Old Oct 14, 2012, 11:37 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Yes, the extension is much smaller....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Oct 17, 2012, 11:38 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
The choke lever gets REAL close to that motor mount on mine. How is your clearance?
Have you got to cutting the cowl out yet? Based on my template it looks like the entire area around the muffler is going to have to be cut out.
Originally Posted by rmr24 View Post
Yes, I rotated the arm so the rod could go between the motor mounts. The stock arm is held in place by the screw on top. The Spot-On arm has places for two set screws, but I only used one.
going4speed is offline Find More Posts by going4speed
Old Oct 18, 2012, 12:22 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
So.... on a previous run-up of my Velox with a Xoar 18X8, I got these numbers, using a Globee tach and a "Watts Up" meter....
on Thunder Power 6S 65C 5000mAH packs and default settings on Castle ICE100 ESC, with a Xoar 18X8 (suggested prop), I got 7320 peak RPM (actually varied a bit as I was trying to hold both the plane and my Glo-Bee tach at the same time, while my wife ran up the throttle). 24.17 volts, 72.2 amps, and 1648.3 watts (Checked with a "Watts up" meter). Both the watts and amps are pretty low, and since the motor is rated for 2500 watts peak, this means a larger prop could definitely be used.
Yesterday, with a Xoar 20X10, the wires on my "Watts Up" meter were getting hot, but I was showing 91.66 amps, at 23.92 volts and 2,080 watts, and again with my Globee tach, I was showing 7020 rpm...
I usually don't use the logging on the Castle ESCs, but after talking to Kyle at Aero-Model I decided to try it. At first, I couldn't get it to work (I was using my old laptop), so, it took me a few tries which is why the voltage is down a bit, but here is what I got with the logging....
Volts=23.3 max, 20.3 minimum
Amps=100.1 max 33.3 average
Watts= 2163 max 722 average
RPM=7079 max 3721 average...
Even with the partially discharged packs, 2163 watts (235.10 watts per pound) should be enough to pull a 9.2 pound Velox around quite smartly!! Especially, since you really can't compare the input wattage of a 28 pole motor to a 14 pole motor....
SteveT
Old Oct 18, 2012, 09:43 PM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Guys got a question for you. I can't get the velox to tumble well at all. I took out the 985 servos and put in 7985s. That made the plane feel much better. So l worked on elevator throw and cg. Nothing seems to help. Am l the only one having this issue?
losifanatic is offline Find More Posts by losifanatic
Old Oct 18, 2012, 10:25 PM
rmr24 is offline
Find More Posts by rmr24
rmr24's Avatar
Joined Jul 2006
I used a clevis to connect to the choke arm. See first photo in my previous post.
rmr24 is offline Find More Posts by rmr24
Old Oct 18, 2012, 10:53 PM
3DHS 'native'
USA, TX, Spring
Cool! no cowl work yet?
Old Oct 18, 2012, 11:52 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
Anyone looking to do a gasser, you can get the O.S. GT22 for about $320 with the gold coupon and this rebate. The muffler alone is probably worth the extra money over the DLE-20.
http://towerhobbies.com/products/pro...ebate_form.pdf
Enterprise7 is offline Find More Posts by Enterprise7
Old Oct 19, 2012, 04:45 AM
rmr24 is offline
rmr24's Avatar
Joined Jul 2006
Yes, I have cut the cowl. It does require a pretty big opening to get around the muffler Hopefully maiden today, I'll get some photos.
Old Oct 19, 2012, 08:39 AM
3DHS 'native'
USA, TX, Spring
Look forward to it
Old Oct 19, 2012, 10:16 AM
hosam is offline
Find More Posts by hosam
hosam's Avatar
United States, MI, Livonia
Joined Nov 2004
Matt, if you are comparing it to a slick in tumbling then you will not get the same results... my Velox does not tumble anywhere near my 70 Slick... I am running 7955 and 6S on both planes...
hosam is offline Find More Posts by hosam
Old Oct 19, 2012, 10:37 AM
3DHS 'native'
USA, TX, Spring
That is odd considering that is what it was designed for at least in part.
Old Oct 19, 2012, 11:58 AM
Sippin the Koolaid!
Joined Oct 2007
Ok so its not just me
That high lighted part is why we wanted to try the velox instead of getting another slick. Wanted a high energy tumblely plane. I am playing Hell to get it to rotate. Now harriers and hovers very well but really wanted to see some 51 slick style tumbles with a bigger plane
Old Oct 19, 2012, 01:55 PM
3DHS 'native'
USA, TX, Spring
Dang that is not good. That is what I spend most of my time doing is stall turns and tumbles...maybe a short affair with the velox without good tumbles.
Old Oct 19, 2012, 03:25 PM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Find an old 68" Velox, it's a tumbling monster.
gregory.da is offline Find More Posts by gregory.da
Old Oct 19, 2012, 03:29 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
It might make sense that with the added length and square inches of the wing, that it "might" not tumble as hard....not saying that is the case, just that it could possibly be.....
SteveT
New Product 3D Hobby Shop Velox Revolution 47" 800mZero 3D Flying 8497 Dec 19, 2011 11:48 AM
Discussion 25 Flights: 3D Hobby Shop Velox Revolution Doc Austin 3D Flying 45 Apr 21, 2008 10:19 AM
Video 3D Hobby Shop 47" Velox: On 3S sun.flyer Electric Plane Talk 4 Dec 07, 2007 11:13 PM
Video 3D Hobby Shop 47" Velox: sun.flyer Electric Plane Talk 3 Dec 07, 2007 02:23 PM
