Old May 31, 2009, 12:20 AM
JIMinKENTUCKY is online now
Find More Posts by JIMinKENTUCKY
United States, GA, Columbus
Joined Mar 2002
Video
Sapac L-39 EDF with JS1400
Video Link at bottom of page under "files"
Sapac L-39 EDF
JetScreamer 1400
HET 6904 fan
5s 3200 XPS 30-50C
Castle Creations 125 ESC
Castle Creations BEC
This was the maiden and is just a short clip of the handlaunch with a few passes.
Being the maiden I didnt really try to push it , yet it was faster than anything I have flown so far.
No radar gun but I feel like this could hit 140mph regularly once I get used to it and get the control throws where they should be.
Pictures:
http://www.rcgroups.com/forums/showp...&postcount=280
James
JIMinKENTUCKY is online now Find More Posts by JIMinKENTUCKY
Old May 31, 2009, 12:49 AM
coolboarder is offline
Find More Posts by coolboarder
Plane on the Brain
coolboarder's Avatar
Joined Apr 2005
Wow
Do you need additional parts to mount that motor in the sapac fan?
I have some 5s3700's that i would prefer using over 4s4000
coolboarder is offline Find More Posts by coolboarder
Old May 31, 2009, 12:51 AM
Joined Mar 2002
Originally Posted by coolboarder
Wow
I'm sorry, I forgot to mention I was using an HET 6904 fan.
The JS1400 mounts in the 6904 fan though with no modification at all.
James
Old May 31, 2009, 12:52 AM
noobflyer92 is offline
Find More Posts by noobflyer92
Joined Apr 2007
what fan?
noobflyer92 is offline Find More Posts by noobflyer92
Old May 31, 2009, 01:00 AM
Plane on the Brain
Joined Apr 2005
What kind of amp draw are you getting?
thanks
cool
Old May 31, 2009, 01:30 AM
therealhiphop is offline
Find More Posts by therealhiphop
therealhiphop's Avatar
USA, UT, Springville
Joined Dec 2005
Originally Posted by JIMinKENTUCKY
Aileron control was a little twitchy. I have too much throw and I'm using HXT 900's. I will change out the aileron servos to mini digital MG's before flying again.
Wow, nice vid. Jim.
Crap I have the exact same servos for mine. What's wrong with the HXT 900's? Are you using the reccomended throws?
therealhiphop is offline Find More Posts by therealhiphop
Old May 31, 2009, 06:09 AM
CRASH_Jim is offline
Find More Posts by CRASH_Jim
Silent but deadly
CRASH_Jim's Avatar
Cataula, Ga
Joined Mar 2005
I was there with him. Actually I'm the one who shot with his camera... That's why the vid isn't as good as his usual. Anyway, the aileron servos were stuttering a bit before centering. They did it worse went thrown to the farthest point. At the speed it's going, I would say that is too much stress for them.
I use those servos a lot also. I have some in a HET F-20 for ailerons and have been in there for about 2 years now, with no problems. The F20 is not near as fast as this plane though. If I were to change motors in the F-20, I'd change the aileron servos as well.
If you set yours up on a slower power setup, then you may be ok.
CRASH_Jim is offline Find More Posts by CRASH_Jim
Old May 31, 2009, 06:13 AM
Socomon is offline
Find More Posts by Socomon
Joined May 2006
Jim:
Another great vid. That plane hauls! I imagine you could slide that one off its belly with no problem if you didn't have someone along to hand launch for you.
How many watts and what RPM are you getting with that set-up?
Steve
Socomon is offline Find More Posts by Socomon
Old Jun 08, 2009, 12:35 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
James
You are my idol!! I've been trying to tell people that the JS in either the 6904 or Wemo is just stupid on 5S I think you will go beyond 150 once you get used to it.
Steve,
He is getting right near 60,000 rpm's and about 2000 watts
rvincent is offline Find More Posts by rvincent
Old Jun 08, 2009, 12:59 PM
Socomon is offline
Joined May 2006
Boo ya!
Old Jun 09, 2009, 10:26 AM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
Bob,
Whats the amp draw on that setup?
Brian
Originally Posted by rvincent
James
Steve,
Tumbler is online now Find More Posts by Tumbler
Old Jun 09, 2009, 10:30 AM
Tumbler's Avatar
Joined Feb 2003
Nevermind, I just found this. 115 amps??? Are you serious?
http://www.rcgroups.com/forums/showt...4#post11896071
Old Jun 09, 2009, 10:35 AM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
In my Boogie Hawk I am using a CCHV-110, Wemo Mini Pro, XPS 5S 3200, I am getting 106 amps at 21.6v, and 2280 watts Thrust is at or over 5lbs. With him using the HET 6904 I would bet he is around 112 amps. These batteries are amazing! In my Hawk I have so much thrust I plan to use 2S2P 5S 3200's so I can have longer flight times. The plane is large enough to carry it easily. On a single 5S 3200 I get about 4 minutes with occasional bursts of WOT cause you just don't need it.
Old Jun 09, 2009, 11:08 AM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Also Brian those were MAX readings on first throttle up not "settled" readings.
Old Jun 09, 2009, 11:11 AM
Joined Mar 2002
James
Steve,
I use the JS1400 on 4s in the HET F-20 and I remember you suggested I go to 5s. I didn't go 5s in the F-20 because the ESC I was using probably wouldn't handle 5 cells at those amps.
On the Sapac L-39 I did spring for the better ESC and went 5s and glad I did.
Power is incredible! This jet will really move at even less than half throttle!!!!
In fact at just under half throttle it is still faster than most anything in my fleet.
As you said, I do believe over 140 is a possibility.
I haven't flown any thing this fast before and will take some practice to keep control surface movement to a minimum to reduce drag and reach top speed.
James
Discussion Sapac L-39 EDF Unit: How To Tighten Fan LNLP Electric Ducted Fan Jet Talk 11 Dec 26, 2010 06:32 PM
Discussion Savex L-39 EDF Doug Bateman Electric Ducted Fan Jet Talk 1 Nov 03, 2009 02:03 PM
Sold L-39 EDF w/ fan, motor, contoller TomFlyer Aircraft - Electric - Jets (FS/W) 8 May 29, 2006 09:29 AM
Questions about K&A's L-39 Albatros with 609 unit demetrius Electric Ducted Fan Jet Talk 4 Dec 29, 2004 02:58 PM
f/s l-39 edf FASTBEN Electric Ducted Fan Jet Talk 1 Sep 20, 2002 03:14 PM
