Old Jun 02, 2009, 01:09 AM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Aerobatic Profile Sukhoi Su-31 (with plans)
Here are plans for a profile Sukhoi Su-31 aerobatic 3D model. Like my other designs, it features the same type of simple tabbed construction for a quick and easy build. The dimensions for slots and tabs are made for 6 mm depron.
I've marked out the slot for the motor, but you might want to adjust the slot to fit your particular motor and mount.
This is quite a large model and it is intended to be flown outdoors. Make sure to user proper reinforcements on the wing and elevator, like stiff carbon fiber rods.
Data
Wing span: 105 cm (41 inches)
Length: 98 cm (39 inches)
CoG location: 5.7 cm (2.2 inches) behind wing leading edge
Build instructions
Not available.
Plans
Plans for this model in PDF, Google Sketchup, and AutoCad formats, can be downloaded from http://rc.tomhe.net/su-31. The tiled plans are intended to be printed centered at 100 %.
Consolidated information
Consolidated information on this model is available on my website.
tomhe is offline Find More Posts by tomhe
Old Jun 02, 2009, 03:53 AM
Joined Feb 2009
Great ! Loving it already
Any estimates/suggestions for weight and powerplant/propsize ?
Segunda is offline Find More Posts by Segunda
Old Jun 02, 2009, 11:59 AM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
I believe it will weigh in somewhere around 500 g (17-18 oz.) with a 2.2 Ah battery.
I'm planning to use this motor: Above All 2813-18. 240 W with 1200 V/RPM. Perhaps with a 10x5 prop.
Old Jun 02, 2009, 03:00 PM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
I forgot to include the template for the motor mount in the plans, but I have added it to the list of files for the Su-31.
Old Jun 04, 2009, 08:23 AM
Sweden
Joined May 2008
WOW! That will be my next outdoor foamie!
Soon finished my EDGE 540. http://www.rcgroups.com/forums/showt...light=edge+540
/Micke
Mikson is offline Find More Posts by Mikson
Old Jun 11, 2009, 01:44 AM
Malaysian Flier
Selangor, Malaysia
start to build it since yesterday... maybe snap few photo..
zhnme523 is offline Find More Posts by zhnme523
Old Jun 13, 2009, 11:33 AM
KZ RIDER
raythomas's Avatar
Confederate States of America
Joined Nov 2001
Anybody ever figure out where the CG is on this foamie?
Thanks Ray
raythomas is offline Find More Posts by raythomas
Old Jun 15, 2009, 06:55 AM
Malaysian Flier
Selangor, Malaysia
Here's some pic on progress..
Old Jun 16, 2009, 10:00 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
CG?
CG?
CG?
Ray
Old Jun 17, 2009, 04:13 PM
tomhe's Avatar
Linköping, Sweden
Joined Jan 2007
Originally Posted by raythomas
CG?
CG?
CG?
Ray
Sorry Ray, I haven't built this plane yet. My guess though, is that the CoG will be in line with, or slightly in front of the aileron hinge line.
Old Jun 17, 2009, 04:29 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
That seems "WAY" back doesn't it?
I wish somebody here had built and flown one of these and could tell us the
CG.
I'm dying to build one, but won't cut mine out yet till I hear some flight reports.
Thanks Ray
Old Jun 21, 2009, 10:49 PM
Malaysian Flier
Selangor, Malaysia
Got busy a bit now.. but the plane already glued well and it only wait for electronics and motor.. plus time to fly.. hahah
Old Jun 22, 2009, 04:03 AM
johndamet's Avatar
Joined Feb 2009
I'm working on a 3D bipe right now, but this will be on the to do list next! I have a 3D su-29, but I'm new to 3D flying so I would rather crash one I can rebuild rather than buy parts to fix!
johndamet is offline Find More Posts by johndamet
Old Jul 03, 2009, 02:53 AM
Joined Jul 2009
I Just got done building this plane. (Cut out the foam and glued together)
Then I realized, there is no manual, I was looking for the CG as well lol.
I guess, once I get it all up I will be the test pilot
I'm going to be running a 1800 mah, 2200kv and not sure on which prop yet.
I'll post pics soon.
xDennis is offline Find More Posts by xDennis
Old Jul 03, 2009, 07:20 AM
Napoleon Ohio
Joined May 2009
Looks nice, It has a long tail moment, with very large control surfaces on the tail. The long tail will make it stable. The large surfaces wil make it responsive. A conservative cg at 25% of root chord with lots of throw on the elevator and rudder with 40% expo would be where I would start. This would be on the nose heavy side IMHO. The nose is on the longish side for a foamy, so I would leave plenty of room to move the batt back. I believe the neutral cg will be closer to 30%, but 25% will be a safe starting point. That motor and battery are on the heavy side for un reinforced 6mm depron, so you may want to beef up the nose a bit. It's nice to finally see Su-31 3 views, I've been looking all over the web with no luck. Until now the best I've found was a front and top view, with no side view. IMHO the long moments will favor smooth pattern type flying with good wind tolerance. I bet it will roll like it's on a string. Nice looking plane, good luck.
Jeff
foamlvr is offline Find More Posts by foamlvr
Sukhoi SU 31 Aerobatic ARF parkflyer from Simprop Cayman Electric Plane Talk 9 Jul 25, 2009 04:39 PM
Great Plane Sukhoi SU-31 Profile owners ml0126 3D Flying 8 Oct 27, 2004 10:54 PM
FS Simprop Sukhoi SU 31 (NIB) Aerobatic ARF RC Park Flyer dougpong1 Aircraft - Electric - Airplanes (FS/W) 3 Aug 25, 2003 08:48 PM
Sukhoi SU 31 Aerobatic ARF RC Park Flyer deadstk Aircraft - Electric - Airplanes (FS/W) 0 Jul 31, 2003 06:38 PM
Sukhoi SU 31 Aerobatic ARF RC Park Flyer YZYgold Sport Planes 4 Aug 18, 2002 12:48 PM
