Old Feb 13, 2013, 02:07 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I built the 68" Velox that Amir (3Dwannabe) owns, and when I originally built it, I did built it with the pull/pull, however, when trying to balance the plane, it seemed quite nose heavy, so, I switched it to push/pull, but left the pull/pull control horns. After flying the plane a few times, and getting the CG where I wanted it, I found that I could go back to pull/pull. So...I just left the control horns for the push/pull, and covered the opening for the servo in the tail. I probably have the control rod for the push/pull in my hardware drawer...So, it will be very easy to switch over to pull/pull if needed....
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Feb 13, 2013, 08:08 PM
hosam is offline
Find More Posts by hosam
hosam's Avatar
United States, MI, Livonia
Joined Nov 2004
Originally Posted by rcbirk21 View Post
where are your packs? i kinda want to do a 4320, but i also would prefer push pull if i can manage it
Originally Posted by hosam View Post
let me check tonight and i will let you know...
sorry about the delay but the 6s 50000 packs sits 5" forward of the wing tube for slightly nose heavy inverted flight...
hosam is offline Find More Posts by hosam
Old Feb 13, 2013, 08:11 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
With what motor?
SteveT.
Old Feb 13, 2013, 08:22 PM
hosam is offline
hosam's Avatar
Joined Nov 2004
Originally Posted by SteveT. View Post
With what motor?
SteveT.
sorry Steve but my reply was for rcbirk from a few days ago... I am using a Motrolfly 4325.
Old Feb 13, 2013, 08:24 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
and you said you have the rudder servo up front?
rcbirk21 is offline Find More Posts by rcbirk21
Old Feb 13, 2013, 08:25 PM
hosam is offline
hosam's Avatar
Joined Nov 2004
yup... pull-pull
Old Feb 13, 2013, 08:35 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
No problem....
SteveT.
Old Feb 14, 2013, 05:00 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Man, I bet you get some serious flight time but would be tough to balance.[one too many zero's]
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Feb 14, 2013, 07:12 AM
hosam is offline
hosam's Avatar
Joined Nov 2004
it's a very very very special one of a kind pack and I am the only one in the whole world that owns it ... it was late and I was tired but great catch...
Old Feb 14, 2013, 08:34 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
To those that are running a motrolfly DM4325-310 (on 8s) what prop are you running? I have a xoar 18x8 (gas prop) and it really isn’t very impressive. I was hoping for performance similar to my 58 and 59, which I run a 4315-714 on 4s and a 15x6-7 props. The LHS ordered a Xoar gas prop by accident, but will that make much difference? Really, this plane isn’t all that much better than it was on a DLE20.
nebwake is offline Find More Posts by nebwake
Old Feb 14, 2013, 09:20 AM
hosam is offline
hosam's Avatar
Joined Nov 2004
I can only answer this part and it is NO... I have run gas props on electric motors this size as I have a few sizes from my 30cc motors...
Old Feb 14, 2013, 12:05 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
well, i hate to argue but i think it does make a different. the electric props are significantly lighter, and that will make a difference on spool up. top end performance may not be a big deal, but more weight for spool up will make a difference, but either will work and wont harm anything
Old Feb 14, 2013, 12:16 PM
nebwake is offline
nebwake's Avatar
Joined Mar 2011
I know its not going to hurt anything and I have it perfectly balanced, it just doesn't have the snort I was expecting, I wonder if the 17x10e will be better? I think this plane wants some speed for the high energy stuff it loves and a little less torque up front also.
Old Feb 14, 2013, 01:09 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Well...the lack of "snort", may be as Eric said, the prop is taking longer to spool up, and therefore your aren't getting the punch you are expecting, Try an 18X8 electric, and you may get what you are wanting, if you don't like it, then try the 17X10...Personally, I like the larger diameter props, due to better air wash over the surfaces....YMMV...
SteveT.
Old Feb 14, 2013, 02:13 PM
nebwake is offline
nebwake's Avatar
Joined Mar 2011
I usually go for the largest diameter props also but I want a bit more top end speed on this guy. The 18x8gas has plenty of power and acceleration is instant, just not the top speed I want for my attempts to snap a wing tube in flight
New Product 3D Hobby Shop Velox Revolution 47" 800mZero 3D Flying 8497 Dec 19, 2011 10:48 AM
Discussion 25 Flights: 3D Hobby Shop Velox Revolution Doc Austin 3D Flying 45 Apr 21, 2008 09:19 AM
Video 3D Hobby Shop 47" Velox: On 3S sun.flyer Electric Plane Talk 4 Dec 07, 2007 10:13 PM
Video 3D Hobby Shop 47" Velox: sun.flyer Electric Plane Talk 3 Dec 07, 2007 01:23 PM
