Old Oct 20, 2012, 10:14 PM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
Here is a carbon 2.5" spinner:
http://www.ebay.com/itm/2-5-inch-car...item337cf08e90
I've bought a 2" and 3" from the same seller, they look nice. Only real problem is that the mounting screws tend to be too short, but a couple longer screws and you are in business. I've typically used some spare ones from a 3dhs or EF kit and cut off the excess length. They are metric 2 or 3mm if memory serves.
ryan_m is offline Find More Posts by ryan_m
Old Oct 21, 2012, 03:45 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Originally Posted by SteveT. View Post
My Velox has a Hacker A60-6XS But you can't just bolt one in....
SteveT
did you make that mount? looks nice, i was looking at this motor, what size prop are you swinging?
keithy4129 is offline Find More Posts by keithy4129
Old Oct 21, 2012, 05:40 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
@ losi. I have a 68 Velox and while I haven't flown it on present electric configuration yet (used to have a DLE 20) it was a super insane tumble machine before. It tumbled as well as my 58" edge which is just nuts.
nebwake is offline Find More Posts by nebwake
Old Oct 21, 2012, 06:26 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
A friend of mine with a CNC mill made the "X" mount for me, and I made the stand offs. If you are interested in one, I can get another "X" mount made, and make the stand-offs for you...but it would be just a bit different, as I am going to have him make me another "X" mount with 1/8" 60601 aluminum, instead of the 3/16".
As to the prop, it is an 18X10 Xoar, giving me these numbers..(but this was not with fully charge packs)....
Volts=23.3 max, 20.3 minimum
Amps=100.1 max 33.3 average
Watts= 2163 max 722 average
RPM=7079 max 3721 average...
Yesterday when I maidened the plane it was really windy, and I can't actually say the power was "WOW...look at that"...but, it certainly wasn't bad. I felt I needed a little bump in the middle on the throttle curve, which I have now done. I may try an APC 18X10, but if so, I will have to go to a Castle HV 110 ESC (which I have)...right now, I am using a Castle ICE 100...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 21, 2012, 08:20 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Hummmmmm wonder what I'm doing wrong? This one won't tumble at all. It's like it has very little elevator authority off throttle. Even crankshafts are lazy at best
losifanatic is offline Find More Posts by losifanatic
Old Oct 22, 2012, 07:06 AM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
Wanted 3dhobbyshop 48" EPP Extra 330 Starboard main wing
Each post of this request was meant to target buyers of models from 3DHS that may like most have more then one model from that vendor as many here do and not use the classified adds this seem to be the only way to reach the buyers of this brand. A little dog not mine ruined my wing and I have not gotten a response from 3DHS since 10/9 about getting a new wing, as the wing is the only part that is damaged I am searching for a replacement
I need the starboard main wing for a 3dhobbyshop 48" EPP Extra 330, if you have one I am in the market, please send me a PM
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Oct 22, 2012, 10:37 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Might make sure you check your bulk/spam mailboxes to see if a reply from 3dhs might have slipped into there.
Also,just a word of caution,you might get popped for cross posting this request over lots of threads.. If you havent already,try posting your request in the classified section and maybe someone will have a crash unit that has a good part for you to put on your plane.Also,if you have a local craft/hobby store you might could find some pep and can just cut out a copy and make a wing. That might can get you up and flying
Manta1 is offline Find More Posts by Manta1
Old Oct 22, 2012, 10:40 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Next time just use the thread for the plane, the 3dhs fanatics thread, and the off topic thread. Oh and of course the classifieds. The people that have multiple planes from 3dhs are usually subbed to the fanatics and off topic threads so you're just asking the same people over and over again.
hone1er is offline Find More Posts by hone1er
Old Oct 23, 2012, 10:17 PM
SteveT.'s Avatar
San Jose, CA
So... I got around to checking the logging on my ICE 100 in my Velox maiden from Saturday.. .Looks like I might want to change my ESC to something a bit more robust...
Volts.... Max 25, Avg. 23.5, min. 20.3
Ripple...max. 1.37, avg. .57
Amps....max 110.9 avg. 16.5
watts.....max 2446, avg 371
rpm.......max 8057 avg 2556...
SteveT
Old Oct 23, 2012, 10:20 PM
Joined Aug 2010
SteveT
that motor looks like a beast, how would you rate the power, like rocket fast or above average?
Old Oct 23, 2012, 10:25 PM
SteveT.'s Avatar
San Jose, CA
Was really windy that day, and didn't get a chance to ring it out, and haven't had a chance to fly it since, so....we'll see...
SteveT
Old Oct 23, 2012, 10:30 PM
Joined Aug 2010
SteveT
Cool, let us know, looks like a good 6s setup, probably what I would use in this plane as well.
Old Oct 23, 2012, 10:33 PM
SteveT.'s Avatar
San Jose, CA
I am going to have the parts laser cut for an extension box to replace the stock one, and it will also be lighter than the mount I am using right now...
SteveT
Old Oct 24, 2012, 10:09 AM
Joined Aug 2010
SteveT
thats a good idea!
Old Oct 30, 2012, 09:15 PM
SteveT.'s Avatar
San Jose, CA
Got a couple of good flights on my Velox today....found I can take some of the weight out of the tail, and the A60-5XS is a killer motor for the Velox....it has a LOT of power!! And it tumbles and snaps like crazy!!
SteveT
New Product 3D Hobby Shop Velox Revolution 47" 800mZero 3D Flying 8497 Dec 19, 2011 10:48 AM
Discussion 25 Flights: 3D Hobby Shop Velox Revolution Doc Austin 3D Flying 45 Apr 21, 2008 09:19 AM
Video 3D Hobby Shop 47" Velox: On 3S sun.flyer Electric Plane Talk 4 Dec 07, 2007 10:13 PM
Video 3D Hobby Shop 47" Velox: sun.flyer Electric Plane Talk 3 Dec 07, 2007 01:23 PM
