Old Nov 19, 2012, 03:12 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
What color velox? Might be interested in the rudder!
losifanatic is offline Find More Posts by losifanatic
Old Nov 19, 2012, 03:53 PM
mzl969 is offline
Find More Posts by mzl969
United States, MI, Bloomfield Hills
Joined Apr 2012
70 Velox canopy ejection
I had my canopy fly off the plane twice today. The first time it was to far away and I could not see why it came off. After looking for an hour in the woods we found it, but could not tell why it came off, everything was fine on the canopy and the fuse of the plane. The second time up I kept the plane in close and on the second pass of the field you could see the canopy start to rise off the fuse and eject from the plane. The only possible cause would be air pressure inside the fuse pushing off the canopy. I have the cooling air holes cut out per the manual in the bottom of the fuse and I have the plywood "3dhs" plate glued in the back of the canopy. Anybody else have this problem and what suggestions do you have to fix the problem?
mzl969 is offline Find More Posts by mzl969
Old Nov 19, 2012, 04:56 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
is the latching pin passing the front edge of the rear plate enough?
going4speed is offline Find More Posts by going4speed
Old Nov 19, 2012, 05:35 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
The 68" version was famous for ejecting canopies. Ben in person told me that the new version had fixed the issue. I resorted to using canopy bolts retrofitted from a broke 71 Slick canopy. I am watching my new 70" like a hawk. I glued in the canopy latch myself and it is very stiff, so as long as I make sure it is forward I should be OK.
Enterprise7 is offline Find More Posts by Enterprise7
Old Nov 19, 2012, 05:55 PM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Knock on wood, I've tumbled mine pretty hard and never lost one yet. I did make sure the locking pin is going all the way through the wood backing plate on the canopy.
gregory.da is offline Find More Posts by gregory.da
Old Nov 19, 2012, 06:30 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Me too.....so far so good...
Just like I intend to live forever.....so far so good...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 19, 2012, 07:53 PM
mzl969 is offline
Joined Apr 2012
Yes, looking through the canopy I can see the pin through the wood retaining collar.
Old Nov 19, 2012, 07:58 PM
mzl969 is offline
Joined Apr 2012
The canopy latch is firmly in place, that's the 1st thing I checked the first time the canopy ejected. I went over the latch during assembly with thin CA also. I was wondering if I took out the 3dhs backplate in the canopy if that would make a difference? I have flown the plane at least 6 or 7 times and this is the first issue I have had with the canopy.
Old Nov 19, 2012, 07:59 PM
SteveT.'s Avatar
San Jose, CA
Noll had mentioned making sure the latch is glued in properly.....just make sure you don't get any glue into the latch...
SteveT
Old Nov 19, 2012, 08:15 PM
mzl969 is offline
Joined Apr 2012
SteveT
As tight as the canopy fits under the cowl the last thing I thought would eject would be the canopy. The latch is firmly glued in place and the latch pin goea all the way through the collar in the canopy.
Old Nov 19, 2012, 11:37 PM
horton is offline
Find More Posts by horton
ExtremeFlightRC.com
horton's Avatar
Joined Jun 2006
We also recommend cutting a vent hole in covering on the bottom of the fuse.
horton is offline Find More Posts by horton
Site Sponsor
Old Nov 20, 2012, 08:19 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Lost my 71 the other day to a lose servo screw, lots of folks fly the slicks but yall fly the velox. How does it compare to the slick? I may go a different direction this time. I also have a 72, and 74 if that factors into a comparision. I really like the yellow\red. But they have both orange 71 and yellow velox in stock. Power setup would be 8s, 4325 at 330.
I do tend to like the slower near stall stuff over the high speed energy stuff if that helps.
I guess the new velox doesn't come with a E motor box?
Rob
robj is offline Find More Posts by robj
Old Nov 20, 2012, 08:30 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
New Velox comes with an E motor box. Or mine did at least.
Comparison - the Velox is more agile than the Slick. It is easier to get down low with for me as it's easier to hover/harrier/throw around. You can be sloppier with a hover and still bring the nose back up when it starts to fall off. Overall the plane is just more maneuverable than the Slick. It doesn't have quite as much of that 'big plane' smoothness and feel that the other three you mentioned do. But I like it for precisely that reason. To me, when I had a 70" Slick and 72" Extra they flew so similarly that I couldn't justify keeping both. But the Velox flies differently enough that I really really enjoyed it.
It is rock solid in harrier too, especially with the SFG's on.
ryan_m is offline Find More Posts by ryan_m
Old Nov 20, 2012, 09:16 AM
robj is offline
robj's Avatar
Joined Nov 2008
Good info Ryan! Does it have the pitch authority of the Edge and Extra. I like that. Once I got use to the edge and extras pitch control, I liked it a lot. The slick has more yaw control IMO and is a big help in learning to hover, etc. But I was able to learn around that and like pitch over yaw these days.
Old Nov 20, 2012, 09:21 AM
ryan_m is offline
doh!
ryan_m's Avatar
Joined May 2006
Yep. Maybe more even
It's also lighter than the others by a good bit. Mine was about 1/2 lb lighter than the Slick with the same setup in it. So it feels more powerful
New Product 3D Hobby Shop Velox Revolution 47" 800mZero 3D Flying 8497 Dec 19, 2011 10:48 AM
Discussion 25 Flights: 3D Hobby Shop Velox Revolution Doc Austin 3D Flying 45 Apr 21, 2008 09:19 AM
Video 3D Hobby Shop 47" Velox: On 3S sun.flyer Electric Plane Talk 4 Dec 07, 2007 10:13 PM
Video 3D Hobby Shop 47" Velox: sun.flyer Electric Plane Talk 3 Dec 07, 2007 01:23 PM
