 min 29 sec)
Old May 02, 2010, 10:21 AM
My name is Tom
Tommygunn's Avatar
Joined Aug 2009
Blindflight,
Crikey, 'tis a pretty build though.
What is your motor distance and battery specs?
p.s. if you save your photos in 24bit instead jpeg, even though the file will be much larger, you'll retain much greater quality and the overlayed writing will not deteriate.
Max,
Did you figure out what happened? What radio are you using?
Tom.
Closed Thread
My new AP platform gustabmo Aerial Photography 50 Apr 25, 2005 10:12 AM
Cool Aerobird Xtreme new video platform nakelp86 Aerial Photography 9 Nov 16, 2004 11:55 AM
New AP Platform Ursine Aerial Photography 4 Aug 26, 2004 07:42 PM
New AP platform kahnxx Aerial Photography 1 Jul 12, 2004 09:06 AM
New Aerial Platform?? toofastdave Aerial Photography 40 May 24, 2004 11:54 PM
