Go Back   RC Groups > Aircraft - Electric - Helis > Multi Rotor Helis
View Poll Results: Would you seriously consider purchasing this board when it is released?
100% for sure 52 38.24%
Probably 46 33.82%
Maybe 24 17.65%
Undecided 3 2.21%
Unlikely 7 5.15%
Would not 4 2.94%
Voters: 136. You may not vote on this poll
Old Nov 07, 2009, 05:14 PM   #1891
SD..in the following post, you drilled into the CFplate and frame.Is that safe? I have the same parts from HK..both the rod and the plate.
bluehash is offline Find More Posts by bluehash   Reply With Quote
Old Nov 07, 2009, 05:27 PM   #1892
Hunter850's Avatar
Originally Posted by S11D336B View Post
Guys,
Sorry for the problems with the site. There was a compatibility problem with IE and one of my JS menus. I disabled it and everything seems to be working now. Thanks for your patience. I do have some AccelPower news, but you'll have to wait until tonight to hear it.
George, Do you have any boards in stock. Site does not have a "add to cart" for board.
has the programmer there.
kevin
Hunter850 is offline Find More Posts by Hunter850   Reply With Quote
Old Nov 07, 2009, 05:32 PM   #1893
kevin
I can see it. I tried and it added to cart. I'm using FF.
Old Nov 07, 2009, 05:46 PM   #1894
kevin
is on the next page, click the link below did it for you.
http://www.quadpowered.com/index.php...mart&Itemid=72
mir4dor is offline Find More Posts by mir4dor   Reply With Quote
Old Nov 07, 2009, 06:31 PM   #1895
Lets show him a spin. CRASH!
S11D336B's Avatar
It is safe to drill into but wear a mask or use tools which vacuum the dust out of the air. I would put a round CF or wooden dowel in the CF square tubes. Use gorilla glue or >20 minute epoxy to seal the dowel. Avoid drilling into the CF square tubes at the root. Simply sandwich the CF square tubes between CF plates. Just make sure to drill your holes in the CF plates to the left and right of where the square tubes go between the CF square plates. Then when you tighten the hardware the CF square tubes "friction" fit in place. No holes in the square tubes is ideal but some holes in the ends is ok for fitting motors. Remember, most of the force when flying and crashing is at the roots of the CF square tubes.
So AccelPower update. The software is flying well with it. There is however one defect. Every once in a while a bad position is accepted which causes the quad to bank ~10 degrees then recover. At first I was puzzled as to the cause. But then I figured out what the issue is. My accelerometer is only +-3G. The vibrations were periodically causing the accel to sense > 3g periodically. This means the accel gets saturated and the position estimates not only look normalized but are very very wrong. Anyway, long story short. I'm ordering another accel to replace the current one. I expect this change will fix this issue and the accelpower board will then be very close to release. I know I know. . VIDEO! I'll get some soon, it just ends up being dark before I can get out to test.
S11D336B is offline Find More Posts by S11D336B   Reply With Quote
Old Nov 07, 2009, 06:34 PM   #1896
S11D336B's Avatar
I just fixed the website today. Check again. You might need to click on the description before you can see the button. It is at the bottom of the page.
kevin
Old Nov 07, 2009, 07:38 PM   #1897
Sid3ways's Avatar
Send a message via AIM to Sid3ways
Just want a final confirmation, if we don't have the QP board and we want to buy both boards, how much are we talking out the door?
Sid3ways is online now Find More Posts by Sid3ways   Reply With Quote
Old Nov 07, 2009, 08:01 PM   #1898
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
Hey George,
can u give me a thickness of the board with the add on board,I'm thinking of mounting the board inside my frame so i need to know the thickness so i don't wast my time.I should have my new frame part on Monday.
Thanks G
G-unit is offline Find More Posts by G-unit   Reply With Quote
Old Nov 07, 2009, 10:34 PM   #1899
S11D336B's Avatar
something like $430 for both. The height of both boards together is 2x one board. It's right around 1.25" tall with the base and accelpower board connected.
Old Nov 07, 2009, 11:47 PM   #1900
Hi George,
Excellent news!
Will the Accell board have the baro hold and OSD? Do you have any vids of the OSD in action?
Ben
ben1101 is offline Find More Posts by ben1101   Reply With Quote
Old Nov 08, 2009, 12:00 AM   #1901
S11D336B's Avatar
Originally Posted by ben1101 View Post
Hi George,
Excellent news!
Ben
Yes and Yes. I need to post videos. I'm seriously lagging in this.
Old Nov 08, 2009, 12:20 AM   #1902
Mint Mint Mint!!
Seriously looking forward to this George! Along with everyone else I imagine!!
Old Nov 08, 2009, 04:58 AM   #1903
In two hours I will be taking the quad out for round two of test flying. I will have the downlink set up but I won't be flying from it yet. I have no way yet of capturing the footage from the downlink so my Dad will be filming both the Quadf and the downlink. Should be good...
Old Nov 08, 2009, 07:55 AM   #1904
Hi,
Well took it out, Had a flat downlink batt so I didn't get anything from that.
I noticed that the controls were very mushy, and the hold wasn't that great which I attributed to the reasonably low gain setting I'm running. When I tried to increase it the quad starts behaving erratically - which from previous conversations in this thread indicates that the board is receiving vibrations.
At one point due to a spasm the quad hit the ground at an angle, breaking off the landing gear. I will have vids up soon.
I also noted that when I gave yaw input, the quad would respond very slow and once I released the yaw command, it would turn back to its original heading.
Overall, I am fairly confident that all issues noted here are due to my misdeeds in mounting the board and I am very happy with the performance of the board!
Videos soon
  • Name: IMG_3645.JPG
  • Name: IMG_3646.JPG
  • Name: IMG_3648.JPG
  • Name: IMG_3649.JPG
  • Name: IMG_3650.JPG
  • Name: IMG_3651.JPG
  • Name: IMG_3652.JPG
Old Nov 08, 2009, 08:17 AM   #1905
Here are the vids:
QuadPowered Board 2nd Test Flight (1 min 4 sec)
QuadPowered Board Third Test Flight with glitch (0 min 35 sec)
My new AP platform gustabmo Aerial Photography 50 Apr 25, 2005 11:12 AM
Cool Aerobird Xtreme new video platform nakelp86 Aerial Photography 9 Nov 16, 2004 12:55 PM
New AP Platform Ursine Aerial Photography 4 Aug 26, 2004 08:42 PM
New AP platform kahnxx Aerial Photography 1 Jul 12, 2004 10:06 AM
New Aerial Platform?? toofastdave Aerial Photography 40 May 25, 2004 12:54 AM
Bored? Want to fight?
Join the RCGroups clan!
