Old Jun 03, 2009, 05:57 PM
teha99 is offline
Find More Posts by teha99
Real name's Teja :)
teha99's Avatar
USA, NJ, East Brunswick
Joined May 2008
Boeing 737 and DC-10 build?
Hey guys I know it is a lot to ask for but there are many skilled plan makers in this forum. I would like to request plans for a small Boeing 737. Maybe around 30 inches of wingspan?
I have been wanting a 737 from the day I started this hobby. In fact, it was because I wanted to fly airliners that I even started this whole beginner phase
Thanks guys,
Teja
teha99 is offline Find More Posts by teha99
Old Jun 03, 2009, 09:18 PM
alpapilot is offline
Find More Posts by alpapilot
Newnan, GA
Joined Jun 2005
What I would do for such a smallish airplane is go with a profile. It would be real simple to get a three-view drawing and then scale them to your desired size. To give the fuselage and engines some three dimensional depth try using half-inch blucore.
Try making it a single pusher to start with. If you like it, make another as a twin engine puller (if it is a 737 with the CFM56 engines) or a twin pusher if you build the 737-200 with the JT8D engines.
Not super hard. In fact, I have been thinking about doing the same thing with my current ride, a 757 or 767-300ER.
alpapilot is offline Find More Posts by alpapilot
Old Jun 04, 2009, 05:46 AM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
I did try that once. I think I would be able to get the scale width of the plane and then cut out profiles to be the width of the fuselage and then carve and sand the nose and tail?
Old Jun 04, 2009, 05:54 AM
plane_spotter is offline
Find More Posts by plane_spotter
plane_spotter's Avatar
United Kingdom, Wrexham
Joined Jun 2004
I did see a profile 737 on here some time back. It had dummy 2d foam engines and a mid mount motor in a slot in the fuz. Be dammed if I can find it. Looked like a great but simplistic design.
Good luck
Ash
plane_spotter is offline Find More Posts by plane_spotter
Old Jun 04, 2009, 06:30 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Scroll to the bottom of this page to the 'Similar Threads' list, there are a few threads there with 737 in.
eflightray is offline Find More Posts by eflightray
Old Jun 04, 2009, 06:37 PM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
I went down and saw that someone had built a 737 with edf 75s but there are no pics...
Ash, I saw that too, I cant seem to find it though.
Old Jun 06, 2009, 11:36 AM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
Can any1 that is good at making plans make some... lol
Old Jun 06, 2009, 03:26 PM
brett1984 is offline
Find More Posts by brett1984
RC Airliner Man
brett1984's Avatar
United Kingdom, Dudley
Joined May 2007
not 737 plans but airbuss a300 plans
i dont have any at the moment but after my 747, then the mb339 im drawing in auto cad i will do some 737 plans, i have attached a proflie a300 plans it is to be built like a shock flyer.
i found these plans on the net it was ment to be a little glider that someone has developed i have the videos of the test flights saved to my computer seemed like a good flyer, so in auto cad i enlarged it wingspan 31.5 inches length of around 35 inches, i wa going to make it a pusher, add a little carbon fibre to the leading edges and bam a profile a300, i have tiled the plans too,
i have the dwg/ dxf file if you requiere it, as someoff you lucky people have cnc machines
brett1984 is offline Find More Posts by brett1984
Old Jun 06, 2009, 03:53 PM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
thanks they will help a lot.
Old Jun 06, 2009, 06:18 PM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
I found this picture worthy of becoming plans! It was there the whole time. It gives all the formers for the fuse and everything. All I have to do is go to kinkos and print it out larger and draw out the newer version of the nacelles.
Old Jun 08, 2009, 05:04 AM
lessram is offline
Find More Posts by lessram
Crash-safe
lessram's Avatar
Baar, Switzerland
Joined Oct 2006
This post has already enlarged your profile to 30 inches ws.
http://www.rcgroups.com/forums/showp...30&postcount=4
hth
Olli
lessram is offline Find More Posts by lessram
Old Jun 10, 2009, 07:13 PM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
Ok, guys, this is my plan, I am going to fedex kinkos and printing out a large 3 view of a 737 and a dc-10. I will get 1inch thick pink foam from Home depot and put the 3 view on the rectangular prism I will cut. The side view on the side, and a front view on the front and the top view on the top. Then I will sand it to be like a fuse. Will take time but I think it will be faster than cutting out all the formers and glueing them together and sheeting with depron no? Has anyone tried this? Will it work?
Old Jun 11, 2009, 05:47 AM
dlazarus6660 is offline
Find More Posts by dlazarus6660
If it flies, I crash it!
dlazarus6660's Avatar
United States, FL, Mary Esther
Joined Nov 2006
Sounds like a plan to me!
Just take pic's and make notes on how and what your doing. (so we can avoid your mistakes)LOL Just kidding!
I'll be watching this build.
dlazarus6660 is offline Find More Posts by dlazarus6660
Old Jun 11, 2009, 11:00 AM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
Will start this weekend probably. Leaning towards the dc-10 because I only have one EDF system. I will update the title.
Old Jun 11, 2009, 11:14 AM
teha99 is offline
Real name's Teja :)
teha99's Avatar
Joined May 2008
sorry for the double post, but anyone have any liveries for the dc-10?
Boeing 737, 767, 777, 747 etc., Plans Import_Racer Fuel Jet Talk 9 Jan 08, 2010 06:26 PM
Zagi 400X vs Boeing 737-400 Ex-Slimedriver Foamies (Kits) 4 Nov 19, 2007 03:49 PM
Boeing 737 - the new project Hawker Foamies (Kits) 34 Sep 09, 2007 06:01 PM
Discussion Twin EDF75 Boeing 737 pardus Electric Ducted Fan Jet Talk 27 Sep 21, 2004 01:35 AM
Boeing 737 jermaine Foamies (Kits) 6 Apr 08, 2002 11:21 PM
