Go Back   RC Groups > Aircraft - Electric - Jets > Electric Ducted Fan Jet Talk
Old Nov 02, 2009, 11:49 PM   #181
Birger de la Peña
bdelapen's Avatar
Originally Posted by jayb1rdz View Post
Thanks Birger,
Your instruction manuals are really the best standard. They are clear and logical. I am looking forward to the rest of your build thread. Did you take any pictures of the boxed kit and contents layed out??
regards J
I only got the bottom half of the box thought they will probably be plain white with a page size label on top and on one end, just like the T-45 and L-39 boxes. I don't believe that I took pictures of how the parts are packed in the box however (and it's too late for that now). The contents of the kit (pre-assembly) can be seen in post #142:
http://www.rcgroups.com/forums/showp...&postcount=142
The struts depicted in that post are not included, the pictures came from R&D. I believe that the prototypes are complete and the tooling for the first production run of the struts is being worked on.
Regards,
- Birger
bdelapen is offline Find More Posts by bdelapen   Reply With Quote
Old Nov 06, 2009, 02:24 PM   #182
Soviet Aircraft nut !!!
lavochkin's Avatar
well when do they come to my door? I want mine now badly. Will the new scale struts make it with the new kit or are they delayed?????
lavochkin is offline Find More Posts by lavochkin   Reply With Quote
Old Nov 06, 2009, 10:20 PM   #183
hole digger
Bronze Member
hole digger's Avatar
Hey Joe,
I want one too. Just don't know how long I can wait. I'm painting all my jets in bright colors now so I can see them.
Pete
hole digger is offline Find More Posts by hole digger   Reply With Quote
Old Nov 07, 2009, 03:05 AM   #184
Jetnfast's Avatar
Will the green/white Viperjet be released anytime soon? Is that option coming later? I think the colors look great, I will probably make that my next project (after I finish the T-45) if it ends up being mass produced.
Cheers,
Jetnfast
Jetnfast is offline Find More Posts by Jetnfast   Reply With Quote
Old Nov 07, 2009, 06:04 AM   #185
Site Sponsor
MFALLON's Avatar
Cheers,
Jetnfast
Green/white scheme will be available
And a lime green for Pete so he can see it
MF
MFALLON is offline Find More Posts by MFALLON   Reply With Quote
Old Nov 07, 2009, 07:22 PM   #186
Site Sponsor
MFALLON's Avatar
Viper Shipping
Hey Guy's check for your scheme we will be shipping soon
WORLD WIDE SHIPPING AVALIBLE
  • Name: 70mm_Viper_Jet.jpg
Description: AVALIBLE SCHEME IF YOU ARE ON THE PRE ORDER LIST YOU HAVE FIRST PICK WE WILL BE EMAILING AND CALLING NEXT WEEK. AVALIBLE SCHEME IF YOU ARE ON THE PRE ORDER LIST YOU HAVE FIRST PICK WE WILL BE EMAILING AND CALLING NEXT WEEK. 101.3 KB · Views: 96
Old Nov 07, 2009, 07:42 PM   #187
hole digger
Bronze Member
MF
I'll take the lime green one. how do I order one of these beauties? Quick while I can still see.
Pete
Old Nov 07, 2009, 11:22 PM   #188
Wouldn't be dead for quids..
jayb1rdz's Avatar
Hey Mike, do I need to reconfirm the lime green or my previous order is logged and understood?
jayb1rdz is offline Find More Posts by jayb1rdz   Reply With Quote
Old Nov 07, 2009, 11:26 PM   #189
Jetnfast's Avatar
SWEET! The Rudder is already cutout correct? Or is it like my T-45?
Cheers,
Jetnfast
Old Nov 07, 2009, 11:26 PM   #190
Birger de la Peña
bdelapen's Avatar
Cheers,
Jetnfast
Rudder is already cut, correct.
Old Nov 07, 2009, 11:33 PM   #191
Site Sponsor
MFALLON's Avatar
You can confirm with email to janette@sapacamerica.com
We will email every one on the list or call
Old Nov 07, 2009, 11:41 PM   #192
Site Sponsor
MFALLON's Avatar
Manual
Hey Birger some time next week can you post a link to the Viper manual
Thanks for ALL YOUR HELP!!!! your manuals are the best I have ever seen
MF
Old Nov 08, 2009, 10:35 PM   #193
Birger de la Peña
bdelapen's Avatar
Sapac Viper Jet Build Thread Post 2 of ???
OK, time for another build thread post. Today I will be covering the installation of the retractable landing gear.
First the main wing retracts. I started by marking the cutouts based on the laser etching on the wing skins. By shining a flashlight from the root of the wing towards the landing gear mount you can clearly see where you need to cut the retract gear opening. I marked this with a water based pen and then cut away the covering and balsa wood sheeting with a hobby knife.
Once the opening is cut you will see that the pilot holes for the mounting screws are laser etched in the mounts. I reinforced the mounts with some thin CA, attached a section of air line to the retract unit and screwed it into place with 2.5m X 10mm screws.
I tested the units to make sure that they moved freely but I did not bend and mount the struts at this time, I will be doing that after the wing is attached to the body and I have the completed wheel well available to measure and test. To finish of the main retracts I covered the opening in the wing with the supplied PVC squares.
