Old Nov 10, 2012, 11:04 AM
ben_beyer is offline
Find More Posts by ben_beyer
United States, TX, Canyon
Joined Jan 2011
Originally Posted by JoeR View Post
That's funny. Almost like saying I have this steering wheel cover I better go get a car for it.
True.
ben_beyer is offline Find More Posts by ben_beyer
Old Nov 10, 2012, 11:14 AM
Enterprise7 is online now
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
Originally Posted by kingsflyer View Post
I just converted my V1 Velox from electric to gas. From E-flite 90 to DLE 20. Bowman ring and reed cage mods before the first flight. WOW! 17x6 Xoar prop hovers at 1/4 throttle. After 5 flights, I'm read to start leaning out the engine a little more. Now comes the really hard part - cutting out that beautiful cowl to clear the engine cylinder head.
I fly mainly electrics these days so I've been getting some pretty snide remarks at the flying field for going over to the "Dark Side" with this conversion, but I'm loving the performance of the little 20.
McD
Do you have a throttle curve setup on your throttle. A lot of the times in small gassers you get most of your throttle in the first half of stick travel due to the way the carb works. Most of the time you get 14-15 lbs of thrust with a 20cc and depending on your weight you will need 70-80% or so of available thrust to hover.
What did the weight come out to?
Enterprise7 is online now Find More Posts by Enterprise7
Old Nov 10, 2012, 11:40 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
Yea normally you need a steep curve and a geometrically correct throttle linkage
nebwake is offline Find More Posts by nebwake
Old Nov 10, 2012, 09:14 PM
bob418 is offline
Find More Posts by bob418
Bob418
United States, WI, West Bend
Joined Feb 2011
McD
Quick question, how was the Velox on the Eflite 90??? and were you running 8 cells, and what prop did you run??
bob418 is offline Find More Posts by bob418
Old Nov 12, 2012, 07:54 AM
kingsflyer is offline
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
I fly mostly pattern and sport style manuevers with a little hovering, some harriers, and lots of flat spins.
I have not set up a throttle curve yet for the 20. I set up exact travel geometry for the servo and throttle plate. I get good throttle response up to a little over 3/4 throttle throw and then not much difference from there to full.
The E-flite 90 (325kV) flew very well with an 18x8E APC prop on 6S Thunder power 65C batteries. I flew this setup at SEFF for the last two years. I just wasn't flying it very much here at home so I decided to try my luck with gas power. I had one of Ben's MLD 28s that I was going to use, but it was a tight fit in the cowl, so I got the DLE20.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Nov 12, 2012, 11:24 PM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Can you post what this curve would look like, or the numbers? Is it linear or other?
I have a JR9303 and I think I can setup a throttle curve on it for my gassers.
gregory.da is offline Find More Posts by gregory.da
Old Nov 13, 2012, 08:35 AM
nebwake is offline
nebwake's Avatar
Joined Mar 2011
the curve is different for every engine but you could start like this (I run a dx8) your curve should look graphically like an exponential equation on a graphing calculator.
low-0%
25%-10%
50%-35%
75%-65%
High - 100%
Old Nov 16, 2012, 08:23 AM
USA, NH, Manchester
Joined Jun 2010
One of my curves has the 75% point at less than 50% servo travel. I even have one on my DA-120, although other have reported no need and I think I got the servo geometry backwards. Winter project.
Old Nov 16, 2012, 10:16 PM
nebwake is offline
nebwake's Avatar
Joined Mar 2011
Yea, I usually start with that curve and it tends to get steeper after a flight or two.
Old Nov 16, 2012, 11:03 PM
alfabeast is online now
Find More Posts by alfabeast
3D Addict
alfabeast's Avatar
Merrimac, MA
Joined Jan 2006
Originally Posted by losifanatic View Post
Hummmmmm wonder what I'm doing wrong? This one won't tumble at all. It's like it has very little elevator authority off throttle. Even crankshafts are lazy at best
maybe you have a "compromised" elevator servo that is suffering blowback. Can't speak for the V2, but my V1 velox was a great tumbler as others have mentioned.
alfabeast is online now Find More Posts by alfabeast
Old Nov 16, 2012, 11:13 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
That sounds reasonable.....and mine sure tumbles...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 17, 2012, 08:49 AM
kingsflyer's Avatar
Joined Sep 2005
low-0%
25%-10%
50%-35%
75%-65%
High - 100%
Here's the throttle curve I tried yesterday for my DLE20 on my JR9503 TX:
L - 0.0%
1 - 10%
2 - 20%
3 - 30%
4 - 45%
5 - 65%
H - 100%
Throttle response felt much better with this curve in place.
Thanks for the tip.
McD
Old Nov 19, 2012, 06:57 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Just put a another set in the plane. Went from the 985s to the 7985s still no better
l am working on the velox now hoping some of what l do will help.
losifanatic is offline Find More Posts by losifanatic
Old Nov 19, 2012, 08:08 AM
kingsflyer's Avatar
Joined Sep 2005
V1 Yellow Velox 68" Parts
I stretched my knife edge a little too far so now I have some parts for sale.
I had converted my electric to gas but had not cut out the cowl yet, so the cowl and electric motor box were at home and are still pristeen. The right wing and CF wing tube are perfect as are the elevator and rudder and right wheel pant.
PM me if need any of these parts and we can work something out.
McD
Old Nov 19, 2012, 03:02 PM
SteveT.'s Avatar
San Jose, CA
Sorry to hear that....I always hate to hear of a flier losing a plane....
Shoot me a PM as to how much you want for the cowl, wing and wing tube please
SteveT
New Product 3D Hobby Shop Velox Revolution 47" 800mZero 3D Flying 8497 Dec 19, 2011 11:48 AM
Discussion 25 Flights: 3D Hobby Shop Velox Revolution Doc Austin 3D Flying 45 Apr 21, 2008 10:19 AM
Video 3D Hobby Shop 47" Velox: On 3S sun.flyer Electric Plane Talk 4 Dec 07, 2007 11:13 PM
Video 3D Hobby Shop 47" Velox: sun.flyer Electric Plane Talk 3 Dec 07, 2007 02:23 PM
