| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
| View Poll Results: Would you seriously consider purchasing this board when it is released? | |||
| 100% for sure |
52 | 38.24% |
| Probably |
46 | 33.82% |
| Maybe |
24 | 17.65% |
| Undecided |
3 | 2.21% |
| Unlikely |
7 | 5.15% |
| Would not |
4 | 2.94% |
| Voters: 136. You may not vote on this poll | |||
Thread Tools |
#31 | |
If you need a more beta testers i would be interested! |
#32 |
Wow That's Cool!
This sounds like a cool project ... is it also going support Heading Hold (HH) mode? For comparison, the X-3D-BL supports Height Hold, ACC, and HH on its 3-way switch.
The variable-pitch support has been a goal for many too ... will be following along ... keep up the great work! --Eric-- |
#33 | |
Lets show him a spin. CRASH!
. I should have poointed this out. In any case, yes it will have it . I am suprised to hear that no one has done variable pitch support yet. In my mind it's a very logical next step to achieve near perfect stability. With fixed pitch props there is a large delay between the time a throttle is commanded and the time the prop achieves the coorisponding speed. That and the fact that the effectiveness of any command change varies with the speed of the propeller. I.E command changes on a slower propeller are less effective than changes on a faster propeller. With variable pitch this isn't an issue. The time to achieve a change in command is just equal to the time the servo takes to move to the position. From what I have seen most servos can achieve 90 degrees of rotation in about 100ms - 300ms. Varying the speed of brushless motors over their entire range is much slower. I would estimate most brushless motors take from 500ms to 1 second to go from 0 to 100% throttle. Though speed of command response is an issue it is small in comparison to the issue with effectiveness of fixed pitch props at low speeds. In bad weather (E.g. wind >10 knots) I have seen fixed pitch props stop because the correction required to maintain a pitch attitude was greater than the propeller stopping. Obviously this leads to stability problems. The issue can be fixed by adding a payload to it, thereby increasing the average speed of each propeller, but all of these factors are eliminated 100% by using a variable pitch setup.
#34 |
J.F. Sebastian
Tobias is on it
#35 | |
#36 |
Up flying and stable :)
Sound's rbetter and better every day!
Everything we all ever imagined might become true then... I'm definitely staying tuned, and available
#37 | |
WoW .... I'd like to see this aerobatic Quadro inverted or doing tic tocs Good work Khaled |
#38 |
New Board Teaser
Hey guys, attached is another teaser for the new board. I think I'll be able to fit an accelerometer on it and thats about it. I'll probably have to create a daughter board to get the GPS hold sensor data. It'll mount above the first board on stilts. BTW the board is 2 layer I just haven't been showing the second layer because it makes the board unreabable in a jpg. What do you guys think so far?
#39 |
Good price considering the gyros and barometer alone would cost you... $120 or so.
But, is that 2 PIC Propellers in there? Kinda seems like overkill for the job, unless you have some really intensive future plans. Still, very cool project! |
#40 | |
#41 | |
#42 | |
Good luck, anyway Cheers Ted |
#43 |
Board Redesign
I redesigned the board. I am now able to get everything I need onboard except GPS which will likely still need to be mounted elsewhere. This shouldn't be a problem because the GPS I would like to use can be mounted inside of a surface. E.g. cut a hole in a canopy and it mounts through the hole. As you can see there is still some board space left for other stuff. Any more ideas before I work on finalizing this thing?
#44 | |
Wow That's Cool!
Also, what about adding LED support? ... a programmable sequencer and different 5V/11V power taps for other external devices like CAMs, FETs for remote Tx control? --Eric-- |
#45 |
I'm really intrested in your great work and willing to buy one as soon as you finish.
can you tell me how much will it cost if I want it with the stability option? and when will you finish it? because I am having a problem that I am living in Germany at the moment and in about 2 months I have to go back to my home land so I have to get everything before going back there. |
| Thread Tools | |
| My new AP platform | gustabmo | Aerial Photography | 50 | Apr 25, 2005 11:12 AM |
| Cool Aerobird Xtreme new video platform | nakelp86 | Aerial Photography | 9 | Nov 16, 2004 12:55 PM |
| New AP Platform | Ursine | Aerial Photography | 4 | Aug 26, 2004 08:42 PM |
| New AP platform | kahnxx | Aerial Photography | 1 | Jul 12, 2004 10:06 AM |
| New Aerial Platform?? | toofastdave | Aerial Photography | 40 | May 25, 2004 12:54 AM |