Next I moved to the nose wheel retracts. The production models will have the nose gear opening etched into the fiberglass body but in my case I had to measure it out and mark it with a pen. Once the opening was marked I cut it out with a rotary cuter. From the inside of the cockpit I cut away the bulkhead that held the opening to the fuselage.
Next I dry fitted the servo and the retract unit to drill pilot holes. These pilot holes were also reinforced with thin CA. I attached a hose to the retract unit and mounted it and the servo in location. I like to use a metal gear servo for the steering as it receives a lot of direct vibration from the landing gear and will avoid premature stripping of the gears.
I assembled the steering and measured the distance from the servo arm to the steering arm in order to rough in the pull-pull steering. I like to assemble this outside of the plane and crimp one side. Once I had that complete I place it all in position, tighten the un-crimped side and crimp it. Finally I tested the retract action and the steering.
Last step in the installation of the retractable landing gear is the mounting of the actuation mechanism. I pre-assembled the valve with a section of hose on each side and a T-fitting at the end of each hose; this makes it easier to complete the plumbing later as there are fewer connections to be made where things are tight. The retract actuator valve and the servo have mounting spots available below the ducts through the fan unit access hatch. Installation is simple; screw them into position and bend up a control rod.
The air tank doesn’t have a bulkhead slot prepared for it so I chose to mount it to one of the inlet ducts using hot glue. I completed as much of the plumbing as I could but final testing will have to wait until the wings have been mounted and the main gear retract units have been connected.
More to come in a few days,
- Birger
  • Name: Viper 5-02.jpg
  • Name: Viper 5-04.jpg
Description: Reinforcing the mounting plate with thin CA. Reinforcing the mounting plate with thin CA. 95.8 KB · Views: 36
  • Name: Viper 5-05.jpg
Description: Retract unit mounted and with air hose attached. Retract unit mounted and with air hose attached. 124.0 KB · Views: 27
  • Name: Viper 5-06.jpg
Description: PVC cover reducing the size of the mounting hole. PVC cover reducing the size of the mounting hole. 78.6 KB · Views: 29
  • Name: Viper 7-01.jpg
Description: Opening marked on fuselage (production models have the opening etched in the fiberglass). Opening marked on fuselage (production models have the opening etched in the fiberglass). 112.4 KB · Views: 31
  • Name: Viper 7-02.jpg
Description: Cut away the opening from the bulkhead. Cut away the opening from the bulkhead. 119.0 KB · Views: 31
  • Name: Viper 7-04.jpg
Description: Steering servo and nose gear retract unit mounted in position. Steering servo and nose gear retract unit mounted in position. 125.8 KB · Views: 38
  • Name: Viper 7-05.jpg
Description: Pull-pull steering assembled outside the airframe. Pull-pull steering assembled outside the airframe. 70.5 KB · Views: 31
  • Name: Viper 7-06.jpg
Description: Retractable nose gear complete. Retractable nose gear complete. 121.7 KB · Views: 26
  • Name: Viper 8-02.jpg
Description: Retract actuator vale and servo installed. Retract actuator vale and servo installed. 128.2 KB · Views: 31
  • Name: Viper 8-03.jpg
Description: Air tank mounted with hot glue to the fiberglass duct. Air tank mounted with hot glue to the fiberglass duct. 64.7 KB · Views: 29
Old Nov 08, 2009, 11:18 PM   #194
hole digger
Bronze Member
Very nice. Is the wire for the gear 3mm or 1/8? Are you going to use the oleo struts on this?
Pete
Old Nov 09, 2009, 01:00 AM   #195
Birger de la Peña
bdelapen's Avatar
Pete
The wires are actually 2.5mm diameter, this is the same diameter on the wire struts, the retract supplied unbent wire struts and the adapter pins for the Scale struts and oleos.
As for the scale struts, I'm hoping to get some eventually but so far there is only one set in the world that fit the Viper Jet. They are gearing up for production as we speak and they should hopefully be shipping via air-mail in a couple of weeks.
It probably goes without saying that the Viper struts are different from the T-45 and the L-39 struts. The Viper struts are Sz180-v where the T-45 and L-39 struts are Sz180.
- B
Sold New Sapac 70mm Edf Fan & Motor (free Shipping) BirdofpraY Aircraft - Electric - Jets (FS/W) 8 Feb 27, 2009 06:06 PM
Sold Sapac 70mm fan and D2842-3200 motor cjdscratch Aircraft - Electric - Jets (FS/W) 1 Feb 04, 2009 07:40 PM
For Sale SAPAC 70mm Fan & 2836-3200 Brushless Outrunner Never Used kryfly Aircraft - Electric - Power Systems (FS/W) 1 Jan 29, 2009 01:06 PM
Wanted sapac 70mm fan outrunner motor kmp647 Aircraft - Electric - Jets (FS/W) 0 Jan 26, 2009 10:18 AM
Sold Sapac 70mm fan and 900watt motor flanker Aircraft - Electric - Jets (FS/W) 13 Jul 03, 2008 05:35 PM
Bored? Want to fight?
Join the RCGroups clan!
