Old Jun 05, 2009, 06:04 AM
Oregon
Joined Feb 2009
O-ring broke
I just read this in micro RC world magazine <pdf> .
"Because this particular motor comes with a prop saver, the APC props would be as well suited in
this application as the GWS. I used both for the PARK-250 testing. One important thing I noted
with the first prop I installed on the 250. The “O” ring supplied with the motor has a 1/2 inch
I.D. When I ran up the motor for the first time at about half throttle the prop flew off the motor.
It turns out that size “O” ring is too big and therefore when it is wrapped around the prop and
the two screws it is too loose. I went to a smaller 3/8 inch I.D. “O” ring. This is a little harder to
install, but rest assured the prop is now on tight. I never threw another prop after making that
change."
I had the same problem . Is this a special kind of O-ring ? Do I need to go to a LHS ? Can I use one from a auto supply house ?
hlbly is offline Find More Posts by hlbly
Old Jun 05, 2009, 10:46 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Should be able to get them at Home Depot., Hardware stores or industrial suppliers. I use two or three different sizes for different setups.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jun 05, 2009, 11:41 AM
Southern Utah
Joined Mar 2008
"ACE" "TrueValue" is what I use.....needle nose pliers to put on is how I do it....take the old one and match it up
21xct45 is offline Find More Posts by 21xct45
Old Jun 05, 2009, 11:56 AM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
http://www.rcgroups.com/forums/showthread.php?t=924179
O-rings are meant to be in compression, not tension. They are not a good option for prop savers.
Go to ACE (or similar) and get yourself a foot or two of surgical tubing. Cut yourself 1/8" thick slices with a sharp scissors. Reliable & economical!
chalmrast is offline Find More Posts by chalmrast
Old Jun 05, 2009, 12:06 PM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
You can even use those skinny/tiny silicone hair bands you can get in most drug stores. They come in a bag of dozens.
You need several depending on the power/use but they are easy to put on.
It's like using thread instead of rope-a bunch of 'winds' is plenty strong.
flydiver is online now Find More Posts by flydiver
Old Jun 05, 2009, 04:44 PM
Wind blows
Laggard's Avatar
Minneapolis
Joined Jan 2007
I use O rings with no problems.
I'd like to use surgical tubing but can not find it anywhere.
Laggard is offline Find More Posts by Laggard
Old Jun 05, 2009, 05:26 PM
Joined Jan 2009
You can get these o-rings at most hobby shops. But be careful, they come in different diameters and cross-sections. You need one that's somewhat matched to the prop.
Or... you can just use a stout rubber band, wrapped around and around the two screws and the prop hub. Not much worry about prop balance, because the rubber band's mass is low and it's so close to the rotation axis.
rafe_b is offline Find More Posts by rafe_b
Old Jun 05, 2009, 05:29 PM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I got the slingshot rubber from Wallmart. I think it's the same type of rubber and doesn't deteriorate like the O ring rubber.
Gord.
Old Jun 05, 2009, 05:58 PM
Joined Jul 2006
Those are my favorite. Cheap, and strong as anything!
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Jun 05, 2009, 08:30 PM
Wind blows
Laggard's Avatar
Minneapolis
Joined Jan 2007
I'm going to agree with chuck and go back to the hair bands. The O rings are a bitch to put on.
Old Jun 05, 2009, 09:31 PM
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Gord.
What he said..
Works great for me..
bartricky is offline Find More Posts by bartricky
Old Jun 06, 2009, 12:44 AM
WARNING: May contain spam
Xpress..'s Avatar
Joined Oct 2007
Yeah, O-rings don't work well. If they're stretched for long periods of time, they begin to split, and they will eventually let go.
Also, there's o-rings I found that were made specifically to be stretched for long periods of time, maimed at the RC market. Dunno where I found them, but they seemed to work pretty good. No splitting!
Xpress.. is offline Find More Posts by Xpress..
Old Jun 06, 2009, 09:24 AM
Hagerstown, MD
You can get the slingshot bands from many different sporting goods stores, too !
jim_ag3y is offline Find More Posts by jim_ag3y
Old Jun 06, 2009, 02:53 PM
Wind blows
Laggard's Avatar
Minneapolis
Joined Jan 2007
Please don't use the word maim in a thread about prop savers.
I also can't find the slingshot bands anywhere. No Walmart here but I check Cabellas and Target with no luck.
Old Jun 06, 2009, 05:08 PM
Southern Utah
Joined Mar 2008
Man ...........Now I'm confused....hair bands...sling shot, surgical? My local "tru Value" has no idea what I'm talking about
Discussion Prop saver 'O' ring broke Crash Trash Beginner Training Area (Aircraft-Electric) 27 Sep 01, 2011 07:58 PM
o-ring at front fork yodafm1e Motorcycles 3 Nov 26, 2004 10:10 PM
what's the size of the Axi O-ring for the 2212 ? 4DwannaB Power Systems 0 Oct 07, 2004 12:24 PM
Astro 010 o-ring help adar Power Systems 5 Sep 08, 2003 01:56 PM
