Old Jun 02, 2009, 07:27 AM
schoeni is offline
Find More Posts by schoeni
schoeni
schoeni's Avatar
Switzerland
Joined Apr 2007
Alert
Spektrum DSM8 with dropouts
Hi guys
I had problems with the DSM8 module in a Futaba 9C.
My TX has repeatedly dropouts and my colleague had the same effect with his DSM8 and 9C.
The multi socket from Spektrum DSM8 is cheap inferior and, after a certain period only does bad contacts to the TX.
I have therefore a original Futaba connector ordered and these soldered in the DSM8.
The Futaba is gold and many better quality than the spectrum contact.
Since my module is working again without problems.
Also fits on, if you disruptions and bad checks. Check the module through movements. View of the LED from DSM8 module. Begins to blink when they move, this is the problem!
schoeni is offline Find More Posts by schoeni
Old Jun 02, 2009, 11:57 AM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
I have a DM8 module that does this same thing, and it is getting much worse as time goes by. Came to the same conclusion that the connector is bad and needs to be replaced. The connector is a Molex KK series.
village_idiot is offline Find More Posts by village_idiot
Old Jun 02, 2009, 11:39 PM
schoeni is offline
schoeni
schoeni's Avatar
Switzerland
Joined Apr 2007
Wow, we are not alone, though spektrum says that there is not!
Thank you for the information village_idiot.
We had contact with spektrum germany.
This assured us that such cases do not exist.
Had it repaired by Spektrum, would probably be no gold contact was used and the problem would be after 6 months occurred in exactly the same.
They reported the incident to spektrum USA. Spektrum USA is the problem seems not known .
Watch out if you tried.
Where the TX is not too long with this suspension.
It may seem to be that even the TX is hurt.
When you replace the connector, importent that you use the gold version.
My interest is that we are on the spectrum quality problem can draw attention
and know that we are not isolated cases.
It can not be that I have a sender for $ 1000 - buy and the Spektrum module caused disturbances, the fast times much money or even a human life may cost.
Old Jun 10, 2009, 05:44 PM
Tfour2 is offline
Find More Posts by Tfour2
Southwest Ohio USA
Joined Sep 2002
If you could swap out the Molex tin plated contacts with gold plated ones would that be worth doing? Or would you still have the same glitching problems 6 -12 months down the road?
Is the Molex connector (gold contact version) as good as the Futaba part in the long term?
Buzz
Tfour2 is offline Find More Posts by Tfour2
Old Jun 10, 2009, 09:06 PM
Inciting Riots
Joined Dec 2006
The futaba connector seems to have thicker gold, but the thick molex gold plated seem to work really well so far.
Old Jun 10, 2009, 10:13 PM
Tfour2 is offline
Southwest Ohio USA
Joined Sep 2002
Did you install the gold plated contacts yourself or did you have Horizon install them or were they factory installed when you purchased the Spektrum module?
Buzz
Old Jun 11, 2009, 10:16 AM
Inciting Riots
Joined Dec 2006
I haven't fixed my module yet, but I'm using some of the Molex on a project that plugs in to my 9C and it is fine. I'll fix my DM8 module when I get a chance since I have a few of the connectors around.
My second DM8 which I bought when the price went down last year doesn't seem to have this problem, at least not yet so maybe they found it and fixed it.
Old Jun 11, 2009, 04:31 PM
Tfour2 is offline
Southwest Ohio USA
Joined Sep 2002
Thanks for your reply VI. Hopefully Horizon has fixed this.
At least that's what I'd like to think. Please let us know if your newer DM8 module starts acting up.
Buzz
Old Jun 15, 2009, 08:54 AM
schoeni is offline
schoeni
schoeni's Avatar
Switzerland
Joined Apr 2007
As mentioned above, I had to contact Horrizon Hobby germany. they told me that the error spectrum is not known and therefore no action is taken.
So fix yourself, then it works too!
Old Jun 15, 2009, 09:01 AM
Greybird is online now
Find More Posts by Greybird
Greybird's Avatar
Florida
Joined Nov 2004
Or, just buy Futaba.
Greybird is online now Find More Posts by Greybird
Old Jun 15, 2009, 09:13 AM
olmod is online now
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Or keep the contacts coated with CRC 2-26.
olmod is online now Find More Posts by olmod
Old Jun 15, 2009, 05:46 PM
cvause is offline
Find More Posts by cvause
Joined Feb 2007
This explains a lot. I have a DM8 module with a 9Z that was working great until recently. It started with dropouts and weirdness that 2.4 was supposed to solve.
I just ordered a new module (for $109 with AR7000 it was the easiest thing to do). Can someone post the Futaba contact part number or a picture of how the changes were made to the mods?
cvause is offline Find More Posts by cvause
Old Jun 15, 2009, 07:50 PM
Inciting Riots
Joined Dec 2006
figure B 5 contacts gold plated at $0.96 each:
http://www.mouser.com/catalog/catalogusd/638/1450.pdf
Old Jun 15, 2009, 09:24 PM
cvause is offline
Joined Feb 2007
VI, thanks for the hook up.
Old Jun 17, 2009, 03:59 PM
cvause is offline
Joined Feb 2007
For what it's worth, I did a little troubleshooting today. First, I re-bound the rx to the transmitter.
I tried to "jiggle" the module, but the light stayed constant. Then I did a range check with the kluge antenna that is supplied with the module. No dice. The controls would look up around 25-30 paces and then would not come back until I released the button and walked in to around 15 paces. This was repeated many times with the range test locking out around 25 paces. Not a good result.
Then, I swapped out the Spektrum antenna with a 2.2dbi WiFi antenna that I've been using in the shop for setups and testing. Guess what? Good range check's all around.
It seems that my issues are with the antenna. Maybe the cable is crimped or broken, but now I have low confidence in the module system. I love my 9Z, but at this point I'm really nervous about flying any glow models with this setup.
With the good deals on the x9303 systems right now, I may have to break down and walk away from the WCII. I have more money and time in my airplanes than the radio. If I could have complete confidence in a 9303, then that is probably worth the change.
Discussion Spektrum DX6 with full size servos Gary in Fla Radios 13 May 19, 2008 03:22 PM
Discussion JR DX6 Spektrum problems with ESC MX400 Bugg Mini Helis 9 Jun 19, 2006 10:08 AM
Help! Spektrum DX6 with multiple receivers?? weg22 Radios 6 Jun 09, 2006 11:10 PM
Help! Spektrum DX6 with multiple receivers?? weg22 Parkflyers 9 Jun 09, 2006 09:55 AM
For Sale Like new spektrum 6dx with rx in box 150.00 shipped mrctattoo Aircraft - General - Radio Equipment (FS/W) 3 Mar 15, 2006 03:14 PM
